opinions wanted on denon 1803
Jeff1
Jeff1 Posts: 34
edited November 2003 in Electronics
I have been looking at this receiver because it seems to have the most features in its price range. I was almost ready to purchase when I started reading of the many problems some have had with Denon receivers. Does anyone have any good experiences with this or a similar receiver? Thanks.
Post edited by Jeff1 on
  • shack
    shack Posts: 11,154
    I've had the 1802 for almost 2 years now. It is a fine receiver and I've had absolutely no problems whatsoever. It plays as loud as I want for my HT in a very large room and it also does well with music. The Denons seem to work well with the Polk RT(whatever) series of speakers. As I recall the only difference in the two is the 1803 is 6.1 and the 1802 is 5.1. I think the 1803 has pre-outs for all channels and the 1802 only has front 3 pre-outs. Denons are well regareded HT AVRs and you will find more possitive than negative reviews overall.
  • Jeff1
    Jeff1 Posts: 34
    Thanks, maybe I was just overlooking the good reviews and only seeing the bad. I really want to purchase a 6.1 rcvr, and it seems the 1803 is a pretty good value.
  • section19
    section19 Posts: 90
    I'm very happy with my 1803. I bought it in Feb. and haven't had a single problem. It drives my 6700's nicely and sounds great (to my ears ) for both movies and music.
    I suppose 1803's can be had for less now that the 1804's are out. I think it's a great value. Still, you should listen and compare. Onkyo and Harmon Kardon, to name just a couple also make nice AVR's in that price range. It's not always just about the most features. One may sound a whole lot better to you than the others even if it has a few less features.
    The 1803 does not have an on screen set up feature (the 1804 does). That means all your set up info is only displayed on the Rec. itself. That is a big drawback for some but I never found it that hard to deal with.
    Good luck and have fun.
    Denon AVR-1803
    Polk RM6700 w/ Infinity Entra Sub
  • GZ
    GZ Posts: 343
    I have two Denon's, an 1801 purchased in 1999 and a 1802 purchased in 2001 and have never had a problem with either one. They are both pushing Polk systems and are a great match up IMHO.
  • glemay
    glemay Posts: 574
    I've had my Denon AVR-1803 for about 2 months so far and I am more than pleased with it. I've had no problems what so ever. The unit is very nice with a smooth sound to it. I really enjoy it and believe it is an outstanding receiver for the money.
    Gerald Lemay
    Main System:
    Denon AVR-2805, Polk Audio RTi70's, Polk Audio CSi40, Polk Audio FXi50, Paradigm PW-2200 v.2, Toshiba 42XV545U HDTV
    Second System:
    Denon AVR-1705, Polk Audio R40, Polk Audio CS245i, Polk Audio R15, Paradigm PS-1200a
  • Dr. Spec
    Dr. Spec Posts: 3,780
    Count me as one very happy 3803 owner. No problems at all.
    SVS
  • Jeff1
    Jeff1 Posts: 34
    Thanks for the responses. I am replacing an old Sony pro logic 1 rcvr, so I'm sure it will be a vast improvement.
  • hljones821
    hljones821 Posts: 35
    I replaced a Sony DD5.1 receiver with a Denon 1603 and the improvement is drastic.
    2 Channel: Adcom GTP-450,Adcom GFA-555II,Denon DVD-1920,Denon DCD-610,Pro-ject Phono Box E, Music Hall MMF-2.3 SE with Music Hall Spirit, Klipsch RP-250f, Velodyne F-1200 sub
    HT Rig: Mitsubishi WD-73642,HK AVR-2600, Sony BDP-S580, Polk RTi100, Polk R50s,CSi25 Center,SVS 25-31 PCi Sub NSD Upgrade
  • Early B.
    Early B. Posts: 7,900
    I, too, have a Denon 1803 and I love it. Never had a problem with it. It's a great receiver for a basic 5.1 or 6.1 setup. I paid $329 NIB for mine about 6 months ago. Go for it.
    "God grooves with tubes."
