What would you suggest?
Im looking to spend between 2500-3000 on a 5.1 system.
Post edited by Wayne E on
new, used, room size, expectations etc etc.......?Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
We need a bit more information here.
How big is the room?
Do you already have any gear that you'd like to use with the new system?
What type of speakers do you want? A smaller sub/sat setup...bookshelf speakers...floorstanders?
Is this only for home theater, or will you be listening to music on it too?
If you are listening to music on it, will the music listening be in 2 channel or in surround sound?
Would you like to use external amplification, or just use an AVR?
Would you prefer buying new, or is used alright?The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
WELCOME TO CLUB POLK!!
My room is 14x20, prefer floor standing speakers, 50 percent music/ 50 percent ht, hope this would help
Does this budget include purchase of the source component(s) like a DVD/Blu-ray palyer, or you may already have a PS3/XBox. I will assume it will include an AV receiver... and that you already have the display.
have ps3 have denon 4810 avr
Without shopping around much you get a set of RTi As (A9, A6, FxiA6) for $2400, then find a $600 sub that suits your needs. If you think you'd prefer 2 subs you could go for the A7 fronts and get 2 $600 subs , lots to chose from there. This sub thread is invaluable:
http://www.avsforum.com/avs-vb/showthread.php?t=1246684
I've got the A6 center and have listened to the A7 & 9 towers and really like the sound, especially vocals & strings.
If you don't like the A6 surounds, I'd look at the RTi A3s.
PS Nice AVR!
