Dual svs pc ultra-13 pics
rubin
A few pics .Even with all 4 subs on there still are DIPS and PEAKS.Wall to Wall is 11'.The room opens to 24'x14' plus a stairway plus openings to 2 more rooms.It's discouraging with all these subwoofers.
Post edited by rubin on
:eek::eek::eek::eek::eek:Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Try an additional sub. That may help.
4 subs in 2 locations. Try moving them around the room!Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
looking good
If you don't drive a Jeep, then please stay on the pavement.
Conradicles wrote: »Try an additional sub. That may help.
The response one could expect from someone with (1) tiny sub:( -
Nice!!!!!!!!!Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
I agree. Some subs are probably canceling each other out...........4 subs in 2 locations. Try moving them around the room!Samsung HL61A750 LED DLP
Onkyo TX-SR805 receiver
Oppo BDP-83 blu ray player
Polk Audio LSi9 front speakers
Polk Audio LSiC center speaker
Sony SS-MB100H rear speakers
SVS PC12-NSD powered subwoofer
Pioneer PL-514 turntable
Logitech Harmony 628 Universal Remote -
Turned the gain up a little (still running cool) now the bass response is overwelming. I have the bass that is,well like you would expect from subs like these.
That's probably because it appears you've done nothing to treat the room acoustically. Get your learn on about bass traps, and you just might find yourself with 2 extra subs that you can move to another room. -
LessisNevermore wrote: »That's probably because it appears you've done nothing to treat the room acoustically. Get your learn on about bass traps, and you just might find yourself with 2 extra subs that you can move to another room.
+1
If you're still not getting even response with four MONSTER subs, then you should probably mess around some more placement and set up..and acoustic treatments for your room. Having them that close together could be creating cancellation and phasing issues.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
comfortablycurt wrote: »+1
I've solved most of the problems by just increasing spl.The only dead now spot is room centrer.Because of waf,the subs need to stay where they are.I would also like to try acoustic panels but W A F . -
If the nodes caused by the subs are in your primary listening positions and you're unable to move the subs, then you should experiment with using less subwoofers in just one location as more subs don't necessarily mean better bass if they're just canceling each other out.
Any way you can tweak the WAF?
Agreed, and to go one better, I zoomed in on some of your pics, and it appears you have the subs all set to the same phase setting. Experiment with different settings for these, even though you said by upping the levels there was improvement. With the firepower you have in that room, your neighbors should be issuing death threats.:eek:
Multiple subs can be a challenge to get dialed in, but oh so worth it.Any way you can tweak the WAF?
And dig my own grave:eek:
How on Earth did you ever sneak four f#&^ off big, subs past her? LOL
If you let her choose the fabric for the acoustic panels, in my experience, you'll get much more leeway and an easier time of it from the WAF standpoint. Get her involved. -
LessisNevermore wrote: »Agreed, and to go one better, I zoomed in on some of your pics, and it appears you have the subs all set to the same phase setting. Experiment with different settings for these, even though you said by upping the levels there was improvement. With the firepower you have in that room, your neighbors should be issuing death threats.:eek:
Thanks for your input.I read that if all your subwoofers are at the front wall,left and right sides(near the mains)that the phase should be zero.I'm no expert but I tried phase adjustments by ear and couldn't tell any difference.To recap,increasing the gain totally fills the room, in that the nulls now have sound and the peaks,well they are thunderous!I also read that with 4 subs, placement becomes less of an issue.This is my first experience with 4 subwoofers,so I'm learning by reading and appreciate all the input from CLUB POLK! -
get an SVS ASEQ1 (subwoofer equalizer) or the velodyne SMS-1
