Belles 21A preamp
    Toolfan66 Posts: 18,187
    edited May 2010
    jerryj12 wrote: »
    Wow I want some of those to put in mine. Have you priced them Larry?
    How much will 4 run?
    $189.60 ea. from Madisound for a 15uf:eek: I will just stick with the Clarity ESA/Sonicap Gen1 or the AURICAP
    edited May 2010
    cnh wrote: »
    What are you going to use the Belles for?
    cnh
    Just to play and try something different.;)
  • curved
    curved Posts: 664
    edited May 2010
    That is one pertty pre!!
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
  • george daniel
    george daniel Posts: 12,096
    edited May 2010
    I think that the Auricaps would be the way to go,cost/performance related,as there are alot of auricapped versions out there,,you'll only need 4,,you have the mundorf in the mix already,,for my 20a,,different value caps are used in the signal path (2.2uF's),, it's much easier for you to tube roll(2),than me,(4),,good luck,,I'm sure that you'll get many hours of listening pleasure. :)
  • george daniel
    edited May 2010
    Well the anxiety has passed(thank you Mr.Face),,lol,,I took out the calipers and they(Clarity's) will fit,,it'll be tight though.
  • Todd R
    Todd R Posts: 6
    edited November 2010
    Anyone know where I can get a remote for a 21A?
    The previous owner spilled something on it and only the volume works now.
  • zarrdoss
    zarrdoss Posts: 2,562
    Todd R wrote: »
    you might have better luck posting this in the wanted section.
