Considering a new amp, how many watts?
2
    nooshinjohn Posts: 26,002
    edited May 2010
    kex wrote: »
    mr. Pan, i would recommend medical assistance in your case. I've heard recently that they can no longer refuse you treatment for pre-existing conditions.
    lol!! :D:D:D:D
  • hearingimpared
    hearingimpared Posts: 21,136
    edited May 2010
    I don't need no stinken smoke to get crazy.
    True Kex, but all I can do is put it out there, maybe a few will suck it up, but evetually the worm turns and the issues mentioned will present. There are no gimmicks in hi-fi.
    RT1
    When I get confused by your muse BB, I just pull out my trusty ole official, endorsed by the master, RT1 decoder ring and all is well!:D
  • FTGV
    FTGV Posts: 3,650
    edited May 2010
    second word of the day is "clipping" which is what happens to the transients if you do not have enough...
    But how iz I knowed if my amp are clipping?:confused:
  • cstmar01
    cstmar01 Posts: 4,424
    edited May 2010
    FTGV wrote: »
    your amp will burst into flames and burn your house down.
  • yepimonfire
    yepimonfire Posts: 256
    edited May 2010
    nduitch wrote: »
    I measured the input at the speaker terminals and my average listening level uses 1.7 watts, I couldn't believe it. The 1a's say something like 25-500 watts. I can't even imagine how loud it would be with 100 watts, let alone 500. Why is this much power needed?
    i bet the amp will peak around 75 watts every time the kick drum is hit. power output with music is very random and can go from 1w to 100w and anything in between on just a second or two of music. unless you listen to raw sine waves your never going to be using the same power all the time, but trust me, that 100watts does get used.
  • yepimonfire
    edited May 2010
    As long as it's a quality amp the more power usually results in a cleaner more refined sound from what i have heard. Also your bass will fill out and go much lower.
    this is because low frequency reproduction require anywhere from 3-10x the power of mid/highs because the cone must move much further in and out to correctly produce the long waveforms. if your amp cant put out what it needs on bass peaks such as kick drum kicks, you just simply wont have the long extension needed, capping your response from anywhere from 50-100hz.
    Yeah I had a sony bookshelf that stated it was 2200 watts of power...yep it sounds like crap and doesn't touch how loud and clear my monitor 50s sound on just a mere 50 watts....
    I cannot wait till my HK arrives on my door step....120 watts of clean high current power here i come!
    Yeah....most times watts are just head room... I know the monitor 50s are rated for 150 watts....but probably could take 200 or so if the watts were clean and had little distortion just fine.
    I know I have subwoofers in my car and they said only 350 watts each...but I power them with a class A rockford fosgate amp at 500 watts each and they sound just fine with absolutely no distortion at high volumes... now, I am sure if I had a class D amp...with 150...it would clip and my subs would be ruined eventhough my subs said they could handle 350...
    Kinda get it?
    exactly, power ratings on speakers really are useless, i ruined a pair of 100w rms bookshelfs by using a 13w boombox amp, on the other hand i have in the past for many hours at a time driven 50w MAX bookshelfs on a 130wpc amp full blast with no problems.
  • jrgoswick
    jrgoswick Posts: 159
    edited May 2010
    In ALL of these posts, I've YET to see ANYONE mention OHMS law!
    For BASIC reasons we shall start here: I=V/R. For those whom aren't familiar with this nomenclature, let me explain:I is current in amperes, V is voltage in(duh) volts, and R is resistance in ohms. For a BASIC power formula, P=V*I, OR power in watts equals voltage multiplied by current.
    This is where it gets tricky. Impedance(which most driver arrays are measured in) is ALSO in OHMS of resistance. HOWEVER this value changes with frequency, SO most manufacturers AVERAGE this value within the prime audible spectrum. Also if I'm not mistaken, decibels(dB) are an exponential function(ie if 80dB takes 10 watts, 81 takes 100, 82 takes 1000 and so forth).
    NOW with this being said, the amount of power you need depends on how deep your wallet really is. Amplifiers are power supplies. If it claims 1200 watts and the sticker says it pulls 600-CALL BS!!!!!! Nothing is free.
