Ceiling mounted speakers
spphoenix
Hello,
I am going to be mounting speakers in my ceiling, the only problem being that the ceiling is vaulted. I was wondering if there is a place that sells an enclosure that would allow me to aim the speaker down. Or any other solutions you guys have. Thanks.
Post edited by spphoenix on
Hello,
Does it have to be ceiling speakers? I ask this question because if it is for Hi-Fi audio. I would never use those kind of speakers. Can you get small regular speakers with a sub and mount them on walls ( not the sub lol)?:rolleyes:Make it simple...Make it better! -
It is for a theater room. My only concern with the walls is I only have two to work with, a right and a back, so the sound would be pretty uneven. I am going to have three front speakers. These were the ceiling speakers I was considering.
Polk Audio RC80i
I was going to install 4. I was just concerned about directing the sound.
