Adcom war
Cthulhu11
Cthulhu11 Posts: 69
edited May 2010 in Electronics
Ok you adcom guru's, which would you prefer:
GFA-585 LE
GFA-5802
Post edited by Cthulhu11 on
  • acmf74
    acmf74 Posts: 937
    edited May 2010
    For what application?
    heiney9 Posts: 25,492
    edited May 2010
    5802 hands down. No contest. But yes, it would be nice to know the application and corresponding gear used. Won;t change my choice but I could make other suggeations as well.
    Toolfan66 Posts: 18,149
    edited May 2010
    I own both and they both are very good amps but I would say the 5802 is a step above A little more refined if you will.
  • Cthulhu11
    Cthulhu11 Posts: 69
    edited May 2010
    For 2-channel SDA style, Like Toolforlifefan likes it
    edited May 2010
    Cthulhu11 wrote: »
    Go for a 5802 you will be very happy with it..
  • ben62670
    ben62670 Posts: 15,969
    edited May 2010
    5802. The 585 is very nice, but a **** to work on and most need to be rebuilt do to leaking capacitors.
    Ben
