Ive got the HT system mapped out... or most of it
So in the next couple of months I am going to slowly pick up components to build me a HT system...
Here is what I have decided on as of now...
Mains - Tyler Super Towers
Main subs - Tyler Custom 10"
Center - Def Tech CLR3000 (built in 10" sub)
Surrounds - Def Tech Powermonitor (any of them, anywhere from a 6.5" to 10" sub
LFE subwoofer - Hopefully a VMPS Larger, if not - itll be a SVS or Epik or something... just something solid real low hahaha
Processor - Emotiva UMC-1
Main amplifiers - Odyssey Mono Extremes (HT Bypass on the Candela)
Center and surround amplifiers - Not really sure -- I was thinking Emotiva XPA-3
LFE sub amplifiers - Again, not really sure - maybe a Crown XTI series or something for the crossover functions...
DVD player - PS3
Any thoughts?
DVD player - PS3
Any thoughts?
Post edited by VR3 on
Why not a timbre matched center from Tyler?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Cost - 2,000 for the center (Super Center) - and 1,000+ for the surrounds ---
Besides the Def Tech stuff is stellar for HT and the midbass punch from having powered subwoofers in all speakers should be off the hook... lol - I love bass in movies... love it
The Def Tech tweeter should be bright enough to go with the Tylers without problem - they wont have quite the detail of course, but thats ok.
If I cant score a CLR3000 - Ill probably look around for a CS1000P from Polk -- but the CLR3000 goes pretty cheap and its a little smaller in the width department...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I think that system will blow up your house.
Looks good to me.
FYI...there is a CS1000P for sale now on this forum which is kind of rare. -
Yeah I saw that -- was interested... but the local pick up kind of killed it...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
What are you going to use for bass management? Do all the subs have adjustable phase? And will they all be hooked up to the same breaker?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
center, surround, lfe sub amp = own 20 amp circuit
each main amp/main sub has its own 20 amp circuit
the center sub, preamp, sources will be on its own 20 amp circuit
the surround subs will prolly be on a 15amp circuitr - but basically its own
Each speaker has all necessary adjustments - and will be ran in a tri-wireable config - not lfe- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
What projector?polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Alright --
More thinking...
Im thinking about just getting the Studiomonitor 450 from Definitive -- which is a single 6.5", 1" dome tweeter and a 10" PR - that should realistically be more than adequate... (not to mention cheaper)
So... hmm
I have a bid on a CLR3000 right now -- if I get it, Ill pick up a Studiomonitor 450 pair in the next month or so
I have a line on a VMPS Larger... and after that all I will need is the processor and the amps!
Sweet
And - no projector, just the TV- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Isn't the PowerMonitor series better performing?
When I heard them a while back at Audio Breakthroughs (hi-fi store), the PowerMonitor series sounded better/more accurate than my 10B's, at least in the bass department.polkaudio RT35 Bookshelves
The Studiomonitor 450 and the Powermonitor 900 should be the same speaker except for the subwoofer and the amplifier...
They both use the tweeter and midbass out of your BP10B -- but the Power Monitor 900 uses a 10" sub + amp where as the Studiomonitor 450 uses a 10" PR
Both have identical enclosure construction....
So - really I have to decide if having full range surrounds is really worth it to me and really the Studiomonitor 450 wont be a slouch in the bass department, no Def Tech speakers really are.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Sounds like a crappy system to me...... no offence but you could have done better with the money
Especialy on that umc1 .. Ive heard it sounds garbage compared to many receivers with preouts -
Interesting comments boy genius
What would you do?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Another processor though has been the Pioneer Elite SC stuff
Im indifferent to amplifiers honestly... Id like to keep it all in one unit since it will be located in the master bedroom closet - Im thinking at this point a 5 or 7 ch to also power inwalls and outdoor speakers throughout the house.... lots of thoughts
But if someone wants to make this a Emotiva trash thread - you can go kick rocks...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
For starters I would get a used integra 9.8 for $150 more dollars and get a used anthem amp for the same money as an emotiva
I'm not trashing anything except large cerwin vegas
UMC1 just doesnt have a sophisticated auto cal like audessy and I dont even think it has balanced outsssssss ssssssss sssssss -
Interesting suggestion - I will definitely look into it...
