SDAs unplugged
2
  • hearingimpared
    hearingimpared Posts: 21,136
    edited May 2010
    ben62670 wrote: »
    Running SDA's without the cable is like having sex with your sister. It is still sex, but it just ain't right.
    :eek::eek::eek::eek: I love you Bro, but YOU ain't right!!!:p:D
    heiney9 Posts: 25,432
    edited May 2010
    Yes, I was generalizing which I normally don;t like to do. My statement pertains to earlier SDA's rather than later. Later models and the big boys are more like you describe.
    http://www.polksda.com/sda1creview.shtml
    Refer to the above link pp 42, left and middle columns.
    P.s. The OP has 2B's which are "later" models. Earlier 2's and 1's are as I described, for confirmation see the above link.
  • hearingimpared
    edited May 2010
    heiney9 wrote: »
    I notice the opposite. Tonal balance seems off to me when running w/o the cable. Vocals are recessed, highs are muted and things seem to sound unnatural. Flat, dry, lifeless, uninspiring, flaccid, tepid, vapid, choked, constrained, etc.
    Without the SDA cable you have to toe in the speakers to get the right sound which btw with the pair of SDA/SRS I once owned was a real PITA.
    F1nut Posts: 51,778
    edited May 2010
    The SDA drivers work up to 1000Hz, with the cable disconnected they only work up to 100Hz, in concert with the stereo drivers. Therefore, H9 is correct in that you are losing some of the frequency range produced by the SDA drivers.
  • Schurkey
    Schurkey Posts: 2,122
    edited May 2010
    With specific regard to the 1Bs in the first post:
    The + terminal of the dimensional drivers gets EXACTLY the same signal from the crossover as the stereo drivers. Unlike some other SDA models, the dimensional + circuit is a carbon-copy of the Stereo circuit--same resistors, same inductors, same drivers, same cabinet volume. The only things that make the dimensional driver signal different from the stereo driver is that:
    1. The - side of the dimensional drivers has the SDA signal from the other channel; the SDA signal delivered to the crossover is a full-range, full-amplitude version of the opposite-channel signal. This full-range, full amplitude signal is then processed by going through ~185uf of capacitors before being routed to the ground side of the dimensional drivers, and
    2. There's a fairly huge inductor in the ground path of the dimensional drivers. This inductor is in the circuit whether or not the SDA cable is connected; disconnecting the cable doesn't disable the inductor.
    Depending on program material, there is nothing to prevent the dimensional driver from producing essentially the same frequency response as the stereo drivers--except the inductor in the ground path.
    I don't understand how pulling the SDA cable can cut the bandwidth of the dimensional drivers to 1/10 of what it is with the cable connected. Can you explain?
    To my ears, the 1Bs have similar (not identical) response whether or not the cable is connected. The cable dramatically expands the soundstage when connected; but not so much effect on the tonal characteristics. This assumes a true "common ground" amplifier; put some resistance between the negative terminals of the amp and the sound quality of the midrange/vocals will go straight to hell with the SDA cable connected. 20 ohms is unlistenable; I haven't experimented, but I'm going to guess that 10 ohms will be "bad" and 5 ohms is "noticeable". I don't know how little resistance between the negative terminals it takes to be "acceptable". With "0" ohms, having the SDA cable connected or disconnected makes little difference in the tonal balance.
    This then becomes my advice to the original poster: Measure your amp for resistance between the negative terminals. Maybe even build a jumper wire--it's cheap and easy--and see if that "fixes" your midrange issue. The jumper wire was nothing less than a miracle cure for my system!
    Other SDA models are sure to be different. (That's material for another entire thread that I don't have time to start right now--SDA signals are handled in several different ways; and I'm thinking that the "strength" or audibility of the SDA signal is bound to be different depending on the speaker model. So my thread topic will be: which model has the most obvious/strongest/"best" SDA effect???)
  • John in MA
    John in MA Posts: 1,010
    edited May 2010
    Yes, but at least in the later big boys their 100-1K range is the reversed-phase signal.
  • jrgoswick
    jrgoswick Posts: 159
    edited May 2010
    ben62670 wrote: »
    WTF MATE???????? That's just wrong. TRUE but ultimately wrong.
