Anyone like their Preamp?
thor098
Any suggestions for a good 2 channel preamp to go with an adcom 545 amp that I just picked up?
2 CH
Parasound 2100 preamp
Polk Lsi15s
powered by a
Parasound HCA 1500a
2 Passive JBL 10" Subs
powered by a second
Parasound HCA 1500a
HT
Denon 3311-CI
Polk Lsi15 Fronts
Polk LsiC Center
Polk Lsi7 Surrounds
2 Passive Polk 10" Subs
powered by ADCOM 545
Polk Lsi15s
powered by a
Parasound HCA 1500a
powered by a second
Parasound HCA 1500a
HT
Denon 3311-CI
Polk Lsi15 Fronts
Polk LsiC Center
Polk Lsi7 Surrounds
Post edited by thor098 on
I am happy with my Wright WLA12A and Anthem Pre 2L and have been happy with Adcom GFP-750 and Anthem Pre 1L.
Whats your budget and preference tube vs ss?Speakers: SDA-1C (most all the goodies)
I am using a Grounded Grid Pre I built with the 545. Love it. What is your budget? What speakers are you driving?
Welcome to club PolkPlease. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
The speakers are SDA-2's. I currently am using my Marantz 2270 as the preamp.2 CH
Polk Lsi15s
powered by a
Parasound HCA 1500a
powered by a second
Parasound HCA 1500a
HT
Denon 3311-CI
Polk Lsi15 Fronts
Polk LsiC Center
Polk Lsi7 Surrounds
powered by ADCOM 545 -
Lots of pre amps are going to sound good with the 545. Can you tell us more about what you want to spend, do you need HT bypass, what speakers, etc?DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
The budget? Maybe up to $600. I really don't understand what makes a good preamp yet and what I'd be paying for. Its a new area for me.2 CH
Polk Lsi15s
powered by a
Parasound HCA 1500a
powered by a second
Parasound HCA 1500a
HT
Denon 3311-CI
Polk Lsi15 Fronts
Polk LsiC Center
Polk Lsi7 Surrounds
At $600 there are several great choices, with and without HT bypass or remote. Pretty wide open in that range.
Tube or SS ?
If you look hard the GFP-750 can be found if SS is your thing. If tube is what you want the Anthems I mentioned, the Wright if you can find one and host of other tube pre's.
But you do need to figure out what features and sound you are looking for. Is balance control required, remote, HT bypass, IEC for power, input types (RCA and or XLR), color, on and on.Speakers: SDA-1C (most all the goodies)
Well, I'm off to bed. Thanks for the info so far and I look forward to more. What kind of specs do I even look for?2 CH
Polk Lsi15s
powered by a
Parasound HCA 1500a
powered by a second
Parasound HCA 1500a
HT
Denon 3311-CI
Polk Lsi15 Fronts
Polk LsiC Center
Polk Lsi7 Surrounds
I'm strictly looking for SS.2 CH
Polk Lsi15s
powered by a
Parasound HCA 1500a
powered by a second
Parasound HCA 1500a
HT
Denon 3311-CI
Polk Lsi15 Fronts
Polk LsiC Center
Polk Lsi7 Surrounds
I think the Adcom 750 will get a lot of votes then. Nice thing is you want have to buy tubes to roll and go broke;)Speakers: SDA-1C (most all the goodies)
I like my B&K.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
I like both the SEP-1 and the Parasound 2100. Concealer404's B&K is very nice as well.
I like my preamp, sometimes I sleep with it................sometimes I have to move afterwards to avoid the preamp police, those guys are pretty quick.
RT1 -
All solid state huh! Look for a used Spectral DMC 10x. They are hard to come by used and will cost you a bit more than $600 but it will blow you away. However, it has only three inputs, phono, aux (for digital) and a tape loop which you can use for any line level device. BTW that phono stage is still one of the best ever made.
