LSi15 comparisons
dan t
dan t Posts: 206
edited November 2003 in Speakers
I was using the comparison chart of Polks, comparing the LSi15's to the Monitor 10's Series2 (currently use as fronts) when I noticed under Enclosure Type it was N/A. C'mon polk. I know the difference but that is a critical piece of info which is missing.
On another note, would a current owner lof the LSi15's like to offer their opinion on the sound. If I can find an authorized dealer here in Southern Cal, I will give them a listen. They might replace my Monitor 10 S2.
Dan
Post edited by dan t on
  • dan t
    dan t Posts: 206
    Enabled.
  • [Deleted User]
    [Deleted User] Posts: 7,598
    Hello Dan,
    Thanks for posting on the Forum. What question about the two enclosures are you looking for?
    Regards, Ken
  • dan t
    dan t Posts: 206
    Hi Ken,
    For enclosure types for both the M10 and LSi15's, I was looking for the Monitor 10's to be that of a Passive Radiator type and the LSi15 a Bass reflex or tuned port type of enclosure. Perhaps you can add 'enclosure type' to the comparison chart.
    Finally being able to purchase a new pair of Polks in 1991 (M10 S2) I remember wondering why polk never had speaker encloures of the Bass Reflex or Tuned Port type. The first time I heard my brothers JBL L166 Horizons, I thought there is no better type of enclosure than the tuned port. I see Polk is adapting this type of enclosure now. Interesting.
    Still interested in Polks,
    Dan
  • Doug Montgomery
    Doug Montgomery Posts: 58
    Dan,
    Just thought I'd show you a few graphs displying the difference between using the same driver in a sealed box vs a ported configuration.
    Note:
    Ported has bad group delay, cone displacement and impedeance at lower freqs
    Ported has a lower F3 thought (-3 db down freq)
    Sealed has better linearity
    Can YOU feel the bass?
