Stapling grill cloth on the 1.2tl's
Toolfan66
I am having a hard time putting staples in the frame for the grill cover to pin down the cloth. I know seems like an easy task but the staples do not want to go in. I thought the frame was just MDF but this **** is hard. I pulled the staples out so I should be able to put staples in. I had no problems with the 1C's. is there some magical staple I need? Or some special tool? I am using an electric stapler (Power Shot Pro) question is what do I do, and need?
Thanks,
Larry.
Thanks,
Larry.
Post edited by Toolfan66 on
Shorter staples? They are less likely to bend the "legs".Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I am using 1/4" staples the shortest I could find.
I've never seen staples used on SDA speakers. The cloth is always glued on.Political Correctness'.........defined
President of Club Polk -
Every SDA I have had my hands on have been glued and stapled.
Now all the monitors i have had my hands on have just been glued. -
Larry, I stand corrected. I was thinking of the side panels that I've seen.
The air powered staplers that the pro's use never seem to have a problem getting a staple to seat.Political Correctness'.........defined
I was just thinking about that and wondering where I might borrow one. -
Buy one from home depot/Lowes and return it when you are done:eek:Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Ben,
You are on it !!!!Some final words,
"If you keep banging your head against the wall,
you're going to have headaches."
Warren -
surely you have access to a compressor. at work? you need one for the home. and harbor freight (yeah, i said it) is good enough to purchase inexpensive pneumatic staplers. mine all work grand.
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
7.1 SURROUNDS: RTI6'S
XBOX 360WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
http://polkarmy.com/forums/index.phpbobman1235 wrote:I have no facts to back that up, but I never let facts get in the way of my arguments. -
I look my grills to an autosound shop that had the correct materials and tools. Cost me twenty bucks to have them stapled on and stretchedThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
I used an Arrow Model T50 stapel gun with T50 3/8" staples for all my SDA grille recloth work. I bought the gun and staples at Home Depot. I made sure I held the gun firmly against the grille to prevent recoil and the spring powered T50 had no problem driving staples all the way into the MDF (or whatever it is the grille frames are made of).Proud and loyal citizen of the Digital Domain and Solid State Country!
This is all great stuff. My buddy is returning to me a 30 year old pair of RTR 300 D's that I sold him back in the '80s and I'm going to be performing major surgery on them when he drops them off.
A few people here were unimpressed by them but they were in their day a great tower speaker. As a matter of fact, it was those & RTR 600 Ds that I replaced with a first run set of SDA/SRSs back in 1984. I can't wait till they come home to papa. -
A big misconception on the forum is that the material commonly referred to and believed to be MDF, is in fact, plain old particle board. Sometimes that stuff can be very hard to penetrate with fasteners and having a helper to stretch the fabric while you shoot the staple might work out better for you. If you do a practice/test shot while firmly holding the stapler down on the surface, and if the staple doesn't seat properly, your stapler is not operating correctly and you should try another one. I use a vintage Duofast (manual type) that will sink a 9/16" staple in solid oak with no sweat, you can find one of them on ebay for very little $$ and possibly return the electric one.Good Luck !:)
Like this:;)
http://cgi.ebay.com/DUO-FAST-STAPLE-GUN-MANUAL-HAND-STAPLER-USED-/330434927478?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item4cef74db76 -
^^^My 2.3TL's, grills included, are MDFThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Yeah, I should have stated that all of the speakers I own are constructed of particle board, and not MDF.
This stapler is the best I've found yet. It's never let me down on grill frames and odd jobs I've asked it to do.
Cheap, uses standard staples AND shoots up to 1 1/4" brads.
It's the one that you actually put forward pressure on when you depress the handle to activate the stapler.
It even put 1/8" staples in my AR9LSi plastic frames when I replaced the cloth on them.
Recommended product..
Harry -
Sounds like you need better speakers.:p;)The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
DarqueKnight wrote: »I used an Arrow Model T50 stapel gun with T50 3/8" staples for all my SDA grille recloth work. I bought the gun and staples at Home Depot. I made sure I held the gun firmly against the grille to prevent recoil and the spring powered T50 had no problem driving staples all the way into the MDF (or whatever it is the grille frames are made of).
Same here, but maybe with 1/4" I think.
I was having serious shoulder pain and sometimes I was medicated pretty well during that period and I might have used 3/8" to.
Maybe tomorrow I'll pull one out and see.
I found a block or book the same thickness as the grill wood and used it as support for the rear of the staple gun. My wife and I had both SDA-SRS2 grills done in 2 hrs. That was casual work speed too.Most people just listen to music and watch movies. I EXPERIENCE them.
