Preamp with HT Bypass
RCFGuitars
RCFGuitars Posts: 159
edited June 2010 in 2 Channel Audio
I'm planning to add a pre with HT bypass to my rig, but before I pull the trigger, I want to make sure I'm not overlooking any models worth checking out. Sub out is a must, but other than that, I'm open to suggestions. I'd like to get the best I can in the $2k range, and pre-owned is an option. Right now, I'm leaning towards the Parasound Halo P7 (even though I hate silver), but if there's something better our there, I'd like to know.
Primary System
Polk Audio SDA SRS 2.3TL (RDO198,Sonicap/Dayton/Mills,CardasCCGR,Mye Spikes,DynamatX,Driver Rings,Ben's IC,Bi-Wired)
Polk Audio CSiA4 x2 (C)
Polk Audio FXiA6 (S)
Polk Audio RTiA3 (RS)
Polk Audio FXiA4 (FX)
Epik Sentinel x2
Yamaha RX-V3900
Rotel RB-1090
Rotel RMB-1095
NAD C565 BEE
Technics/KAB SL-1210M5G w/ Denon DL-160
Parasound Halo P7
OPPO BDP-83
Panasonic TC-P65V10 65" Plasma
Post edited by RCFGuitars on
    nooshinjohn Posts: 26,002
    edited May 2010
    Check out Rogue Audio. I run the Perseus with great results, and it's TUBES baby!
  • RCFGuitars
    edited May 2010
    Thanks, that looks interesting. It says it has a sub out, but I don't see it on the back. Does it use one of those variable outs for the sub/s? How do you like the phono pre? What tubes are in there? I've probably got a hundred 12AX7's and 12AT7's around, so that could lead to some tube swapping fun.
    Primary System
    Epik Sentinel x2
    Yamaha RX-V3900
    Rotel RB-1090
    Rotel RMB-1095
    NAD C565 BEE
    Parasound Halo P7
    OPPO BDP-83
    edited May 2010
    12au7's are the stockers in it. The phono-pre is awesome, but I do not use a sub in my two channel configuration so I cannot answer that one.
  • thsmith
    thsmith Posts: 6,082
    edited May 2010
    Look at the Anthem Pre 2L, in the 650-700 range.
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited May 2010
    Adcom GFP-750 ($700 range)
    Nice system you put together. I see you totally redone the 2.3's. Got any updated pics?
  • Face
    Face Posts: 14,340
    edited May 2010
    heiney9 Posts: 25,510
    edited May 2010
    leroyjr1 wrote: »
    The 750 doesn't have a sub out although it has a 2nd set out outputs which could be used for a sub, just no bass management.
    Are you looking for bass management as well? If not, the 750 is a very neutral and natural sounding pre-amp, built like a tank, etc.
  • RCFGuitars
    edited May 2010
    leroyjr1 wrote: »
    Yes Lee I do have quite a few pics. I took a lot as I was going along. It's hard to believe it's been almost a year already :) I'll post a few when I can pull them up later.
    Primary System
    Epik Sentinel x2
    Yamaha RX-V3900
    Rotel RB-1090
    Rotel RMB-1095
    NAD C565 BEE
    Parasound Halo P7
    OPPO BDP-83
    edited May 2010
    RFC... I did not know you were so clost to Indiana. I have 2.3's as well and would be pleased to have you drop by and hear the Rogue.
  • RCFGuitars
    edited May 2010
    heiney9 wrote: »
    Yes, bass management is a feature I believe I will need. I'm guessing that if the pre does not have bass management than I would have to be changing the settings on the subs themselves, and I have them set where I want them right now.
    Primary System
    Epik Sentinel x2
    Yamaha RX-V3900
    Rotel RB-1090
    Rotel RMB-1095
    NAD C565 BEE
    Parasound Halo P7
    OPPO BDP-83
  • RCFGuitars
    edited May 2010
    I'm in the suburban Chicago area, so we probably aren't that far apart. That Rogue through your rig would probably give me a pretty good idea of what it would sound like in mine. As I get closer to a decision, I may just take you up on your kind offer.
