SDAs unplugged
bigaltx24
bigaltx24 Posts: 141
edited May 2010 in Vintage Speakers
I'd like to hear from SDA owners who don't use the interconnect cable. I've been running my 1Bs unplugged for about a month now. I like the SDA effect, but to my ears when I run unplugged the tonal balance is much better and vocals sound more natural. The difference is more noticeable when listening to vinyl than listening to CDs. Has anyone else noticed this?
Denon PMA-900V
Linn Axis with Grado Red
Cambridge Azur 650C
Polk SDA-1BTL
Post edited by bigaltx24 on
«13
  • wayne3burk
    wayne3burk Posts: 939
    edited May 2010
    hmmmm -- truth be told I'm listening to my Monitor 10s (peerless tweeters i think), and my SDA 1Cs are sitting in the closet, unused at the present time.
    I haven't tried the 1Cs without the interconnect cable, maybe I'll give that a try and see if you're right.
    -- wayne --
    Yamaha RX-V2700, EMI 711As (front), RCA K-16 (rear), Magnavox Console (Center & TV Stand), Sony SMP-N200 media streamer, Dual 1249 TT =--- Sharp Aquas 60" LCD tellie
  • dorokusai
    dorokusai Posts: 25,576
    edited May 2010
    You should buy another loudspeaker if you're not using the interconnect. They simply aren't working for you, perhaps something is wrong with them or its time to move on....that happens as well.
  • Bubinga99
    Bubinga99 Posts: 283
    edited May 2010
    One thing you might try is to make an SDA cable and run it back to your listening chair, with a switch on it so you can switch it in and out. Combined with the A/B repeat feature on most CD players, you can really hear even the very subtle cases, and I'll bet you decide to leave it attached.
    I did this, but with a fairly short wire between the speakers, with a wireless-activated realy to switch it in and out. That way, I could just push the keyfob to open/close the relay from my chair, as opposed to having wires stretched to the listening chair. But that method works too. The relay was also a good/quick way to demonstrate the SDA effect to others, especially with the right recording.
  • Conradicles
    Conradicles Posts: 6,343
    edited May 2010
    I enjoy listening to "Unplugged" music on my SDA's with the cable. Does that count hehe?
  • Bobsama
    Bobsama Posts: 526
    edited May 2010
    I haven't listened to my SDA-1's much without the SDA effect. I have heard, however, that the power handling capabilities are cut by 40-50% when you're not using the dimensional woofers(/tweeters).
    polkaudio Monitor 5 Series II
    polkaudio SDA-1 (with the SL1000)
    TEAC AG-H300 MK III stereo receiver
    beyerdynamic DT-880 Premium (600 Ω) headphones
    SENNHEISER HD-555 headphones
    Little Dot MK IV tube headphone amp
    Little Dot DAC_I balanced D/A converter
  • OldmanSRS
    OldmanSRS Posts: 419
    edited May 2010
    The SDA effect on music quality is very sensitive to listening position, and speaker placement. Maybe you should experiment some with both before making up your mind to go unplugged for good.
    '65 427 Shelby Cobra
    '72 Triumph TR-6
    __________________
    '88 Polk SDA SRS 1.2, with upgraded XO caps and Erse SDA inductors
    '86 Polk SDA CRS+
    '84 Polk Monitor 10A (Peerless tweeters)
    '05 HSU VTF-3 Sub (Original OEM)
    '20 HSU VTF-3 Sub (three more, 100% cloned)
    '93 Carver TFM-35
    '88 Carver M-1.0t
    '88 Adcom GFT-555
    '88 Adcom GFP-555
    '88 Adcom GFA-555 (upgraded/restored)
    '88 Adcom GFA-555 (a second one upgraded/restored)
    '05 Onkyo DV-555 media
    '89 Fosgate 360 Digital Space Matrix
    '89 Fosgate 360 Digital Space Matrix, internal surround amp bridged to drive only a center channel
    '91 Kenwood Basic M1D Amp
    '89 Pioneer Laser Disc media
    '89 Sony SuperBeta HiFi media
    One PGA2310 based custom built remote volume control
    Four Polk T-15's
    Four Polk TSi-200's
    Four Polk TSi-100's
    Two Polk CS-10's
  • hearingimpared
    hearingimpared Posts: 21,136
    edited May 2010
    When I bought my first SDA/SRSs in 1984/85 I had to use them for a while without the SDA cable because I had non-common ground amps. While they did sound good, there was no comparison with the SDA cables in use. They just were a completely different speaker.
