Upgraded to rti28/csi30
kirk2236
kirk2236 Posts: 2
A question from someone who knows just enough to be dangerous..... I recently upgraded my RM6600 / PSW350 / Yahama 5240 system with the following speakers...... csi30 center, rti28's main, r15 surrounds, psw350 sub. I set up the csi30 as "large", the rti28's as "small", the r15's as "small" and utized a LFE cable instead of "the Polk way", the cross over is set at 100, output set to "both", and I've moved the sub into a corner. The sound is much improved, but I wonder if I've taken the right approach. Which sub connection set up would you recommend? What speaker set up (small/large) will give me the cleanest bass and fullest range. Any other feedback would be appreciated.
Post edited by kirk2236 on
  • fireshoes
    fireshoes Posts: 3,167
    edited November 2003
    I would try switching the CSi30 to small and setting your x-over to 80 hz instead of 100.
  • Tour2ma
    Tour2ma Posts: 10,177
    i 2nd fs's suggestion...
    if this is referring to lfe output, try it to sub only...
    More later,
    Tour...
    Vox Copuli
  • Fireman99
    Fireman99 Posts: 129
    Going to say the same set all speakers to small and x-over to 80 and start from there.
    Dan
    Recever AVR 8000
    Amp PA 4000
    CDR 26
    Mains RTI 150 Bi wired
    Center CSI 40 Bi wired
    Surround FXI 30
    Rear RTI 4
    Sub PSW 140
  • nebborjk
    nebborjk Posts: 425
    Let us know if this set-up sounds better than the RM6600 system (I'm sure it probably does) I have a RM6700/PSW202 set-up and was thinking about making a similar upgrade.
    Proud SOPA Member since 2005!
  • jdhdiggs
    jdhdiggs Posts: 4,305
    With those speakers, I would almost keep the corssover at 100 with all speakers set to small. You might pick up some directional base from the sub but those smaller speakers would be cleared of their higher power (Lower freq) duties.
    Try both crossover settings (Assuming this is on your AVR) If the crossover setting is on the back of your sub, set it as high as possible to keep from doubling the crossover from your AVR.
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
  • kirk2236
    kirk2236 Posts: 2
    Thanks for all the advice! I set all speakers to "small". switch the sub out put to sub only, set cross over to 80. It sounded OK. Next I used the AVIA set up disc (got it back from a friend)with a sound level meter. WOW! I never would have believed the results, nor would I have made the adjustments on my own. I moved the cross over to 100, made slight volume adjustments up to center and surrounds. Then (totally unexpected), I ended up turning down the sub volume in the reciever as well as somewhat on the sub. The results were that "everthing" tested out in the 80 85 db level. When I tried it out on selected scenes in"Lord of the Rings" and "Matrix", I heard a much fuller range of sounds and no bass distortion at high volumes. In response to the upgrade question on the RM6700, I would say that the new set up is significantly better (sounds GREAT!). When I used the AVIA disc with my RM 6600 I had a "mid range hole" detected on some of the test. I fully realize that my upgrade pales in comparison to other systems I've read about in this forum, but for the budget I had approved from the commander, and the size of my room, it's a great improvement! Thanks again for all the help!
  • Tour2ma
    glad you and "the commander" both like the results...
    More later,
    Tour...
    Vox Copuli
  • Fireman99
    Glad to hear things are in working order!
    Crank it up and enjoy
    Dan
    Recever AVR 8000
    Amp PA 4000
    CDR 26
    Surround FXI 30
    Rear RTI 4
    Sub PSW 140