    Primary System
    Epik Sentinel x2
    Yamaha RX-V3900
    Rotel RB-1090
    Rotel RMB-1095
    NAD C565 BEE
    Parasound Halo P7
    OPPO BDP-83
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited May 2010
    RCFGuitars wrote: »
    If you are getting a preamp with HT Bypass - I assume that means you are trying to put together a hybrid HT/2-channel system right?
    How did you plan on hooking up your AVR to the preamp and sub?
    edited May 2010
    The Rogue has no bass management either. You are pretty much looking at an HT pre w/HT bypass :confused:. I have yet to see a tubed pre that incorporates bass management for a subwoofer.
    edited May 2010
    Erik Tracy wrote: »
    Good point. What processor (not AVR) are you running thru the HT bypass that doesn't already have bass managment built it?
  • RCFGuitars
    edited May 2010
    Erik Tracy wrote: »
    Yes, this preamp would be added to the system in my sig. Since I was looking at the P7, I was planning to run the front and sub pre outs of my RX-V3900 to the P7, and then the P7 to the 1090 and subs. I was not going to change anything else since the new pre would be for 2 channel listening only. The Yammie has bass management, and I have it dialed in, so maybe I don't need it in the pre after all.
    Primary System
    Epik Sentinel x2
    Yamaha RX-V3900
    Rotel RB-1090
    Rotel RMB-1095
    NAD C565 BEE
    Parasound Halo P7
    OPPO BDP-83
  • Polkitup2
    Polkitup2 Posts: 1,642
    edited May 2010
    I understand running the front pre-outs to the P7 for HT bypass but I don't see how you can run the sub pre-outs from the receiver to the P7 at the same time.
  • Erik Tracy
    edited May 2010
    RCFGuitars wrote: »
    I have a hybrid system now built up that works pretty good:
    * RX-V1800 as my AVR
    * Musical Fidelity A5 Integrated Amp with HT Bypass
    Sub out from the AVR goes to the LFE input on the sub
    Left and Right preouts from the AVR go to HT Direct inputs on the A5 Int Amp
    Then, from the A5 pre-outs, I run two cables to the Left and Right Line level inputs to my sub (So, I've got three cables hooked up to my sub at the same time: one from the AVR, and two from the Integrated Amp).
    When in HT mode, I switch the A5 to "bypass" and the preamp section cuts off and the A5 is just an amp - preouts cut out too so that the sub only runs from the Sub out from the AVR and all of the applicable bass management settings.
    When in music mode, my source components such as CD, Phono, are connected directly to the A5 and I use the xover freq adjustment on the sub to blend the sub with my mains. And my AVR is off - so no input from the AVR on the LFE connection.
    That's the beauty of a HT Bypass - you can have both your AVR and your pre (or int) amp hooked up to the sub at the same time!
    A preamp with bass management might be useful if you really want to fine tune how your mains and sub are set up. If you are truly concerned over amp strain due to scary bass levels going to your mains, then a preamp w/ bass management might be a good thing for 2-channel listening.
    Otherwise, you may not need a preamp with bass management.
  • leroyjr1
    edited May 2010
    RCFGuitars wrote: »
    Don't know how big your listening room is but when I had them in my 24x14 living room I didn't need a sub. The bass output was great.
    Take care....
  • RCFGuitars
    edited May 2010
    Polkitup2 wrote: »
    I took that info from the P7 owners manual.
    Primary System
    Epik Sentinel x2
    Yamaha RX-V3900
    Rotel RB-1090
    Rotel RMB-1095
    NAD C565 BEE
    Parasound Halo P7
    OPPO BDP-83
  • RCFGuitars
    edited May 2010
    Erik Tracy wrote: »
    Thank you for that info. It definitely gives me something else to consider. With the Rotel 1090 I'm not worried about amp strain, but I do like the 20hz range of the Epiks in my system. So maybe I do need the bass management hmmm:confused:
    Primary System
    Epik Sentinel x2
    Yamaha RX-V3900
    Rotel RB-1090
    Rotel RMB-1095
    NAD C565 BEE
    Parasound Halo P7
    OPPO BDP-83
  • Erik Tracy
    edited May 2010
    RCFGuitars wrote: »
    In glancing at the P7 manual - it sure looks like everything can be patched into it and it is 'smart' enough to let AVR bass management to pass thru, or you can let the P7 do all the bass management for both HT and music.
