Low Volume While Listening to Cable Box
seadoons
seadoons Posts: 46
edited May 2010 in Electronics
I have an Onkyo TX-SR607 and a polk speaker setup detailed in my signature. I am loving it so far. The only problem I am having is that I have to crank the receiver volume WAY up to get any decent level of volume out of it while listening to my AT&T Uverse box. I do not have this problem listening to the radio tuner, DVD, Ipod, etc. Any thoughts as to what I am doing wrong? I can't find any adjustements on the cable box and I have poured through the adjustements on the receiver. I am missing something.
Help.
On a UPS truck on the way to my house as of 12/09/09:
Fronts: Polk RTi4
Center: Polk CSi3
Rears: Polk RC85i (in-ceiling)
Sub: Polk PSW110
Receiver: Onkyo TX-SR607
Patio: Polk Atrium 45
Accessories: Onkyo UP-HTI HD Radio Receiver, SIRIUS SUPH1 Home Kit, Onkyo UP-A1 I-Pod Dock
Post edited by seadoons on
  • doctorcilantro
    doctorcilantro Posts: 2,028
    edited May 2010
    seadoons wrote: »
    Help.
    No adjustment in the Cable Box menus for Fixed vs. Variable output? Seems strange.
    They all seem to have that from what I have seen.
    good luck!
    DC
    For Sale 2019:
    Tortuga Audio LDR passive preamp
    Decware EL34 amp
    Allnic H-1201 phono
    Zu Union Cubes
    iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center
  • seadoons
    seadoons Posts: 46
    edited May 2010
    Thanks, so what you are saying is that in your experience most cable boxes do not have any adjustments?
    Fronts: Polk RTi4
    Center: Polk CSi3
    Sub: Polk PSW110
  • doctorcilantro
    edited May 2010
    seadoons wrote: »
    Sorry forgot my punctuation!
    For Sale 2019:
    Decware EL34 amp
    Allnic H-1201 phono
    Zu Union Cubes
  • mystik610
    mystik610 Posts: 699
    edited May 2010
    seadoons wrote: »
    Help.
    Are you using Dolby Volume or Audyssey Dynamic Volume?
    If you are, try turning those off.
    My System Showcase!
    Media Room
    Paradigm Studio 60 - Paradigm CC-690 - Paradigm ADP-390 - Epik Empire - Anthem MRX300 - Emotiva XPA-5
    Living-room
    Paradigm MilleniaOne - Rythmik F12GSE - Onkyo TX-SR805 - Adcom 5400
    Headphones
    Sennheiser Momentum Over-Ear - Shure SE215 - Fiio E18 Kunlun
  • seadoons
    seadoons Posts: 46
    edited May 2010
    Doc - I was just trying to make sure I understand what you are trying to tell me. Did I get it right? :-)
    Mystik - I see you are in Sugarland. That is where I am right now! I will try your suggestions as well.
    Fronts: Polk RTi4
    Center: Polk CSi3
    Sub: Polk PSW110
  • unc2701
    unc2701 Posts: 3,587
    edited May 2010
    Does the uverse remote have a volume button on it? Most cable boxes to have volume control and a setting to turn it off & just output a fixed high level (what you want).
    Anyhow, if it lacks that setting, but has a volume button, just crank the uverse box volume all the way up and leave it there, then use your receiver to adjust.
    Backburner:Krell KAV-300i
  • nhhiep
    nhhiep Posts: 877
    edited May 2010
    i have the same issue with the COX cable box and nowhere in the box menu to adjust the sound output. I connected via a digital coax output
  • doctorcilantro
    edited May 2010
    seadoons wrote: »
    Yes, sorry I wasn't clear w/o puncuation. Seems like you should be able to toggle between both modes, fixed and variable.
    Did you find it buried in there?
    We had a small connectivity issue last week, and they swapped in a new box for some reason; much newer looking and works great. Maybe you could report this as a problem as it is a standard feature on most boxes?
    For Sale 2019:
    Decware EL34 amp
    Allnic H-1201 phono
    Zu Union Cubes