    Onkyo TX-SR705 AVR
    Onkyo M-501-Given to my father.
    Onkyo DX-C730 CD Changer
    Onkyo DV-BD507 Blu Ray player
    Onkyo CP-1036A turntable with Grado, Audio Technique, and Azden cartridges(GOT CARTRIDGE??)
    Polk Monitor 12's with RDO's and XO's
    Polk CS300 Center
    Polk Monitor Series 4 rears
    EBAY is like cocaine. At first you only look, next thing you know, your house is full of crap you have no idea why you own.:eek:
  • John in MA
    edited May 2010
    jrgoswick wrote: »
    Depends, are we talking step-sister, half-sister, or real sister?
  • hearingimpared
    edited May 2010
    John in MA wrote: »
    Who, how, when, how, where? . . . I don't know but your post has me cracking up. Sick pups!:p:D
    Ben you're still a perv for that one!:p:D
  • FTGV
    FTGV Posts: 3,650
    edited May 2010
    Schurkey wrote: »
    .... there is nothing to prevent the dimensional driver from producing essentially the same frequency response as the stereo drivers--except the inductor in the ground path...I don't understand how pulling the SDA cable can cut the bandwidth of the dimensional drivers to 1/10 of what it is with the cable connected. Can you explain?
    It appears that the signal from the stereo array(SA) is fed to the dimentional array(DA) through the big inductor.Therefore the signal sent to the DA will be low pass filtered so only the low bass will be shared between the SA and and DA sections.
  • hearingimpared
    edited May 2010
    Fred could you make that a little more clear, I'm finding it hard to understand for some reason? Thanks!
  • ben62670
    ben62670 Posts: 15,969
    edited May 2010
    The signal goes to ground through the big inductor to ground so the lower bass doesn't cancel. The signal doesn't pass through except to ground. The mids are what get canceled from about 80hz to 2k or 2.5k via the IC cable.
    Ben
  • FTGV
    FTGV Posts: 3,650
    edited May 2010
    The big coil only allows the low bass from the SA section to be sent to the DA section. Does that help Joe?
  • falconcry72
    falconcry72 Posts: 3,580
    edited May 2010
    I noticed on my 2B's (pin/blade) that when the interconnect is not connected they leak a significant amount of air out of the empty sockets when the passive is pressed in.
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited May 2010
    I was unplugging my IC the other day while a song was playing and I felt air blowing out of the pin IC receiver in the cabinet.
    For the record I always run with the interconnect connected but I just wanted to hear the difference because the sound stage was just so enveloping on that particular song and I just wanted to see how compressed it was without the interconnect connected.
    Scott
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • hearingimpared
    edited May 2010
    FTGV wrote: »
    ben62670 wrote: »
    FTGV wrote: »
    Gotcha, I read to much into the first post, thanks guys.
  • ben62670
    edited May 2010
    FTGV wrote: »
    The big coil lets the bass go to the amps ground. The higher frequencies are sent to the negative of the opposite channels negative canceling the mids in the dimensional array.
    Ben
  • FTGV
    FTGV Posts: 3,650
    edited May 2010
    ben62670 wrote: »
    Looking at the schematic for Shurkey's 1B's here's what I see.The DA and SA sections are essentially connected in parallel the only difference being there is a 9.6 mh coil in series with the negative leg of DA section so it will be only recieving low bass .Being that it's an AC signal the coil will function the same whether it be in the negative or positive side of the signal path. (With the IC disconnected the paralleled 50uf and 130uf caps are out of the circuit.)
    An easy test to see if the above is correct would be to try the 1B's
    sans IC and see if the DA section drivers are reproducing low bass only.
  • ben62670
    edited May 2010
    That coil is not in series with any driver on most SDA's. The Blade Blade it is in series in some speakers as in his 1B's.
    Ben
    edited May 2010
    I once asked Nelson Pass about my Aleph 30 and its compatibility with my 1C's. I sent him the schematics as well as a wiring diagram of the SDA 1C's. His response was that the Aleph 30 used a common ground but he mentioned it looked like the SDA's put stress on the negative side of an amplifier because of the interconnect. He also suggested a recommendation of a step down transformer for non-common ground amps like his X series and gave almost the exact spec of the AI-1. Reading between the lines; you need to have a stout amplifier to run the SDA's properly because it can stress the negative side of an amplifier.
