Anyone like their Preamp?
thor098
thor098 Posts: 38
edited May 2010 in 2 Channel Audio
Any suggestions for a good 2 channel preamp to go with an adcom 545 amp that I just picked up?
2 CH
Parasound 2100 preamp
Polk Lsi15s
powered by a
Parasound HCA 1500a
2 Passive JBL 10" Subs
powered by a second
Parasound HCA 1500a
HT
Denon 3311-CI
Polk Lsi15 Fronts
Polk LsiC Center
Polk Lsi7 Surrounds
2 Passive Polk 10" Subs
powered by ADCOM 545
Post edited by thor098 on
  • thsmith
    thsmith Posts: 6,082
    edited May 2010
    I am happy with my Wright WLA12A and Anthem Pre 2L and have been happy with Adcom GFP-750 and Anthem Pre 1L.
    Whats your budget and preference tube vs ss?
  • ben62670
    ben62670 Posts: 15,969
    edited May 2010
    I am using a Grounded Grid Pre I built with the 545. Love it. What is your budget? What speakers are you driving?
    Welcome to club Polk
    Ben
  • thor098
    thor098 Posts: 38
    edited May 2010
    The speakers are SDA-2's. I currently am using my Marantz 2270 as the preamp.
    2 CH
    Polk Lsi15s
    powered by a
    Parasound HCA 1500a
    powered by a second
    Parasound HCA 1500a
    HT
    Denon 3311-CI
    Polk Lsi15 Fronts
    Polk LsiC Center
    Polk Lsi7 Surrounds
  • dkg999
    dkg999 Posts: 5,647
    edited May 2010
    Lots of pre amps are going to sound good with the 545. Can you tell us more about what you want to spend, do you need HT bypass, what speakers, etc?
    DKG999
  • thor098
    thor098 Posts: 38
    edited May 2010
    The budget? Maybe up to $600. I really don't understand what makes a good preamp yet and what I'd be paying for. Its a new area for me.
    2 CH
    Polk Lsi15s
    powered by a
    Parasound HCA 1500a
    powered by a second
    Parasound HCA 1500a
    HT
    Denon 3311-CI
    Polk Lsi15 Fronts
    Polk LsiC Center
    Polk Lsi7 Surrounds
  • thsmith
    edited May 2010
    At $600 there are several great choices, with and without HT bypass or remote. Pretty wide open in that range.
    Tube or SS ?
    If you look hard the GFP-750 can be found if SS is your thing. If tube is what you want the Anthems I mentioned, the Wright if you can find one and host of other tube pre's.
    But you do need to figure out what features and sound you are looking for. Is balance control required, remote, HT bypass, IEC for power, input types (RCA and or XLR), color, on and on.
  • thor098
    thor098 Posts: 38
    edited May 2010
    Well, I'm off to bed. Thanks for the info so far and I look forward to more. What kind of specs do I even look for?
    2 CH
    Polk Lsi15s
    powered by a
    Parasound HCA 1500a
    powered by a second
    Parasound HCA 1500a
    HT
    Denon 3311-CI
    Polk Lsi15 Fronts
    Polk LsiC Center
    Polk Lsi7 Surrounds
  • thor098
    thor098 Posts: 38
    edited May 2010
    I'm strictly looking for SS.
    2 CH
    Polk Lsi15s
    powered by a
    Parasound HCA 1500a
    powered by a second
    Parasound HCA 1500a
    HT
    Denon 3311-CI
    Polk Lsi15 Fronts
    Polk LsiC Center
    Polk Lsi7 Surrounds
  • thsmith
    edited May 2010
    I think the Adcom 750 will get a lot of votes then. Nice thing is you want have to buy tubes to roll and go broke;)
  • concealer404
    concealer404 Posts: 7,440
    edited May 2010
    I like my B&K.
  • cstmar01
    cstmar01 Posts: 4,424
    edited May 2010
    I like both the SEP-1 and the Parasound 2100. Concealer404's B&K is very nice as well.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited May 2010
    I like my preamp, sometimes I sleep with it................sometimes I have to move afterwards to avoid the preamp police, those guys are pretty quick.