    ANOTHER NOTE-IF ANY OF THIS IS INCORRECT POINT IT OUT PLEASE. No information is ALWAYS better than bad information.
    And that's my 2 cents. Sorry to rant.
    Onkyo TX-SR705 AVR
    Onkyo M-501-Given to my father.
    Onkyo DX-C730 CD Changer
    Onkyo DV-BD507 Blu Ray player
    Onkyo CP-1036A turntable with Grado, Audio Technique, and Azden cartridges(GOT CARTRIDGE??)
    Polk Monitor 12's with RDO's and XO's
    Polk CS300 Center
    Polk Monitor Series 4 rears
    EBAY is like cocaine. At first you only look, next thing you know, your house is full of crap you have no idea why you own.:eek:
  • yepimonfire
    edited May 2010
    thats also a good thing to mention, when looking at amps, i disregard the power claims unless it is a marantz because almost all their models have benched at the claims at all channels driven, and look at the power consumption stickers.
    btw your signature is hilarious, i loled for 5 minutes over that because i can relate.
  • yepimonfire
    edited May 2010
    oh and ohms ratings arent always correct either, the resistance of a driver array can vary for numerous reasons, for instance, you run your speakers at full power gain (0db on db rated volume controls) the resistance will go up and the volume will go down because the voice coil heats up, it also depends on the frequency, resistance goes way down on lower frequencies. this is why bass draws more current.
  • hearingimpared
    edited May 2010
    FTGV wrote: »
    Thur b peeses of paper al on de flo.
  • hearingimpared
    edited May 2010
    jrgoswick wrote: »
    Why, thank you sir for the lesson. Although I must say, you've made a simple amp/wattage/speaker setup complicated.:D
  • jrgoswick
    edited May 2010
    I forgot to mention I^2R losses in that rant, but you be correct! Sort of-impedance changes with frequency, the DCR(direct current resistance) of the drivers coil doesn't(as far as I know), however, music is a VERY complex AC wave. And yes, lower frequencies are CURRENT HOGS!!!
    Yeah, I EFFING HATE EBAY(be there next). Good thing I don't spend a lot of time online anymore, my wife would KILL ME!
    Onkyo TX-SR705 AVR
    Polk CS300 Center
  • tcrossma
    tcrossma Posts: 1,301
    edited May 2010
    jrgoswick wrote: »
    I'm no expert, so I could be completely off base, but because capacitors store power wouldn't it be perfectly plausible that an amp could dole out short bursts of more power than it draws? It's not free, it's just stored for when it needs it...?
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • yepimonfire
    edited May 2010
    yes this is called PMPO but it can only be sustained for fractions of a second, this is why your piece of **** boomboxes have ratings like "400watts" the PMPO of a real amp that can comfortably give 100wpc could reach into the thousands.
  • yepimonfire
    edited May 2010
    basically the 100w RMS rating on your amp mean that if you play a 1khz sine wave with the volume turned to 0Db on digital volume controls or around 1/2 way up on analog ones you will be drawing 100w of constant power. PMPO would be drawn whenever you have the volume control set to 0Db and someone hits a kick drum its going to go past the RMS rating anywhere from 10-100w, but the amp can only sustain that for one single kick, or in movies, a gunshot would use PMPO
    PMPO drains the reserves power faster then then transformer can draw it from the wall and refill it, once the reserves are drained, you get clipping until they refill.
  • phuz
    phuz Posts: 2,372
    edited May 2010
    jrgoswick wrote: »
    Actually, you double the power for every 3db. Using the LSi9 with it's 88db at 1m with 1 watt rating as an example, it would go something like this:
    88db 1 watt
    91db 2 watts
    94db 4 watts
    97db 8 watts
    100db 16 watts
    103db 32 watts
    106db 64 watts
    109db 128 watts
    112db 256 watts
    115db 512 watts
    And so on...
  • Litz
    Litz Posts: 111
    edited May 2010
    I am surprised to see no one mention Transfer function!
    Some amps are incompetant at delivering rated power. Some of the Kenwood products and even the massive Rotel (380 wpc) are guilty of this.
