Source for blade/blade
falcon377
Hi, I recently acquired a pair of the original SDA-CRS with the blade-blade connectors on the sda cable, one is falling apart. Just wandering if anyone knows a source for these.
______
Mike
______
Mike
Post edited by falcon377 on
I don't think Polk has any blade/blade cables to sell. Might find 'em on eBay; and it seems to me that Ben makes cables.
Wouldn't be hard; worst part would be finding the actual cable ends. If you converted your speaker's SDA connectors to binding posts, all you'd need for the cables is four banana plugs and two lengths of speaker wire; and the materials (solder, heat shrink tubing, etc.) to hold it all together. -
Call Polk they will hook you up with a blade/blade cable. They do not have the pin/blade cable.
@Tool
Thanks for the heads-up.
Here's a related question: does Polk have any of the the RTA-style connectors? The ones that look like thin-pinned 3-pin XLR's. I want to grab a few so that, later, I can build an AI-1 cable for my original SDA-1's.polkaudio Monitor 5 Series II
polkaudio SDA-1 (with the SL1000)
TEAC AG-H300 MK III stereo receiver
beyerdynamic DT-880 Premium (600 Ω) headphones
SENNHEISER HD-555 headphones
Little Dot MK IV tube headphone amp
Little Dot DAC_I balanced D/A converter -
Blade/blade terminals here, http://www.alliedelec.com/Search/ProductDetail.aspx?SKU=750-3200&SEARCH=P-302-CCT&ID=&DESC=P-302-CCT
You provide the cable.Political Correctness'.........defined
President of Club Polk -
You cannot use the AI-1 with your speakers. No way, no how.Political Correctness'.........defined
At all?
That lowers my choices for poweramp upgrades. I guess the McIntosh MC162's and some other older models are still in, but newer MC402's are out. polkaudio Monitor 5 Series II
>No<Political Correctness'.........defined
Fun. -_- Well, at least I know this now instead of a few months down. I was eying a pair of mono amps but that's not possible then.polkaudio Monitor 5 Series II
Thank you F1!!
Vette C6.r wrote: »
If my memory serves me right Polk charges $28.00 for the Blade/Blade cable.. It has been a year since I ordered one from them.. -
Thanks all, I just need the connector plug. My cable is pulled out, and the plug is falling apart. I will order the plug from Allied that F1 provided the link for.
Mike -
Double check the polarity on the cable pins with a VOM. IIRC, on the cable the large pin to large and small to small.>