    I run an Epik sub too!
    Unfortunately my A5 integrated amp does not have a sub input or bass management, so for HT/Movies, I need to run the Sub out from the AVR to the LFE input on the sub.
    But - for music - I use the xover control on my Epik to blend the sub with my B&W Bookshelves.
    The sub gets all the signal spectrum and the xover sets the low pass cutoff freq of the sub.
    The drawback of my setup - if any - is that the B&W bookshelves get full audio sprectrum when I listen to 2-channel sources. So some folks would roll their eyes at me and wag their finger in derision at trying to blend mains with a sub, or that my poor 250w/channel amp will strain to drive my bookshelves with scary deep bass. :p
  • RCFGuitars
    edited May 2010
    Does anyone know if the Rogue Perseus will let the AVR bass management pass through?
    Primary System
    Epik Sentinel x2
    Yamaha RX-V3900
    Rotel RB-1090
    Rotel RMB-1095
    NAD C565 BEE
    Parasound Halo P7
    OPPO BDP-83
    edited May 2010
    http://www.rogueaudio.com/Products_Perseus.htm
    Give them a call in the morning:) Their customer support is fantastic.
  • Erik Tracy
    edited May 2010
    RCFGuitars wrote: »
    I looked at the Perseus manual.
    The Perseus only has 2 inputs for HT - intended for the Left & Right Front preouts from an AVR.
    That means if you use the AVR bass management, your sub needs to be connected to the AVR sub out.
    When the Perseus is in HT bypass, the preamp is...well...completely bypassed and the Left/Right Front Preouts go straight to your external amp.
    Bass Management in this case would be from the AVR via the direct sub out connection from your AVR to your sub - it would not be thru the Perseus.
    Now, the question is, do you want your sub to work when you are listening to 2-channel sources like a CD.
    If so, you also need to connect the pre-outs from the Perseus to your sub's Left and Right Line level inputs.
  • RCFGuitars
    edited May 2010
    Erik - thanks for all the info, that helps quite a bit
    Primary System
    Epik Sentinel x2
    Yamaha RX-V3900
    Rotel RB-1090
    Rotel RMB-1095
    NAD C565 BEE
    Parasound Halo P7
    OPPO BDP-83
  • RCFGuitars
    edited May 2010
    leroyjr1 wrote: »
    Here are a few pics I took along the way. Thanks again to Ben for the xo's.
    Primary System
    Epik Sentinel x2
    Yamaha RX-V3900
    Rotel RB-1090
    Rotel RMB-1095
    NAD C565 BEE
    Parasound Halo P7
    OPPO BDP-83
    edited May 2010
    If you come down to hear the Rogue... bring those crossovers with you so I can hear what the mods sound like.
  • blueboxer
    blueboxer Posts: 621
    edited May 2010
    Erik Tracy wrote: »
    I was looking at the A5 for my two channel setup as well as integrating it into my HT setup. I had narrowed down my integrateds to the PS Audio C100, Cambridge 840A, and A5. The HT bypass of the A5 is really appealing and has put it in the lead thus far, but the 840A offers the ability to control multiple zones later on if I move it upstairs with the Incognito setups. Oh, blast these choices. LOL
  • RCFGuitars
    edited May 2010
    heiney9 wrote: »
    For what I'm trying to accomplish, it looks like a pre w/HT bypass and bass management is a must. Unfortunately, I haven't been able to find a tube pre with those features either. I guess that puts the P7 back at the top of the list.
    Anyone know of any other pre's in that price range, with those 2 features?
    Primary System
    Epik Sentinel x2
    Yamaha RX-V3900
    Rotel RB-1090
    Rotel RMB-1095
    NAD C565 BEE
    Parasound Halo P7
    OPPO BDP-83
  • Face
    Face Posts: 14,340
    edited May 2010
    :rolleyes:
