Jumper cable upgrade
Ern Dog
Ern Dog Posts: 2,237
edited May 2010 in 2 Channel Audio
When I first got my Tyler acoustics, I used those brass plates and some cheap speaker wire- which did the job as jumper cables. Then I moved up to making my own from DH Labs Q-10 speaker cable. Nice improvement. Lots more sparkle and detail. Today I made some jumper cables from some PNF Symphony cable and it totally warmed up the presentation. Not sure which I like better yet. :D
Post edited by Ern Dog on
  • Ern Dog
    edited May 2010
    Ok, without a doubt the new PNF jumpers are a better match for my rig.
    Ever since I got rid of my Rogue Audio Tube amp and tube cdp and replaced it with a solid state amp and ss cdp, the tone of my rig has been tipped up. Now, today I finally found the culprit by changing out the jumpers and it resolved the problem. Everything is smoothed out now.
    It is interesting that such a small thing as having the right jumper cables can make such a big difference.
    nooshinjohn Posts: 26,039
    edited May 2010
    not to derail your topic, but what was your impression of Rogue audio and why did you move on from them?
  • TouchOfEvil
    TouchOfEvil Posts: 967
    edited May 2010
    I use the PNF wire on my lsi15 and q-10 jumpers to the mids/highs i really like the added sparkle it gives without making it too overdone. wanna sell ur q-10's?:p
    Living Room Rig:D
    Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
    Xbox360/PS3/WII
    M.Br. setup:)
    Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
    Computer Rig:
    Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
    Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
  • Ern Dog
    edited May 2010
    It was the Rogue Stereo 90 and it sounded like **** when I first listened to it. Waaaayyy too mushy and warm. I resolved that easily by rolling in some NOS tubes- then I wasn't prepared for how intoxicating it sounded. Very smooth, but detailed at the same time. I sold it because there was some down sides: had to bias it regularly, tubes died and needed replacement (NOS tubes are expensive). it was a very delicate balance and I wanted something that didn't have so many different variables and wasn't so finicky. I looked towards Pass Labs amp because they offer the muscle and simplicity only solid state offers PLUS the sonic benefits of tubes w/out all the hassles.
  • Ern Dog
    edited May 2010
    Check the flea market :D
  • Jer.War
    Jer.War Posts: 180
    edited May 2010
    Did you use some pnf wire you had left, or did you order a small length (if so how much?)?
    I just bought some PNF symphony cables for my LSI15's. They were an upgrade from Monster XP, and sure sound smooth.
    [The Ever-Evolving System
    LSI15's (PNF Symphony cabels, modded X-Over and subs), LSIC, LSI7's, Rega Apollo CDP (PNF ICON ICs, modified PS cct.), Yamaha RXV-1700 w/ ipod dock, B&K REF200.2 (fronts) Samsung BDP-1600, XBOX360, Patriot Box Office Media Player, 42" Samsung LCD.
  • samnor
    samnor Posts: 155
    edited May 2010
    Just my 2cents but I did see a pretty decent improvement in mids and highs after going from stock jumper plates to anti-cables (Paul Speltz) jumpers... 30$ for a stereo pair... not a bad deal.... havent used them for speaker wire though but am considering... anybody used them at all?
    Fronts: Wharfedale diamond 9.6
    Sub: Wharfedale sw250
    Rears: Wharfedale diamond 9.1
    Center: Paradigm cc-350
    Pre-amp: Oppo dv981hd
    Amp for fronts: Parasound hca-1500a
    Amp for rears: Adcom gfa-5400
    Amp for center: Marantz MA500 monoblock
    Polk multimedia speakers for PC setup
  • zingo
    zingo Posts: 11,258
    edited May 2010
  • Ern Dog
    edited May 2010
    Jer.war- I purchased a used single PNF cable from Audiogon and cut up to my lengths. This move totally opened the sound so that it sounds more natural and neutral.
    Samnor- I've never tried the anti-cables, but at that price, it's worth a try.
    Zingo- Thanks!
  • reberly
    reberly Posts: 173
    edited May 2010
    i need to do some research, I have no clue what your talking about . The learning never ends.
    Onkyo TX-SR805
    Polk LSi15 , LSiC, LSiFX
    Parasound Halo A52
    Panasonic 42'' Plasma
    Oppo BDP-83
    Sonos
    Panamax 4300
    Audioquest cables
  • Ern Dog
    edited May 2010
    I wanted to be more clear about something... It's not the new jumper cables that are adding all the benefits that I'm talking about with this upgrade. They are simple allowing a better transfer from all the gear upstream. The old jumper was choking off I'd say 40% of the benefits of the gear upstream.
    Reberly- I'm talking about the brass plate that connects the top and bottom speaker posts in your LSi's.
  • sucks2beme
    sucks2beme Posts: 5,693
    edited May 2010
    I was playing with jumpers last night. I've got several sets.
    One is made from AQ type 8, one from Kimber 4tc, and one from a double run
    of 14 ga stranded electrical wire. Strangely enough, putting my AQ speaker
    cables on the treble terminals with any of the jumpers changes the sound
    for the worse. The cymbal crashes lose their impact. So does brass
    instruments. Putting the AQ cv-6's back on the other speaker connections
    brings them back. The Kimber jumpers have the best treble sound.
    Note, in order to do this, I swapped polarity on both speakers connections.
    I'll have to spin around the cable and try it the proper way and see if it
    has an effect. Either way, it doesn't make a whole lot of sense.
    You'd think using a like speaker cable as a jumper would yield the same sound,
    but the sound is either bass/tweeter terminal sensitive or polarity.
    Either way, my head hurts.
  • W WALDECKER
    W WALDECKER Posts: 900
    edited May 2010
    I run PNF Symphony speaker cable from my GTA SE40 to my Sonatina's and i was using 10ga bare solid copper wire for jumpers and it sounds really good but on a whim i called Steve Jain @ PNF Audio last night and ordered a 6' demo pair of symphony's so i can do the biwire thing.
    Rogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
    .Audience AU24SE speaker and ic cables- Chord Qutest DAC - Black Cat Silverstar II 75ohm digital cable-Tyler Acoustics Linbrook Signature system with large bass cabinets to accommodate 10" Seas magnesium woofers.2xhmpsuownoj.jpg
  • Ern Dog
    edited May 2010
    I'd be interested to hear about the results of your experiment.
