Dual svs pc ultra-13 pics
rubin
rubin Posts: 565
A few pics .Even with all 4 subs on there still are DIPS and PEAKS.Wall to Wall is 11'.The room opens to 24'x14' plus a stairway plus openings to 2 more rooms.It's discouraging with all these subwoofers.
Post edited by rubin on
  • vmaxer
    vmaxer Posts: 5,121
    edited May 2010
    rubin wrote: »
    :eek::eek::eek::eek::eek:
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Conradicles
    Conradicles Posts: 6,376
    edited May 2010
    Try an additional sub. That may help.
  • Toxis
    Toxis Posts: 5,116
    edited May 2010
    4 subs in 2 locations. Try moving them around the room!
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited May 2010
  • therealjeepguy
    therealjeepguy Posts: 62
    edited May 2010
    Effing hilarious!!! :D
    If you don't drive a Jeep, then please stay on the pavement.
  • rubin
    rubin Posts: 565
    edited May 2010
    The response one could expect from someone with (1) tiny sub:(
  • danz1906
    danz1906 Posts: 5,144
    edited May 2010
    Nice!!!!!!!!!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • emoxley
    emoxley Posts: 205
    edited May 2010
    Toxis wrote: »
    I agree. Some subs are probably canceling each other out...........
    Samsung HL61A750 LED DLP
    Onkyo TX-SR805 receiver
    Oppo BDP-83 blu ray player
    Polk Audio LSi9 front speakers
    Polk Audio LSiC center speaker
    Sony SS-MB100H rear speakers
    SVS PC12-NSD powered subwoofer
    Pioneer PL-514 turntable
    Logitech Harmony 628 Universal Remote
  • rubin
    rubin Posts: 565
    edited May 2010
    Turned the gain up a little (still running cool) now the bass response is overwelming. I have the bass that is,well like you would expect from subs like these.
  • LessisNevermore
    LessisNevermore Posts: 1,519
    edited May 2010
    rubin wrote: »
    That's probably because it appears you've done nothing to treat the room acoustically. Get your learn on about bass traps, and you just might find yourself with 2 extra subs that you can move to another room.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited May 2010
    +1
    If you're still not getting even response with four MONSTER subs, then you should probably mess around some more placement and set up..and acoustic treatments for your room. Having them that close together could be creating cancellation and phasing issues.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • rubin
    rubin Posts: 565
    edited May 2010
    +1
    I've solved most of the problems by just increasing spl.The only dead now spot is room centrer.Because of waf,the subs need to stay where they are.I would also like to try acoustic panels but W A F .
  • cheddar
    cheddar Posts: 2,390
    edited May 2010
    If the nodes caused by the subs are in your primary listening positions and you're unable to move the subs, then you should experiment with using less subwoofers in just one location as more subs don't necessarily mean better bass if they're just canceling each other out.
  • Ern Dog
    Ern Dog Posts: 2,237
    edited May 2010
    rubin wrote: »
    Any way you can tweak the WAF? :p
  • rubin
    rubin Posts: 565
    edited May 2010
    Ern Dog wrote: »
    And dig my own grave:eek:
  • LessisNevermore
    edited May 2010
    cheddar wrote: »
    Agreed, and to go one better, I zoomed in on some of your pics, and it appears you have the subs all set to the same phase setting. Experiment with different settings for these, even though you said by upping the levels there was improvement. With the firepower you have in that room, your neighbors should be issuing death threats.:eek:
    Multiple subs can be a challenge to get dialed in, but oh so worth it.
    Ern Dog wrote: »
    rubin wrote: »
    How on Earth did you ever sneak four f#&^ off big, subs past her? LOL
    If you let her choose the fabric for the acoustic panels, in my experience, you'll get much more leeway and an easier time of it from the WAF standpoint. Get her involved.
  • rubin
    rubin Posts: 565
    edited May 2010
    Thanks for your input.I read that if all your subwoofers are at the front wall,left and right sides(near the mains)that the phase should be zero.I'm no expert but I tried phase adjustments by ear and couldn't tell any difference.To recap,increasing the gain totally fills the room, in that the nulls now have sound and the peaks,well they are thunderous!I also read that with 4 subs, placement becomes less of an issue.This is my first experience with 4 subwoofers,so I'm learning by reading and appreciate all the input from CLUB POLK!
  • Tomasito
    Tomasito Posts: 142
    edited May 2010
    get an SVS ASEQ1 (subwoofer equalizer) or the velodyne SMS-1