    A well designed amp (Like Myriad, outlaw, Mccormack DNA, Bryston etc) will sound better, with superior bass grip because they have the ability to push current properly. For example, it was appearent to me on some Dynaudio and B&W florstanders that a 225 wpc rated Bryston just clobbers the 380 wpc rated Rotel. Designs make a difference.
  • yepimonfire
    edited May 2010
    http://www.integratedaudio.com/help/sensitivity.pdf
    once again this is referring to a 1khz sine wave, technically 87db which is a common sensitivity rating and a common listening level, can be acheived with 1w, in reality this has nothing to do with power consumption because you arent going to be able to playback a full range complex musical signal at 87db with 1w, not correctly atleast. sensitivity ratings only are a guideline as to how loud your speaker is in comparison to this one.
  • yepimonfire
    edited May 2010
    Litz wrote: »
    i have a kenwood amp and it is a piece of garbage and sounds only slightly better then a boombox amp.
  • Litz
    Litz Posts: 111
    edited May 2010
    True story: Kenwood M-2 basic. rated 200 wpc. Delivery: 1/3 rated power into 8 ohms!
    gah!
  • yepimonfire
    edited May 2010
    tubes have alot of headroom and clip softer then SS amps
  • jrgoswick
    edited May 2010
    phuz wrote: »
    THIS IS GOOD! Wasn't sure about that one being right, was kinda in the stands at the game though.
    Onkyo TX-SR705 AVR
    Polk CS300 Center
  • yepimonfire
    edited May 2010
    unless you want to buy large PA speakers capable of handling thousands of watts, buying higher wattage amps is not really going to increase volume, but dynamics, accurate low end reproduction, and overall cleanness of the sound. the most gain you can get from standard 87db speakers before they go out is a max SPL of 115db.
  • sucks2beme
    sucks2beme Posts: 5,691
    edited May 2010
    Bottom line, a quality amp of 100-200 WPC will get it done pretty well.
    Most 2 channel home amp's ratings are fairly honest due to government
    requirements. It's multi-channel that's BS. The ratings standards haven't
    been updated to cover them. Better brands are rated well, but there are tons
    of "mass market" HT receivers from those big electronics stores that don't
    begin to truly put out 100 wpc all channels driven. And not all amps
    sound the same. Some are smooth, harsh, warm, bright, etc.
    Some yahoo came here a couple of years ago with a claim that all
    properly designed amps sound the same. Biggest pile I ever heard.
    I seldom have heard any two amps sound the same.
  • Litz
    Litz Posts: 111
    edited May 2010
    sucks2beme wrote: »
    IIRC there were plenty of recievers that were rated as high as 170 wpc/5 channel...but there was always an asterisk. Either the TRUE rating was posted much lower in the fine print, measured deceptively (not 20hz-20khz but 1khz tone) or these receivers would test for a fraction of the output. I refuse to buy any product from a company that would have a deceptive practice like that.
  • cfrizz
    cfrizz Posts: 13,415
    edited May 2010
    Litz wrote: »
    :D Well that takes out almost every receiver on the market!:eek::D
    Hence my preference for seperates.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited May 2010
    FTGV wrote: »
    you will see fine hairs on the floor.
    RT1
    heiney9 Posts: 25,508
    edited May 2010
    Lasareath wrote: »
    As much as you can afford!
    But I could buy $5000 30wpc amp or a $5000 200wpc amp so affordability really isn't an indicator. Of th two I'm thinking of I'd choose the 30wpc amp
    To the OP, there is no one single criteria. All the suggestions are valid somewhere along the line. It takes some education and experience to come to the answer for your situation. That education and experience has to come from you.
    Look at well regarded names of products and evaluate your listening habits, other associated gear, budget, types of amp, etc, etc........and choose. The in a few months if you are still into the hobby move on to something else, etc., etc.
  • madmax
    madmax Posts: 12,434
    edited May 2010
    RT1
    Or, you could set the amp next to the bushes.
    Vinyl, the final frontier...
  • sucks2beme
    edited May 2010
    Litz wrote: »
    Wow. Short lived member. Not even here a week!
