Belles 21A preamp
Wow I want some of those to put in mine. Have you priced them Larry?
How much will 4 run?
$189.60 ea. from Madisound for a 15uf:eek: I will just stick with the Clarity ESA/Sonicap Gen1 or the AURICAP -
What are you going to use the Belles for?
cnh
Just to play and try something different.;) -
That is one pertty pre!!Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors** -
TOOLFORLIFEFAN wrote: »$189.60 ea. from Madisound for a 15uf:eek: I will just stick with the Clarity ESA/Sonicap Gen1 or the AURICAP
I think that the Auricaps would be the way to go,cost/performance related,as there are alot of auricapped versions out there,,you'll only need 4,,you have the mundorf in the mix already,,for my 20a,,different value caps are used in the signal path (2.2uF's),, it's much easier for you to tube roll(2),than me,(4),,good luck,,I'm sure that you'll get many hours of listening pleasure.
JC approves....he told me so. (F-1 nut) -
Well the anxiety has passed(thank you Mr.Face),,lol,,I took out the calipers and they(Clarity's) will fit,,it'll be tight though.JC approves....he told me so. (F-1 nut)
Anyone know where I can get a remote for a 21A?
The previous owner spilled something on it and only the volume works now. -
you might have better luck posting this in the wanted section.