  • bigaltx24
    bigaltx24 Posts: 141
    edited May 2010
    Thanks Schurkey, I knew I wasn't imagining this. I checked my amp, I'm getting .9 ohms between the grounds. I checked the MWs, without the cable all four seem to sound the same. I ran the SDA quick test and they passed with flying colors. Now back to some more A-B testing
    Denon PMA-900V
    Linn Axis with Grado Red
    Cambridge Azur 650C
    Polk SDA-1BTL
  • ben62670
    edited May 2010
    Sorry Fred I didn't realize you were talking about the 1B's.
    Ben
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited May 2010
    Running SDA's without the cable? I've tried it. No thanks.
    The magic disappears.
    As others have mentioned, these speakers are designed to be run WITH the cable in place. They don't simply function as a normal pair of speakers when the cable is unplugged. They work, yes...but they aren't really designed to be run that way.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • lightman1
    lightman1 Posts: 10,796
    edited May 2010
    dorokusai wrote: »
    I've been farther than you have...you can bet on that Russ.
    I know. It's just fun for me to get a rise from you.
    You still have bad ears.
    Say sumpin' chump!:D
  • lightman1
    edited May 2010
    I've just read a few of your other posts; when was the last time you had your mouth washed out with soap?
    SHUT UP RUSS!:eek::p:D
    I can use the F word any way I wish.
    except here....:rolleyes:
  • Schurkey
    edited May 2010
    FTGV wrote: »
    I agree with almost everything you state. The 9.6mh coil will NOT function the same if it were in the positive side of the circuit, because if it were in the positive side, the SDA signal coming from the other channel would go to ground without being blocked/filtered/modified by the inductor. Or, put another way, the inductor will function the same way, but it's in the wrong place with regard to the SDA signal. It's in the negative leg so that it filters/modifies the SUM of the "regular" signal delivered to the dimensional drivers and the SDA signal which is applied to the ground side of the drivers.
    I don't fully understand how the SDA signal travels through the wiring of the speaker; it seems to me that there's every likelyhood that it back-feeds through the drivers and crossover network as well as draining directly to ground through the big inductor. And, it doesn't help my understanding that the SDA signal is very changeable due to the program material. I know that if you disconnect the + speaker cable at ONE speaker, with the SDA cable connected, the speaker will still produce sound (program material dependent) at the tweeters due to the SDA signal back-feeding through the crossover. Spooky.
    I don't know what else to say except "Thank You". Every time I read about the SDA signal, I'm forced to re-examine what I know about it; and pretty much every time I learn something I didn't know before.
    bigaltx24 wrote: »
    Shove a jumper wire into the negative terminals, and see what happens. Worst case: you've wasted ~$5 on two Rat Shack banana plugs and a foot and a half of speaker wire.
    Gut feeling: add jumper wire; your midrange/vocal anomaly is g-o-n-e. But what do I know?
    edited May 2010
    Schurkey wrote: »
    Or he blows up his amp. Why are you insisting on him jumping his negative terminals on his amp? Do you have specific knowledge of his amp? I'm just curious, not being argumentative. Many non-common ground amps can NOT be jumpered or strapped without blowing up the amp. It seems his amp is common ground because of the the very low reading he has when measuring.
  • dorokusai
    dorokusai Posts: 25,576
    edited May 2010
    Heiney brings up a serious point....as you cannot just strap any amp and press play.
  • Schurkey
    edited May 2010
    dorokusai wrote: »
    bigaltx24 wrote: »
    If there's less than one ohm between negative posts already...
    ...how is a jumper wire going to hurt??? The negative posts are already electrically connected; just with a hint more loss than is optimum for the SDA signal.
    edited May 2010
    So you don't know anything about the design of the OP's amp? You are just "punting" in this case. I doubt getting rid of the .9 ohms is going to make any difference at all. I would ALWAYS check with the amp manufacturer before doing things like strapping the negative terminals. But that's just me.