    Are you sure there isn't something wrong with them? Have you upgraded the caps and resistors on the crossovers? You may find yourself liking them with the SDA effect if you do the upgrades.
  • John in MA
    John in MA Posts: 1,010
    edited May 2010
    SDAs are sensitive to placement. My temporary situation means having 1.2TLs in a room far too tight for them, and with the cable connected there's too much sound bouncing around. They work fine--in the original owner's huge room the SDA imaging was quite impressive.
  • Bobsama
    Bobsama Posts: 526
    edited May 2010
    John in MA wrote: »
    I've experienced that first-hand. 1.2TL's are NOT speakers for smaller rooms. Listened a few weeks later when they were swapped with CRS+'s, and the CRS+'s were not overpowering... though they did like to draw a good bit more more power than the 1.2TL's.
  • dorokusai
    edited May 2010
    I believe SDA loudspeakers are pretty forgiving in regards to the effect and room. I'd be surprised if any members have a perfect enviroment and the best SDA I've ever heard was far from perfect....and I've heard perfect. I's take a real world room over a typically over engineered room anyday. That's real grassroots Polk Audio to me.
    John - "sensitive to placement"...? Uhhh, maybe try a loudspeaker that is REALLY sensitive to placement sometime. I know you've been around the hobby....really?
  • John in MA
    edited May 2010
    Compared to your average speaker, I mean. Put a straight speaker in a corner or whatever and you're liable to just end up with goofy bass response or something. Put a large SDA in a corner and you have the mirror signal bouncing back at you, in addition to the typical placement issues. There's a reason Polk recommends certain setup details.
    In my case, nearly every dimension of the room is fouled up somehow and it often was like listening to a TV with one of those echo-y fake surround-sound settings. Nothing wrong with the speakers or the gear, just a really terrible room. Some new digs are the next system improvement I can make.
  • danger boy
    danger boy Posts: 15,722
    edited May 2010
    you can use your SDA's anyway you want.. with or without cable.. the SDA's are good speakers used either way... some people are chicken to try them without the interconnect cable.. thinking they won't like the sound field. :confused:
    i run mine about 60/40 60% with the cable. 40% without. both sound good to me. some music is to "hollow" with the SDA cable. some music that was recorded with a reverb can sound pretty bad with the SDA's using the interconnect. way hollow sounding.
    PolkFest 2012, who's going>?
  • John in MA
    edited May 2010
    When it's working, it's amazing. The guy I bought them from had them in a huge (like in front of a couch long enough for eight people) finished basement. I couldn't even tell where the speakers were from the sound.
  • hearingimpared
    edited May 2010
    I think SDA placement is a lot more cut and dry and easier for room placement than "regular" speakers. SDAs, all of them have the same minimum requirements. At least 3' from the sides walls, they can be closer but you loose some of the SDA effect. Minimum of 4' apart from center to center of each speaker, best if 6' to 8' apart, any closer than 4' the SDA effect again can be diminished. No toe in, they must be parallel to the back wall which is a cinch compared to having to figure out the proper toe in of "regular" speakers. Location from the back the wall will depend on the room, if they are too far from the back wall, you will loose bass response so you have to move them closer or further a bit at a time to get the proper bass response; 6" to 1.5' away is usually the distance inwhich you will find your best bass response again depending on the room. The sweet spot is usually started at exactly the same distance from the middle of the center plane of the baffles that the distance the speaker are apart. The last consideration is they need to be level, front to rear & side to side. This is easily accomplished by placing a level on top of the speaker, first front to rear then across side to side.
