How much are you willing to pay for an audio rack?
2
  • Jetmaker737
    Jetmaker737 Posts: 1,129
    edited April 2010
    See post 32!
    lol... it wasn't there while I was typing! :cool:
    But still, you'd have to be able to explain how the vibration of the components could alter the sound. In SS gear I don't believe there is any functionality that can be influenced by it. However, for tubes you could see some possible effects due to vibration induced displacement of the relatively large size internal components of the tubes.
  • hearingimpared
    hearingimpared Posts: 21,136
    edited April 2010
    It shakes the electrons up and bounces them off each other!:rolleyes::D
    Tony M Posts: 11,728
    edited April 2010
    I see in some displays they place amps and things on the floor....
    I guess they are keeping infuences to a min. for their Demos.;)
    Makes sense dosn't it.:rolleyes:
    And I'm being serious here. It makes sense if racks introduce changes.
  • Echosphere
    Echosphere Posts: 395
    edited April 2010
    Bought this at Target down the street for $150. 3 Glass shelves, tripod design with steel and wood.
    http://www.target.com/Eclipse-TV-Stand-40/dp/B001L0VYDA/ref=sc_qi_detaillink
  • Hawkeye
    Hawkeye Posts: 1,313
    edited April 2010
    IMHO it is another piece of gear.
    In all reality it is a tweek and as we all know tweeks are a cumulative effect towards better SQ.
    I most certainly agree with you here! My original thought was since it is accepted as a component, there has to be the aesthetic appeal also. Thus, to get both, we're going to have to choke up some coin.
    My BillyBags is also loaded with 200 lbs of lead shot. Makes it a bear when I have to get behind it. In addition, I have all the components except the amps sitting on Symposium Rollerblocks. The rollerblocks are just another tweak which on some pieces did nothing and on others, repeatable changes occurred. I received the best result with the blocks under my transport and tube pre.
    Gordon
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
  • hearingimpared
    edited April 2010
    Hawkeye wrote: »
    Gordon
    I hear ya Gordon.
    I have 350 lbs of lead shot filling the four tiers of the VTI and it is a nightmare when I have to make a change. Sometimes I have to break it down tier by tier to be able to make a change or even swap out ICs for that matter but it is worth every bit of effort and the PITA as the shot loading has improved the sound of the rig by leaps and bounds. It is actually impossible to move when considering the weight and that it is spiked to the floor.
  • madmax
    madmax Posts: 12,434
    edited April 2010
    jaxwired wrote: »
    I'm not doubting that you did, but there are other possible explanations for those differences. Sure, one possibility is that the rack makes a sound quality difference, but seeing how that flies in the face of common sense, I'd be looking really hard at other possiblities. No offense. :)
    No offense taken but do you realize what my test was? I had several different types of material in approximately 20" x 15" panels and slid them one at a time under a given piece of equipment and noted how the sound changed. Try this one, get a piece of glass and a piece of MDF and try each one back and forth under your preamp or CD player.
    BTW, common sense for an engineer is that if you vibrate capacitors or coils you introduce voltages in their associated circuits. You can introduce measurable spikes into something like a preamp just by stepping on the input cable. :)
    Oh, and I'm not a rocket scientist and don't claim to be one but I would hope my rocket had vibration isolation for the circuit boards. ;)
    Vinyl, the final frontier...
  • Midnite Mick
    Midnite Mick Posts: 1,591
    edited April 2010
    Not really a rack per se...more of a cabinet but I am really diggin these.
    http://www.salamanderdesigns.com/chameleon/#/berlin
    Mike
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
  • jaxwired
    jaxwired Posts: 201
    edited April 2010
    madmax wrote: »
    I have no idea if that's true, but where talking about micro or more like nano vibrations here.
    I'm not saying audio racks don't "sound" different, but if they do, it absolutely contradicts common sense. Wouldn't be the first time something did. However, for me, if something contradicts common sense then I'm very skeptical. Especially when the only verification is the quite subjective and less than perfect "listening test".
    NAD C545 -> Benchmark DAC1 -> Bryston BP6 -> Bryston 4B SST2 -> Dynaudio Contour S1.4
  • hearingimpared
    edited April 2010
    Mike
    Salamander racks are so nice Mike. I love looking through Raife's rig pictures just to look at them. When we moved in here, I was going to buy a Salamander for my HT rig and my two channel rig but for some reason the wife put the kibash on it. . . she didn't like the looks. Go figure.:(
  • hearingimpared
    edited April 2010
    jaxwired wrote: »
    Jax as stated hundreds of times here, you'll never know until you try.:)
  • TouchOfEvil
    TouchOfEvil Posts: 967
    edited April 2010
    jaxwired wrote: »
    The amount of vibration a piece of gear is subjected to will vary for everyone. If you have a decent enough sub setup though i'm betting the vibration will be fairly high unless you take steps to eliminate it.
