Pioneer Speakers Crackle
PerfectCreature
PerfectCreature Posts: 1,456
edited April 2010 in Speakers
Ok. So this is a bit odd to me. I powered up my old Pioneer speakers. They will play with crackle at from volume 0-5 of 30 then 10-15 it doesnt crackle after 15 it will shut off my receiver.
Why does this happen?
Receiver
Harman Kardon HK 3490
Speakers
Polk Audio Monitor 50s
Subwoofer
Klipsch KSW-100
Cables
AudioQuest Rocket 33s 10ft
AudioQuest Optilink1 2m
AudioQuest Alpha-Snake 25ft Interconnect
AudioQuest HDMI-1 2m
Alienware X51 R2
PS4
Samsung Smart TV 40" 1080p 3D
Post edited by PerfectCreature on
  • cstmar01
    cstmar01 Posts: 4,424
    edited April 2010
    seems like there is a short somewhere and I would not recommend to keep doing it because its not good for your AVR to keep shutting off. You might have a bad connection with speaker wire touching the other terminal ect. DO NOT KEEP DOING IT AS YOU WILL PROBABLY RUIN YOUR AVR.
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited April 2010
    Your volume control-pots might simply require cleaning... check this first!
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
    edited April 2010
    TECHNOKID wrote: »
    +1, I have a very very old PILOT integrated (and no, it doesn't 'fly')...anyone ever hear of that? And it's pretty much got the same problem. I never bothered to fix it...it just hangs out in my basement in a pile with some other stuff?
    cnh
