level setting on 3803
dave shepard
I know that the 3803 has a memory for the diff modes for each source that was last used and will change accordingly. My question is can I change the speaker leavels for each source tv,dvd,audio etc. I noticed that when I watch the satalite the sub is on but the -5 is too low to even hear +8-+9.5db is where I can get it to a desent level. If I adjust it for the satalite signal will it remember to return to -5 when watching dvd's?
Dave
Dave
Post edited by dave shepard on
Yes you can and here's how to do it.
Preset up your levels VIA the setup menu.
Now go to any source and use the 4 way arrow key and scroll through the speaker levels and adjust to your liking.
I perfer to use the system settings but Denon adds this to add some flavor to each input....it's usefullDan
Thanks that is what I thought but didn't want to do anything to screw up all calibrations I've made for watching movies.
Thanks again
Dave -
The only caveat I will add is if the source signal is DD or DTS, altering the sub level via the remote will also alter it in the main set-up menu for DVD movies.
And you need to leave your main set-up menu unlocked in order to alter the sub level for the Personal Memory Plus function to work via the remote."What we do in life echoes in eternity"
SVS