    RT1
  • hearingimpared
    hearingimpared Posts: 21,136
    edited May 2010
    All solid state huh! Look for a used Spectral DMC 10x. They are hard to come by used and will cost you a bit more than $600 but it will blow you away. However, it has only three inputs, phono, aux (for digital) and a tape loop which you can use for any line level device. BTW that phono stage is still one of the best ever made.
    heiney9 Posts: 25,417
    edited May 2010
    Adcom GFP-750 is an excellent piece. HT bypass, Nelson Pass design, built like a brick **** house. Passive mode, remote, switching relays rather than I/C's, simple signal paths, dead neutral, balanced in's and out's, 12V trigger.............did I mention a Nelson Pass design
  • Fongolio
    Fongolio Posts: 3,516
    edited May 2010
    I have an inappropriate relationship with my Carver C-1. It's geriatric but I love it none the less.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • steveinaz
    steveinaz Posts: 19,545
    edited May 2010
    Love mine, but it's a touch beyond $600. How about a new Creek passive for $499? See audioadvisor, REMOTE too!
    http://www.audioadvisor.com/prodinfo.asp?number=CKOBH22
    edited May 2010
    Since the OP is a little "green" with audio gear and separates I'd caution him against his 1st pre-amp being a passive unit. Passive units need to be carefully matched and not all people appreciate a passive pre-amp's sound.
  • steveinaz
    edited May 2010
    He's driving a CD player---plenty of output. His amp and CDP both lean to the warm side of neutral, the Creek (IMO) would be a good "balancing" move. Just my 2 cents.
    edited May 2010
    I still think he should approach with caution as many people prefer an active pre over a passive pre. If he can afford to experiment with both at the same time that would be best. This being his 1st forray into separates, a passive pre would be low on the list.
    IMHO.
  • Timothy Smith
    Timothy Smith Posts: 764
    edited May 2010
    I went through a lot of different preamps (Adcom, NAD, Dynaco, HK Citation, Advent, Marantz etc.) and eventually ended up with a Forte Model 45.
    I belive that Forte was John Curl's entry level brand to go with Threshold.
    I love this thing, it matches well with any SS or tube amp I pair it with.
    I previously thought that preamps all sounded about the same and that it was not a critical component. It made a big difference in improved detail and still manages to sound effortless and "musical". It also has pretty good gain (some of my previous preamps had feeble outputs) so it works well with lower power amps and inefficient speakers
    It also has a remote control which is nice for the lazy man.
    New it was something like $1300, but can be bought used for about $300 (what I paid) if you are patient.
    I hope it never breaks because I don't even want to think about replacing it.
    Norh ACA-2B tube pre, Sumo Andromeda SS amp. Magneplanar MMG speakers, M&K MX1250 Subwoofer, Pro-Ject RM1.3 Genie TT with Sumiko Pearl MM cart., Keces DAC, Cambridge Audio Azur 640c CD player
    edited May 2010
    It was Nelson Pass not John Curl. And Forte is very solid gear and the less costlier alternative to Threshold. I was looking at a Forte amp before buying my Aleph 30.
  • reeltrouble1
    edited May 2010
    heiney9 wrote: »
    waaaaaaaaaaaaa gee I never would of guessed!!!!!
    RT1
  • Willow
    Willow Posts: 11,220
    edited May 2010
    I like my pre-amp, it's not fancy but it does the trick. Mind you this is my first actual pre. And I have nothign else to compare it to.
  • steveinaz
    edited May 2010
    RT1
    hehe...:D
    edited May 2010
    :D:p;):)
  • Timothy Smith
    edited May 2010
    heiney9 wrote: »
    Heiney9: Thanks for the correction. Sometimes I get those two guys mixed up. At least I didn't say Dr. Omar Bose or Professor Sparkomatic.
  • reeltrouble1
    edited May 2010
    H9 is actually the wayward lovechild born of a menage-a-trois involving Pass, Twiggy, Tiny Tim and several bottles of Ripple.
    RT1
    edited May 2010
    RT1
    I thought that was our little secret ;)
  • zingo
    zingo Posts: 11,258
    edited May 2010
    I've used the Luminous Audio Axiom passive preamp with multiple rigs and it sounded great every time; even at our Seattle Fest. Plus it's real cheap and customized to your amp and speakers. :D
  • lanchile
    lanchile Posts: 560
    edited May 2010
    I wish I could suggest one, but I do not know any.
    I build my diy integrated amp using just a potentiometer in the input signal. There are many integrated amps using this topology getting excellent results.
    just to mention one is the Portal Panache integrated amp.
    Make it simple...Make it better!
