FXi30s placement ?
BIGECASTILLO
Hello, i have mounted my FXi30s on my sidewalls directly across from me 6 feet to each side from the main listening postion they sit 3 feet above the ear level.My question is do i place them with the woofer away from me or towards me.Also do i use bi pole or di pole? THANKS TO ALL THAT REPLY BIG E
TV WS 65809 MITSUBISHI HDTV REC ONKYO TX-SR800 DVD SR-5700 TOSHIBHA MAIN RTi70s CENTER CSi40 REAR FXi50s BACK REAR FXi30s SUB VELODYNE CHT15
Post edited by BIGECASTILLO on
The serial numbers begin with the letter R and L. R goes on the right side and L goes on the left, as you are facing the TV of course. I would suggest trying both Bi/dipole positions and leave the switch where it sounds the best to you.
When mounted on the side the mid points towards the tv. bipole dipole tryem both to suit your needs.
Good luck and enjoy
DanRecever AVR 8000
Amp PA 4000
CDR 26
Mains RTI 150 Bi wired
Center CSI 40 Bi wired
Surround FXI 30
Rear RTI 4
Sub PSW 140 -
as already stated.. you want the woofers pointing towards you/front of the room.. and yeah they do have a L & R distinction.. i run mine in bi pole. to me the di pole sounded off balance. I really enjoy their diffused sound.. much more than direct firing speakers.
good luck and happy listening
AlPolkFest 2012, who's going>?
lol
al,
love your eq list sig.... but miss the sauerkraut...More later,
Tour...
Vox Copuli