I may get a Pioneer Elite processor - aside from looks, they usually are pretty awesome and can be had at a decent price used...
Amps -- like I said Im indifferent... Ill scrounge the used market - but Outlaw and Emotiva both have attractive products for the price...
Now if I could find some Odyssey Audio amps - 5 channels for like 500 bucks Id be happy (ha, not going to happen)- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I dont need Auto Cal - thats what SPL meters are for... and balanced outs? eh - no need... Im an RCA kind of guy - besides the center, surround, lfe out will be ran through the walls to a closet where the amp will be... lol
Again, thanks for the suggestion, I will look into that Integra- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Suggestion: even if you are going to use your TV, consider looking into an Anchor Bay / DVDO iScan unit. These make a HUGE difference as I've seen them at trade shows, etc.
http://www.anchorbaytech.com/products/systems/
Basically it's like an external DAC - except for video.polkaudio RT35 Bookshelves
SPL meters cant take into account the millions of differences like time delay and reflections but its your money
Look on the gon for anthem amps ,they are high end low price amps for 700 bucks a 7ch . or hardcore sunfires go for 800
A used integra 9.8 will kick any receivers **** plus it will hold its price with good resale -
Im no videophile... but when I watch a Blu Ray Im pretty darn impressed to say the least...
I mean can it possibly make that much of a difference????- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Well, based on the demo's I've seen - yes an external scaler can make a difference. And it's not just sharpness... the major difference I saw was in the realism of the picture.
It basically allows you to have your video processing done external to the TV, similar to how you would use a DAC with a CDP.polkaudio RT35 Bookshelves
Vr3MxStyler2k3 wrote: »Im no videophile... but when I watch a Blu Ray Im pretty darn impressed to say the least...
Does not make a diff to justifiably pay more
Thats why I recommend the integra 9.8 because the newer models costing hundreds more just have more vid proccesing
my next purchase will be ghe 9.8 for raw audio and none of that noisy avr bull -
+1 on this... Another consideration would be the Rotel 1098polkfarmboy wrote: »For starters I would get a used integra 9.8 for $150 more dollars and get a used anthem amp for the same money as an emotivaThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Rotel doesny have hdmi audio but the cheaper 1069 does but doesnt do 1080p 24 fps or hdmi 1.3
polkfarmboy wrote: »Rotel doesny have hdmi audio but the cheaper 1069 does but doesnt do 1080p 24 fps or hdmi 1.3
I cannot hear a difference between HDMI audio and optical. Currently I use optical for the audio and HDMI for video for HT use.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
HDMI is a must- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I think this is very important. If cost of the Tyler center is an issue then I would consider downgrading the mains to allow for a timbre matched center.
Example:
Paradigm Studio 20 (or Studio 100 floor-standers) V.4 mains,
Paradigm studio CC-590 (or CC-690 if you have the space) V.4 center -
While I agree timbre matching is important...
This system is 90% music, 10% HT...
If a center channel cost 2,000 dollars from Tyler... my budget is hurt pretty bad.
I can get a processor, center, surrounds, and a subwoofer - all for the price of a matching Tyler center...
So putting it into perspective, that makes no sense.
Besides the CLR3000 - while maybe not using Seas drivers is definitely no slouch - infact, I would put that center against any Polk center except maybe the CS1000p - and even then it will be a close race...
I will definitely look into those processors...
Im kind of doing this backwards though - Im getting the speakers, then the amps, then the processor... sooo by the time I get to the processor there could be something new in town...
Besides Rotel, Nad, B&K, Adcom - what are some other amps that are decent and can be found used on the cheap?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Surrounds are a go - I picked up a pair of Studiomonitor 450
Alright - cmon Center!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Vr3MxStyler2k3 wrote: »Besides Rotel, Nad, B&K, Adcom - what are some other amps that are decent and can be found used on the cheap?
For HT/Music, I love my Sunfire Signature 425~5.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
