FXi30s placement ?
BIGECASTILLO
BIGECASTILLO Posts: 38
edited November 2003 in Speakers
Hello, i have mounted my FXi30s on my sidewalls directly across from me 6 feet to each side from the main listening postion they sit 3 feet above the ear level.My question is do i place them with the woofer away from me or towards me.Also do i use bi pole or di pole? THANKS TO ALL THAT REPLY BIG E
TV WS 65809 MITSUBISHI HDTV REC ONKYO TX-SR800 DVD SR-5700 TOSHIBHA MAIN RTi70s CENTER CSi40 REAR FXi50s BACK REAR FXi30s SUB VELODYNE CHT15
Post edited by BIGECASTILLO on
  • Frank Z
    Frank Z Posts: 5,860
    The serial numbers begin with the letter R and L. R goes on the right side and L goes on the left, as you are facing the TV of course. I would suggest trying both Bi/dipole positions and leave the switch where it sounds the best to you.
  • Fireman99
    Fireman99 Posts: 129
    When mounted on the side the mid points towards the tv. bipole dipole tryem both to suit your needs.
    Good luck and enjoy
    Dan
    Recever AVR 8000
    Amp PA 4000
    CDR 26
    Mains RTI 150 Bi wired
    Center CSI 40 Bi wired
    Surround FXI 30
    Rear RTI 4
    Sub PSW 140
  • danger boy
    danger boy Posts: 15,722
    as already stated.. you want the woofers pointing towards you/front of the room.. and yeah they do have a L & R distinction.. i run mine in bi pole. to me the di pole sounded off balance. I really enjoy their diffused sound.. much more than direct firing speakers.
    good luck and happy listening
    Al
    PolkFest 2012, who's going>?
  • Tour2ma
    Tour2ma Posts: 10,177
    lol
    al,
    love your eq list sig.... but miss the sauerkraut...
    More later,
    Tour...
    Vox Copuli