Adcom GFP-750 is an excellent piece. HT bypass, Nelson Pass design, built like a brick **** house. Passive mode, remote, switching relays rather than I/C's, simple signal paths, dead neutral, balanced in's and out's, 12V trigger.............did I mention a Nelson Pass design
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | BlueSound Node3 - Tubes add soul! -
I have an inappropriate relationship with my Carver C-1. It's geriatric but I love it none the less.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
Love mine, but it's a touch beyond $600. How about a new Creek passive for $499? See audioadvisor, REMOTE too!
http://www.audioadvisor.com/prodinfo.asp?number=CKOBH22Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2 -
Since the OP is a little "green" with audio gear and separates I'd caution him against his 1st pre-amp being a passive unit. Passive units need to be carefully matched and not all people appreciate a passive pre-amp's sound.
He's driving a CD player---plenty of output. His amp and CDP both lean to the warm side of neutral, the Creek (IMO) would be a good "balancing" move. Just my 2 cents.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
I still think he should approach with caution as many people prefer an active pre over a passive pre. If he can afford to experiment with both at the same time that would be best. This being his 1st forray into separates, a passive pre would be low on the list.
IMHO.
I went through a lot of different preamps (Adcom, NAD, Dynaco, HK Citation, Advent, Marantz etc.) and eventually ended up with a Forte Model 45.
I belive that Forte was John Curl's entry level brand to go with Threshold.
I love this thing, it matches well with any SS or tube amp I pair it with.
I previously thought that preamps all sounded about the same and that it was not a critical component. It made a big difference in improved detail and still manages to sound effortless and "musical". It also has pretty good gain (some of my previous preamps had feeble outputs) so it works well with lower power amps and inefficient speakers
It also has a remote control which is nice for the lazy man.
New it was something like $1300, but can be bought used for about $300 (what I paid) if you are patient.
I hope it never breaks because I don't even want to think about replacing it.Norh ACA-2B tube pre, Sumo Andromeda SS amp. Magneplanar MMG speakers, M&K MX1250 Subwoofer, Pro-Ject RM1.3 Genie TT with Sumiko Pearl MM cart., Keces DAC, Cambridge Audio Azur 640c CD player -
Timothy Smith wrote: »I went through a lot of different preamps (Adcom, NAD, Dynaco, HK Citation, Advent, Marantz etc.) and eventually ended up with a Forte Model 45.
It was Nelson Pass not John Curl. And Forte is very solid gear and the less costlier alternative to Threshold. I was looking at a Forte amp before buying my Aleph 30.
waaaaaaaaaaaaa gee I never would of guessed!!!!!
RT1 -
I like my pre-amp, it's not fancy but it does the trick. Mind you this is my first actual pre. And I have nothign else to compare it to.
reeltrouble1 wrote: »waaaaaaaaaaaaa gee I never would of guessed!!!!!
RT1
hehe...:DSource: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2 -
Heiney9: Thanks for the correction. Sometimes I get those two guys mixed up. At least I didn't say Dr. Omar Bose or Professor Sparkomatic.Norh ACA-2B tube pre, Sumo Andromeda SS amp. Magneplanar MMG speakers, M&K MX1250 Subwoofer, Pro-Ject RM1.3 Genie TT with Sumiko Pearl MM cart., Keces DAC, Cambridge Audio Azur 640c CD player -
H9 is actually the wayward lovechild born of a menage-a-trois involving Pass, Twiggy, Tiny Tim and several bottles of Ripple.
RT1 -
reeltrouble1 wrote: »H9 is actually the wayward lovechild born of a menage-a-trois involving Pass, Twiggy, Tiny Tim and several bottles of Ripple.
RT1
I thought that was our little secret"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | BlueSound Node3 - Tubes add soul! -
I've used the Luminous Audio Axiom passive preamp with multiple rigs and it sounded great every time; even at our Seattle Fest. Plus it's real cheap and customized to your amp and speakers.
I wish I could suggest one, but I do not know any.
I build my diy integrated amp using just a potentiometer in the input signal. There are many integrated amps using this topology getting excellent results.
just to mention one is the Portal Panache integrated amp.Make it simple...Make it better!
