Low Volume While Listening to Cable Box
seadoons
I have an Onkyo TX-SR607 and a polk speaker setup detailed in my signature. I am loving it so far. The only problem I am having is that I have to crank the receiver volume WAY up to get any decent level of volume out of it while listening to my AT&T Uverse box. I do not have this problem listening to the radio tuner, DVD, Ipod, etc. Any thoughts as to what I am doing wrong? I can't find any adjustements on the cable box and I have poured through the adjustements on the receiver. I am missing something.
Help.
Help.
On a UPS truck on the way to my house as of 12/09/09:
Fronts: Polk RTi4
Center: Polk CSi3
Rears: Polk RC85i (in-ceiling)
Sub: Polk PSW110
Receiver: Onkyo TX-SR607
Patio: Polk Atrium 45
Accessories: Onkyo UP-HTI HD Radio Receiver, SIRIUS SUPH1 Home Kit, Onkyo UP-A1 I-Pod Dock
Fronts: Polk RTi4
Center: Polk CSi3
Sub: Polk PSW110
Post edited by seadoons on
Help.
No adjustment in the Cable Box menus for Fixed vs. Variable output? Seems strange.
They all seem to have that from what I have seen.
good luck!
DCFor Sale 2019:
Tortuga Audio LDR passive preamp
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center -
Thanks, so what you are saying is that in your experience most cable boxes do not have any adjustments?On a UPS truck on the way to my house as of 12/09/09:
Fronts: Polk RTi4
Center: Polk CSi3
Sub: Polk PSW110
Accessories: Onkyo UP-HTI HD Radio Receiver, SIRIUS SUPH1 Home Kit, Onkyo UP-A1 I-Pod Dock -
Sorry forgot my punctuation!For Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
Help.
Are you using Dolby Volume or Audyssey Dynamic Volume?
If you are, try turning those off.My System Showcase!
Media Room
Paradigm Studio 60 - Paradigm CC-690 - Paradigm ADP-390 - Epik Empire - Anthem MRX300 - Emotiva XPA-5
Living-room
Paradigm MilleniaOne - Rythmik F12GSE - Onkyo TX-SR805 - Adcom 5400
Headphones
Sennheiser Momentum Over-Ear - Shure SE215 - Fiio E18 Kunlun -
Doc - I was just trying to make sure I understand what you are trying to tell me. Did I get it right? :-)
Mystik - I see you are in Sugarland. That is where I am right now! I will try your suggestions as well.On a UPS truck on the way to my house as of 12/09/09:
Fronts: Polk RTi4
Center: Polk CSi3
Sub: Polk PSW110
Does the uverse remote have a volume button on it? Most cable boxes to have volume control and a setting to turn it off & just output a fixed high level (what you want).
Anyhow, if it lacks that setting, but has a volume button, just crank the uverse box volume all the way up and leave it there, then use your receiver to adjust.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
i have the same issue with the COX cable box and nowhere in the box menu to adjust the sound output. I connected via a digital coax output
Yes, sorry I wasn't clear w/o puncuation. Seems like you should be able to toggle between both modes, fixed and variable.
Did you find it buried in there?
We had a small connectivity issue last week, and they swapped in a new box for some reason; much newer looking and works great. Maybe you could report this as a problem as it is a standard feature on most boxes?For Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