    For instance with my sub running while listening to music it used to cause the cd player to skip if turned up too loud. This tells me vibration control is a much needed thing for my setup.
    Living Room Rig:D
    Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
    Xbox360/PS3/WII
    M.Br. setup:)
    Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
    Computer Rig:
    Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
    Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
  • jaxwired
    jaxwired Posts: 201
    edited April 2010
    BlueFox wrote: »
    There is no "common sense" contradiction here.
    Really? Might want to give that a bit of a rethink...
  • jaxwired
    jaxwired Posts: 201
    edited April 2010
    True, but then I'm in jeopardy of becoming one of those guys with cable elevators and orange hospital outlets, demagnetizing my CDs, and resting all my equipment on little squares of tofu. And I'd probably have to trade my CD collection for south american woodpecker mating calls recorded on reel to reel. Too big a commitment for me... :)
  • madmax
    edited April 2010
    jaxwired wrote: »
    Where do I find the woodpecker mating calls on R2R? My CD copies just don't cut it anymore.
    madmax
  • unholyracket
    unholyracket Posts: 3
    edited October 2011
    I'd pay $5,000 but it depends on what you're looking for. The Audiav racks mentioned in the review can cut out vibrations, electro-static discharge, alien brainwaves, etc., to give you the cleanest sound. If you're not into the cleanest possible sound, then stick with your $150 yard sale racks.
  • decal
    decal Posts: 3,205
    edited October 2011
    I wish I had 5 grand to spend on a rack. I'd buy a lot of music with it!!!!
  • inspiredsports
    inspiredsports Posts: 5,502
    edited October 2011
    This goes for anything I've ever purchased that I use on a routine basis . . .
    I find I'm always willing to pay considerably more than the most I was willing to pay when I made the initial purchase.
    When I learn the subtlties of the item, I learn what features could be improved upon and what each of those improvements cost. I then generally sell the original and trade up, several times. I guess it's what you would call the cost of education.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • mantis
    mantis Posts: 17,559
    edited October 2011
    Here's the deal with Audio racks.
    They fill a need. They are spec'd to home X amount of gear for today and if your smart , you spec in some room for future gear.
    If the rack is to be seen then it should work in it's environment. Most times the WAF comes into play. Money comes in after you figure out whats needed and whats needed cost. If your not willing to spend X money on X rack then you have to find something thats affordable to your budget.
    I'm willing to spend what it takes to fill my needs at all times. Most of the time the racks I like are expensive for my budget. I usually find a way to get what I want to try to find a alternative that still suites my needs but don't break the bank of better put piss my wife off.
    I spend some money on my Salamander many years ago and I still have it today. It's in perfect shape and does exactly what I need it to do and look good doing it. I'd like to get all my gear out of my room and put it in the basement , use a Mid Atlantic rack for my house gear as well as theater gear. I'm willing to spend whatever it costs for that rack or 2. They are the best and I will not settle for anything less.
    Dan
  • bikezappa
    bikezappa Posts: 2,463
    edited October 2011
    Consider locating all the equipment in a closet in the listening room or other room.
    Get an IR to RF remote and you have no feedback issues and the wife will love the set up.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited October 2011
    I would pay about 1 million for a rack....if it was attached to this.....
  • thsmith
    thsmith Posts: 6,082
    edited October 2011
    She looks like is not old enough to vote
    Toolfan66 Posts: 18,182
    edited October 2011
    I am building one kinda like this one by Adona http://www.adonacorporation.com/av45cs4.html I did purchase the spikes from them that go on this rack, very nice people. I just wanted to save some money and I wanted mine to be a little wider, my shelves will be 24" x 19" and made from 1" thick acrylic.. should be done in a couple weeks..
  • 3Labman
    3Labman Posts: 2
    edited October 2011
    I made up a crude drawing and had my Amish guy make mine out of hickory. Cost me $1200 and the wife likes it.
  • Drenis
    Drenis Posts: 2,871
    edited October 2011
    3Labman wrote: »
    I'm a big hickory fan. Post pics?
  • rebuy
    rebuy Posts: 694
    edited October 2011
    3Labman wrote: »
    I'm a big Amish fan, Post Amish pics.
  • 3Labman
    3Labman Posts: 2
    edited October 2011
    I cannot find the camera. I will look tomorrow and try to post pics.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited October 2011
    SWEET! :smile:
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • reeltrouble1
    edited October 2011
    thsmith wrote: »
    well you might not want to tell her that....or risk having her name carved into your leather seat.....!!!!:razz:
    VR3 Posts: 29,549
    edited October 2011
    I think I spent roughly 800 on my racks -
    I wanted the VTI style but not VTI, I was not fond of VTI's build quality...
