non-common gound amp and SDA CRS
mctimoth
mctimoth Posts: 5
I've a pair of SDA CRS's. Do I need to apply the Inter Connect cable fix so I can connect them to my Denon 5808?
Tim
  • fbm211
    fbm211 Posts: 1,488
    edited May 2010
    What interconnect cable fix?
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • mctimoth
    mctimoth Posts: 5
    edited May 2010
    Sorry. I meant Denon 5805
  • fbm211
    fbm211 Posts: 1,488
    edited May 2010
    I take it you cant tie the neg speaker terminals together.
  • ben62670
    ben62670 Posts: 15,969
    edited May 2010
    Do you have pin blade IC sockets, or blade blade sockets?
    Ben
  • mctimoth
    mctimoth Posts: 5
    edited May 2010
    Blade - blade.
  • mctimoth
    mctimoth Posts: 5
    edited May 2010
    The instructions for the non-common ground hardware call out the pin-blade IC cable. I have a blade-blade IC cable, does that make a difference?
    Tim
