Making my own cable, any suggestions on wires?
  • Echosphere
    Echosphere Posts: 395
    edited May 2010
    Geez I just looked up the Rocket 33s. Music Direct sells them for $284. For about $65 more you can find a used pair of MIT Music Hose MH 750 bi-wires cables and will have taken a major jump in SQ plus when you upgrade your gear you won't have to upgrade from the 750s.
    Whoa! That rocket stuff is expensive? Is it worth it so far? :)
  • FTGV
    FTGV Posts: 3,650
    edited May 2010
    Echosphere wrote: »
    Though, the PBJ has the 2 ground wires attached on both ends, right? So curious which is better?
    With the PBJ you would connect both grounds at one end and only one at the other.
    Since the extra wire only acts as a partial shield the PBJ will be less immune to noise pick up than would be a normal fully shielded cable.
    I have had good DIY results with the reasonably priced bulk DH Labs BL1 silver cable.
  • Echosphere
    edited May 2010
    FTGV wrote: »
    Could I just buy Teflon shielding for the entire cable and be better off? Or does it not work that way? Meaning, do the wires have to be also shielded from each other?
  • FTGV
    FTGV Posts: 3,650
    edited May 2010
    Echosphere wrote: »
    Teflon is an insulator not a shield,I would guess that the covering on each of the three leads is already Teflon.
  • Echosphere
    edited May 2010
    FTGV wrote: »
    My mistake, yes they already have Teflon insulation.
    What materials do I use for shielding then? Is it a type of material, or the way the wires are set in there?
    Thanks Again.
  • FTGV
    FTGV Posts: 3,650
    edited May 2010
    Cable shielding is usually in the form of an aluminum foil or copper braid.
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited May 2010
    Echosphere wrote: »
    Thanks Again.
    The best way of shielding cales that I know of is actually the conductor to ground. The best material should be mesh copper IE: RGxx cables but for what you are doing I wouldn't worry. As pointed out when wire was first discussed, your first wire connected to groung but not to the gear.
    Cheers!
    TK
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • FTGV
    FTGV Posts: 3,650
    edited May 2010
    The PBJ should be fine as long as you keep it well away from power cords and you don't live beside Radio transmitter etc..
  • hearingimpared
    hearingimpared Posts: 21,136
    edited May 2010
    Echosphere wrote: »
    Thanks Again.
    PM ben62670 and get a dialog going with Ben. He'll teach you everything you need to know about making cables.:)
  • Echosphere
    edited May 2010
    Thank you TK, FTGV and HI,
    This has been very helpful and will keep you all updated.
