opinions wanted on denon 1803
Jeff1
I have been looking at this receiver because it seems to have the most features in its price range. I was almost ready to purchase when I started reading of the many problems some have had with Denon receivers. Does anyone have any good experiences with this or a similar receiver? Thanks.
Post edited by Jeff1 on
I've had the 1802 for almost 2 years now. It is a fine receiver and I've had absolutely no problems whatsoever. It plays as loud as I want for my HT in a very large room and it also does well with music. The Denons seem to work well with the Polk RT(whatever) series of speakers. As I recall the only difference in the two is the 1803 is 6.1 and the 1802 is 5.1. I think the 1803 has pre-outs for all channels and the 1802 only has front 3 pre-outs. Denons are well regareded HT AVRs and you will find more possitive than negative reviews overall."Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
Thanks, maybe I was just overlooking the good reviews and only seeing the bad. I really want to purchase a 6.1 rcvr, and it seems the 1803 is a pretty good value.
I'm very happy with my 1803. I bought it in Feb. and haven't had a single problem. It drives my 6700's nicely and sounds great (to my ears ) for both movies and music.
I suppose 1803's can be had for less now that the 1804's are out. I think it's a great value. Still, you should listen and compare. Onkyo and Harmon Kardon, to name just a couple also make nice AVR's in that price range. It's not always just about the most features. One may sound a whole lot better to you than the others even if it has a few less features.
The 1803 does not have an on screen set up feature (the 1804 does). That means all your set up info is only displayed on the Rec. itself. That is a big drawback for some but I never found it that hard to deal with.
Good luck and have fun.Denon AVR-1803
Polk RM6700 w/ Infinity Entra Sub -
I have two Denon's, an 1801 purchased in 1999 and a 1802 purchased in 2001 and have never had a problem with either one. They are both pushing Polk systems and are a great match up IMHO.
I've had my Denon AVR-1803 for about 2 months so far and I am more than pleased with it. I've had no problems what so ever. The unit is very nice with a smooth sound to it. I really enjoy it and believe it is an outstanding receiver for the money.
Gerald LemayMain System:
Denon AVR-2805, Polk Audio RTi70's, Polk Audio CSi40, Polk Audio FXi50, Paradigm PW-2200 v.2, Toshiba 42XV545U HDTV
Second System:
Denon AVR-1705, Polk Audio R40, Polk Audio CS245i, Polk Audio R15, Paradigm PS-1200a -
Count me as one very happy 3803 owner. No problems at all."What we do in life echoes in eternity"
SVS -
Thanks for the responses. I am replacing an old Sony pro logic 1 rcvr, so I'm sure it will be a vast improvement.
I replaced a Sony DD5.1 receiver with a Denon 1603 and the improvement is drastic.2 Channel: Adcom GTP-450,Adcom GFA-555II,Denon DVD-1920,Denon DCD-610,Pro-ject Phono Box E, Music Hall MMF-2.3 SE with Music Hall Spirit, Klipsch RP-250f, Velodyne F-1200 sub
HT Rig: Mitsubishi WD-73642,HK AVR-2600, Sony BDP-S580, Polk RTi100, Polk R50s,CSi25 Center,SVS 25-31 PCi Sub NSD Upgrade -
I, too, have a Denon 1803 and I love it. Never had a problem with it. It's a great receiver for a basic 5.1 or 6.1 setup. I paid $329 NIB for mine about 6 months ago. Go for it.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