    That's it!
    My room is far from perfect and not very big i.e., 19' X 11' 2" but is a perfect rectangle and my bigass 1.2TLs sound fine and not overpowering in this room. I have them set up 5.5' from the sides walls, 6' 8" apart, and 8" from the back wall. My sweet spot starts exactly at 6' 8" from the center plane of the baffles and in my room can go back as far as 8'. They were very easy to setup and really all I had to do to get them equidistance from the side walls and how far apart was measure the width of the speakers. They are perfectly level and I have spike on those heavy boys and they were not hard to get level. I have a large overstuffed couch up against the back wall which is made to accomodate three people but can easily seat five. I have the center of the couch lined up with the sweet spot.
    Every other "regular" speaker or monitor I've ever had were a pain in the **** to set up. You had to guess how far from the back wall they are which could be 6' or more. The distance between the two speakers again took a guess to get them to sound right. Same thing with the distance from the side walls. The biggest PITA was the toe in. Should they be aimed right on axis aimed at your ears for the sweet spot or of axis, slightly past your ears and where the hell is the sweet spot? Another setup necessity, especially with monitors is, how high the tweeters are from the floor, do they need to be the same height as your ears, do they need to be tilted back and how many degrees do they need to be tilted back? Some require them to be tilted forward.
    IMHO "regular" speakers are much more difficult to set up and take much, much more time to set them up than SDAs. Of course there are guidelines and different forumlas put out by speaker manufactuers as well as other expert opinions on how to set up speakers but there is no cut and dry measurements for these type speakers.
    If you have SDAs set up in a room that is not square they are very easy to setup and will usually give you the perfect sweet spot if the simple setup instructions are followed.
    IMHO, I believe the OP has either a problem with the speakers i.e., a bad driver(s) or tweeter(s) or the crossovers need to have the caps and resistors updated/upgraded.
  • lightman1
    lightman1 Posts: 10,796
    edited May 2010
    Doro has bad ears.
  • hearingimpared
    edited May 2010
    I've just read a few of your other posts; when was the last time you had your mouth washed out with soap?
    SHUT UP RUSS!:eek::p:D
  • dorokusai
    edited May 2010
    lightman1 wrote: »
    Doro has bad ears.
    I've been farther than you have...you can bet on that Russ.
  • bigaltx24
    edited May 2010
    I've played with speaker placement quite a bit with these, they are quite a bit less finicky about placement than a lot of other speakers I've owned. I've settled on having them 32'' from the side walls, 78'' between speakers and 5'' from the rear wall. I have rebuilt the crossovers and damped the baskets on the PRs and MWs. I'll probably replace the SL2000s with RDO194s in the near future. They do sound fantastic on most material with the cable plugged in, but after doing a lot of A-B comparisons with and without the cable, to me the overall tonal balance is a little better without the cable. Without the cable I lose the huge soundstage, but things like female vocals, piano and acoustic guitar sound more natural.
    Denon PMA-900V
    Cambridge Azur 650C
    Polk SDA-1BTL
  • Bobsama
    Bobsama Posts: 526
    edited May 2010
    dorokusai wrote: »
    My ears have been wrecked for years. That's what happens when a kid spends hundreds of hours in a puddle-jumper; I figure I've accumulated at least a thousand hours on single-prop and twin-prop airplanes, not including the dozens of hours flying commercially.
  • OldmanSRS
    edited May 2010
    I have an L-shaped room in the basement. The imaging was so one-sided and I found a solution that's incredible. The problem was the left side had way too much dimensional reflection and the right side had way to much room to fill in the other part of the L-shape. I solved both of these by installing 4" thick acuoustic pads next to the dimentional arrays and adding a panel to make the room size more even left to right. A byproduct of the foam was the SL2000 tweeters sound smoother now. The soundstage is huge, deep and symetrical and the out of phase gimmicky aspect of the SDA that came from all the side reflections is gone. A real win-win IMO. This setup sounds better than ever before in the last 21 years.
