need to run some speaker cable outside...suggestions?
tonyr1
I need to run some speaker wires from my garage to a gazebo about 30 feet away. The speakers are just a small pair of Yamaha outdoor speakers. I know from reading on here a little that using extension cord or something like that is a no-no, but I need a quick and easy and cheap fix.
So would 12 or 14 ga stranded copper work for a cheap weatherproof wire?
P.S. I just put on my asbestos coat so flame away if you must! LOL:D
I used monoprice 14ga several years ago outside, still sounds great. I treated the ends with deoxit....no problems.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
ok, I have some deoxit.
run your wire through some PVC. Glue together some PVC and bury it water worries no more.
I used this direct burial speaker wire for my outdoor system.
http://www.outdoorspeakerdepot.com/outdoor-speaker-wire-cable.htmlIf you can't hear a difference, don't waste your money. -
wow, that stuff looks good! but I was in a rush....bought some 14/2 FT4 from HD . that will have to do for now. thanks guys:)
