Source for blade/blade
falcon377
falcon377 Posts: 47
edited May 2010 in Vintage Speakers
Hi, I recently acquired a pair of the original SDA-CRS with the blade-blade connectors on the sda cable, one is falling apart. Just wandering if anyone knows a source for these.
______
Mike
Post edited by falcon377 on
  • Schurkey
    Schurkey Posts: 2,104
    edited May 2010
    I don't think Polk has any blade/blade cables to sell. Might find 'em on eBay; and it seems to me that Ben makes cables.
    Wouldn't be hard; worst part would be finding the actual cable ends. If you converted your speaker's SDA connectors to binding posts, all you'd need for the cables is four banana plugs and two lengths of speaker wire; and the materials (solder, heat shrink tubing, etc.) to hold it all together.
    Toolfan66 Posts: 17,336
    edited May 2010
    Call Polk they will hook you up with a blade/blade cable. They do not have the pin/blade cable.
    Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
    SVS SB16 X2
    Cary SLP-05/Ultimate Upgrade.
    Cary SA-500.1 ES Amps
    Cary DMS 800PV Network
    Jolida JD9 Fully Modified
    VPI MW-1 Cyclone RCM
    MIT Shotgun 3 cables throughout / Except TT, and PC’s
  • Bobsama
    Bobsama Posts: 526
    edited May 2010
    @Tool
    Thanks for the heads-up.
    Here's a related question: does Polk have any of the the RTA-style connectors? The ones that look like thin-pinned 3-pin XLR's. I want to grab a few so that, later, I can build an AI-1 cable for my original SDA-1's.
    polkaudio Monitor 5 Series II
    polkaudio SDA-1 (with the SL1000)
    TEAC AG-H300 MK III stereo receiver
    beyerdynamic DT-880 Premium (600 Ω) headphones
    SENNHEISER HD-555 headphones
    Little Dot MK IV tube headphone amp
    Little Dot DAC_I balanced D/A converter
    F1nut Posts: 50,755
    edited May 2010
    F1nut Posts: 50,755
    edited May 2010
    Bobsama wrote: »
    You cannot use the AI-1 with your speakers. No way, no how.
  • Bobsama
    Bobsama Posts: 526
    edited May 2010
    At all? :( That lowers my choices for poweramp upgrades. I guess the McIntosh MC162's and some other older models are still in, but newer MC402's are out.
    F1nut Posts: 50,755
    edited May 2010
    >No<
  • Bobsama
    Bobsama Posts: 526
    edited May 2010
    Fun. -_- Well, at least I know this now instead of a few months down. I was eying a pair of mono amps but that's not possible then.
  • falcon377
    falcon377 Posts: 47
    edited May 2010
    Thank you F1!!
    edited May 2010
    Vette C6.r wrote: »
    If my memory serves me right Polk charges $28.00 for the Blade/Blade cable.. It has been a year since I ordered one from them..
    SVS SB16 X2
  • falcon377
    falcon377 Posts: 47
    edited May 2010
    Thanks all, I just need the connector plug. My cable is pulled out, and the plug is falling apart. I will order the plug from Allied that F1 provided the link for.
    Mike
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited May 2010
    Double check the polarity on the cable pins with a VOM. IIRC, on the cable the large pin to large and small to small.