    '72 Triumph TR-6
    __________________
    '86 Polk SDA CRS+
    '93 Carver TFM-35
    '88 Carver M-1.0t
    '88 Adcom GFT-555
    '88 Adcom GFP-555
    Four Polk T-15's
    Four Polk TSi-200's
    Four Polk TSi-100's
    Two Polk CS-10's
  • Litz
    Litz Posts: 111
    edited May 2010
    Monolithic 2001 tablets! No wait... SDA's flagship... I really want some...
    heiney9 Posts: 25,440
    edited May 2010
    SDA's are designed to be used with the cable. If you're not using the cable then you're not getting the full use of the speakers. Time to move on to a conventional speaker. The only reason the cable isn't hard wired is so they can be moved easier, not to play them without it.
    Some of the drivers aren't working and you are missing some frequencies to the drivers which are supplied by the cable. Many think the cable just sends a low level signal from the opposite channel. Not true so you are missing fundamental frequencies and it will cause you to try an compensate with tone controls, etc.
    The only time I've unhooked an SDA cable is for trouble shooting.
    edited May 2010
    danger boy wrote: »
    Not the speakers fault............it's the source. I disagree, you do loose a lot of what a speaker (conventional or SDA) should sound like. The SDA's are not designed to sound as good as a non-SDA speaker when the cable is removed. Can't have it both ways.
    Of course anyone can do what they want, but trying to sell it as it sounds just as good as any other non-SDA speaker is a pretty big stretch, IMHO.
    Todays recordings use way too much reverb and processing and the SDA's pick up on that more than many other speakers. Don;t balme the speakers...........blame the crappy production values and I'm not talking poor recordings, just over processed. Norah Jones - The Fall is a prime example of over processing. She sounds like she's singing in her bathroom.
  • ben62670
    ben62670 Posts: 15,969
    edited May 2010
    Running SDA's without the cable is like having sex with your sister. It is still sex, but it just ain't right.
    Ben
  • OldmanSRS
    edited May 2010
    heiney9 wrote: »
    SDA's are designed to be used with the cable. If you're not using the cable then you're not getting the full use of the speakers. Some of the drivers aren't working and you are missing some frequencies to the drivers which are supplied by the cable. Many think the cable just sends a low level signal from the opposite channel. Not true so you are missing fundamental frequencies and it will cause you to try an compensate with tone controls, etc.
    Agree. My 1.2's were some of the ones with the polarity revered at the binding posts. I ran them as marked from day-1 and 20 years later (after reading about it here) swapped the polarity and got SDA working for the first time since I owned them. Damn, what an improvment!
    '72 Triumph TR-6
    __________________
    '86 Polk SDA CRS+
    '93 Carver TFM-35
    '88 Carver M-1.0t
    '88 Adcom GFT-555
    '88 Adcom GFP-555
    Four Polk T-15's
    Four Polk TSi-200's
    Four Polk TSi-100's
    Two Polk CS-10's
  • vmaxer
    vmaxer Posts: 5,120
    edited May 2010
    ben62670 wrote: »
    ........................................:eek::eek::eek::eek::eek::eek:
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    Toolfan66 Posts: 18,067
    edited May 2010
    If your not going to use them as "SDA's" I say sell them and get some speakers that meet your needs.. Just to have them because there BIG makes no sense at all..
    edited May 2010
    ben62670 wrote: »
    HAHAHAHAHAHA!!!!! :eek::eek::eek:
    edited May 2010
    bigaltx24 wrote: »
    I notice the opposite. Tonal balance seems off to me when running w/o the cable. Vocals are recessed, highs are muted and things seem to sound unnatural. Flat, dry, lifeless, uninspiring, flaccid, tepid, vapid, choked, constrained, etc.
  • John in MA
    edited May 2010
    heiney9 wrote: »
    Can you provide a proper technical description? There've been threads about this in the past, including going over schematics and guys ohming out their speakers with multimeters. Seems like the result is always the same. At least in the big x.x series, the SDA drivers provide no positive signal above the low-frequency crossover point (below which they work in concert with the main drivers, even if the cable isn't connected.)
