level setting on 3803
dave shepard
dave shepard Posts: 1,334
edited November 2003 in Electronics
I know that the 3803 has a memory for the diff modes for each source that was last used and will change accordingly. My question is can I change the speaker leavels for each source tv,dvd,audio etc. I noticed that when I watch the satalite the sub is on but the -5 is too low to even hear +8-+9.5db is where I can get it to a desent level. If I adjust it for the satalite signal will it remember to return to -5 when watching dvd's?
Dave
Post edited by dave shepard on
  • mantis
    mantis Posts: 17,318
    Yes you can and here's how to do it.
    Preset up your levels VIA the setup menu.
    Now go to any source and use the 4 way arrow key and scroll through the speaker levels and adjust to your liking.
    I perfer to use the system settings but Denon adds this to add some flavor to each input....it's usefull
    Dan
  • dave shepard
    Thanks that is what I thought but didn't want to do anything to screw up all calibrations I've made for watching movies.
    Thanks again
    Dave
  • Dr. Spec
    Dr. Spec Posts: 3,780
    The only caveat I will add is if the source signal is DD or DTS, altering the sub level via the remote will also alter it in the main set-up menu for DVD movies.
    And you need to leave your main set-up menu unlocked in order to alter the sub level for the Personal Memory Plus function to work via the remote.
    SVS
