Ceiling mounted speakers
spphoenix
spphoenix Posts: 33
Hello,
I am going to be mounting speakers in my ceiling, the only problem being that the ceiling is vaulted. I was wondering if there is a place that sells an enclosure that would allow me to aim the speaker down. Or any other solutions you guys have. Thanks.
  • lanchile
    lanchile Posts: 560
    edited April 2010
    spphoenix wrote: »
    Hello,
    Does it have to be ceiling speakers? I ask this question because if it is for Hi-Fi audio. I would never use those kind of speakers. Can you get small regular speakers with a sub and mount them on walls ( not the sub lol)?:rolleyes:
    Make it simple...Make it better!
  • spphoenix
    spphoenix Posts: 33
    edited April 2010
    It is for a theater room. My only concern with the walls is I only have two to work with, a right and a back, so the sound would be pretty uneven. I am going to have three front speakers. These were the ceiling speakers I was considering.
    Polk Audio RC80i
    I was going to install 4. I was just concerned about directing the sound.
