What are the symptoms of tube(s) going bad?
polkatese
polkatese Posts: 6,767
edited April 2010 in 2 Channel Audio
As tube aged, and slowly dying, what would be the symptoms or traits? This is specifically on the output stage of a CDP, if it matters.
TIA
I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
Post edited by polkatese on
    F1nut Posts: 52,101
    edited April 2010
    Static, pops and/or distortion are signs a tube is going bad.
  • polkatese
    edited April 2010
    and it is intermittent too? there were days that it didn't show this, but today it did the static, and signal corruption that last half-a-second randomly at an odd interval. Doing a power cycle through the CDP seems to cure that at times.
    Thank you Jesse.
    heiney9 Posts: 25,549
    edited April 2010
    flat sounding, a little lower output. But as Jesse said.......snap, crackle, pop, hissing which gets louder and softer. Red glow rather than orange glow inside the envelope. What brand tube? Many current production Chinese and Russian tubes have a significantly shorter life span than NOS from the 50's-70's.
    SCompRacer Posts: 9,137
    edited April 2010
    I've had dirty pins/tube sockets cause problems like that too.
  • polkatese
    edited April 2010
    It's a Russian Sovtek 6H30pi. Can't say anything about the glow since it is completely enclosed inside. So far the only issue is the one I described in #3.
  • polkatese
    edited April 2010
    Interesting Rich. I've never removed it from its socket since 2004. I already ordered one from Dedicated Audio. I am really hoping this is the culprit, since it would be a major bummer if it's something else. Love this baby and it's been trouble-free since I bought it.
    edited April 2010
    Yes, clean the PINS sometimes that helps. 2004? You may be due for a new tube.
    edited April 2010
    It's worth a try. I've had it happen with Gold plated pins too. I have these great Sylvania Gold Brand 5687's with Gold plated pins I loved in my CD player. Every now and then I'd have to wiggle the tubes in the sockets to get the static to stop, or to get a channel to play. I found some Sylvania Gold Brand with steel pins and now life is gooder.:cool:
    EDIT: Just a disclaimer, touching a hot tube with bare fingers can sizzle the skin.:eek:
    F1nut Posts: 52,101
    edited April 2010
    polkatese wrote: »
    It can be.
    You mean turning it off and on again?
    Is there just the one?
    LOL, I would have thought you would know not to touch a tube, hot or cold, with your bare fingers.
    edited April 2010
    Just don't want anyone hurt is all....;)
    We of the RAS (Rockford Audio Society) do use gloves to change tubes. I'm not sure if the other guys wiggle theirs or not, gloved or bare handed.:D
    F1nut Posts: 52,101
    edited April 2010
    Hehe....:D
  • george daniel
    george daniel Posts: 12,096
    edited April 2010
    Also,, if the tube is in a pre amp circuit, you might experience a loss of volume.I've been playing with a tubed phono preamp,and had just rolled some Sovtek 12ax7lps in her,,about 3 days later I noticed a loss of volume in the right channel,,sure enough,after changing tubes the Sovetek was the culprit,,when I get my tube testor back from an unamed polkie I'll test it,,I'm sure one of the sections has gone bad.Also,,take heed in what the others have said--CLEAN PINS--sorry for the long winded explanation--I feel better now--Have a nice day.:)
  • TNRabbit
    TNRabbit Posts: 2,168
    edited April 2010
    SCompRacer wrote: »
    ...I'm not sure if the other guys wiggle theirs or not, gloved or bare handed.:D
    Hehe....:D
    My first thought, Jesse~ :D
    You KNOW for sure a tube is bad when it goes up in a magnificent flaming pyre, leaving a pile of molten silica....
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • dorokusai
    dorokusai Posts: 25,576
    edited April 2010
    You haven't lived until you've seen a tube blow up within itself, like a supernova.
  • hearingimpared
    hearingimpared Posts: 21,136
    edited April 2010
    SCompRacer wrote: »
    Those are some really great gloves Rich. Where can I get a pair?
    To the OP when I owned the VTL 5.5 pre (for a short time) I had a tube go south. When I tapped the case or the platform is was setting on I could hear the tapping coming through the speakers. Turned out it was a tube going microphonic. I rolled in a full set of JAN NOS tubes and the problem was resolved.
  • polkatese
    edited April 2010
    Jesse, yes on both counts.
  • jhw59
    jhw59 Posts: 348
    edited April 2010
    SCompRacer wrote: »
    what does one use to clean sockets, etc?
  • dorokusai
    edited April 2010
    www.caig.com
    I've used the SWPP with great results on tube sockets. Or just wiggle it around a little and let the clamps break the contact point up.
  • polkatese
    edited April 2010
    heiney9 wrote: »
    so the question is: how long a tube with moderate use supposed to last?
    edited April 2010
    polkatese wrote: »
    That is the million dollar question and it varies. I can say from what I've read NOS tubes tend to last longer on average. Some of my favorite tubes (Telefunken, Valvo) are rated at 10,000 hours but routinely get 15,000 hours in the pre-amp position.
    Most Chinese and new issue Russian tubes are lucky to get 3000-5000 hours. But I'm just quoting averages based on what I've read. There are many that get beyond that.
    Power tubes are a completely different beast as far as longevity but in general older tubes last a bit longer.
  • hearingimpared
    edited April 2010
    heiney9 wrote: »
    According to Musical Fidelity and Jesse, the tubes in my Tri-Vista preamp stage are rated at 100,000 hours. Something to do with the use of tubes from the Russian MIGs.:rolleyes::rolleyes::rolleyes::eek:
  • dorokusai
    edited April 2010
    I think the data from Musical Fidelity, the manufacturer, would suffice.
    F1nut Posts: 52,101
    edited April 2010
    Actually Joe, the tubes were originally used in the guidance systems for US missiles, something Musical Fidelity, the manufacturer won't tell you. They are also rated for an altitude of 60,000 feet.
  • hearingimpared
    edited April 2010
    I was actually joking about the MIGs but there you go, they were used in some kind of aeronautics.
    What I wasn't joking about was the 100,000 hours, I believe this IS what they are rated. Even if it is drummed up a bit it's still impressive and you are correct they are nice tubes.
  • george daniel
    edited April 2010
    Colossus
    http://en.wikipedia.org/wiki/Colossus_computer
    and the Foxbat
    http://www.globalaircraft.org/planes/mig-25_foxbat.pl
    I had some NOS tubes that I bought from a Russian Gent,, came in a plastic tray with lid,, had the "Red Rocket" logo on the boxes,,kinda cool actually,, sold em to a third world country to help start their one plane airforce.;)
  • hearingimpared
    edited April 2010
    That's some cool reading George.
  • george daniel
    edited April 2010
    thanks--what got me going was the fact that the Russians relied heavily on tubes,because they would still operate in certain "nuclear" conditions when other electronics would not,, as in communication and guidi ence systems,,the fact the some manufacturers use a tube that is soldered/secured in place-speaks volumes.
  • hearingimpared
    edited April 2010
    Yep, the tubes in my preamp stage are soldered in and from what I understand from Jesse, they are a bear to replace. I have the replacements but I hope I never have to do so.
  • polkatese
    edited April 2010
    Soldered? wow, that's hardcore!
    so, those jets with tubes, do you think they care if the tube turned microphonics? can they tell just by listening to the engine rev? :p
    I am waiting for the replacement to arrive, I am hoping THAT's the problem. It is frustrating when it only happens intermittently.
    edited April 2010
    Polkatese, I bet that's your issue. Have you cleaned the pins and lightly wiggled it around in the socket just to be sure?
