sunfire
hc_416
i just bought a SUNFIRE CINEMA GRAND SIGNATURE ARCHITECT'S CHOICE II to run my polk audio RTi 12's does this have enuff power to run then and will the voltage outputs sound good.
Post edited by hc_416 on
It has plenty of power & you are going to be one happy camper. Welcome to Club Polk.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
+1 Same response
_____________________________________
01) DENON AVR-4308CI: Advanced 7.1 CH/5.1+2 CH/ 3.1+2+2 CH A/V Home Theater /MultiMedia Multi-Source/Zone Receiver with Networking and WiFi/170 watts x 7 channels
02) SUNFIRE Grand Signature - Bob Carver's
03) OPPO DV-980H 1080p Up-Converting Universal DVD Player with HDMI and 7.1CH Audio
04) OPPO BDP-83 Blu-ray Disc Player w/SACD & DVD-Audio / DENON DVD-2500BTCI: Blu-ray Disc DVD/CD Digital Player/Transport
05) HITACHI P55T501. 55" HD1080 Plasma HDTV
06) POLKAUDIO LSiC (Center speaker)
07) POLKAUDIO LSi15 LEFT (Front speaker)
08) POLKAUDIO LSi15 RIGHT (Front speaker)
09) POLKAUDIO LSif/x LEFT (Surround speaker)
10) POLKAUDIO LSif/x RIGHT (Surround speaker)
11) VELODYNE OPTIMUN SERIES 12"(High Output Digital EQ SubWoofer 2400W/1200WRMS)
http://www.polkaudio.com/forums/showcase/view.php?userid=98096 -
+2 with the above...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
your going to love it.engtaz
More then enough power for any size room. Enjoy it it's a really nice amp.Dan
i am runnign 8 gauge power wire for the speaker wire, should i upgrade and what should i do for my preamp. I am useing a yammie vx-2700 not cheap but not the best. I also use a optical out from my computer for 90% of all my musice any suggestions would be greatly appricated
8 gauge! I'm running 10 and I thought that was thick. Some websites say 12 is good enough for any application. Screw 'em.
One question, did you buy them preterminated or did you futz with them yourself..
a 400 watt x 5 amp...Yep,,,thats what I need too. Maybe the 7x400 tho.
Big speakers and lots of clean high fidelity power..the best combo.
So, like what are going to do with the other 3 channels?
Get some sda's?
You done good. -
Enjoy, Sunfire makes a hell of an amp.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
The amp is 425x5, and I got a really good deal on it. I waited for months befor I bought it. I custom made the wire with monster bannas, they are quick and easy to plug and unplug. Thought i was wondering if they take a little power. I don't know right now as to what i am going to do with the other three. I have the polk auido RTi 12's and with the three 7 inch woofers you just can't get that low end bass, but i love the highs so mabey a speaker upgrade to use the last three.
[QUOTE=hc_416;1322885...... I have the polk auido RTi 12's and with the three 7 inch woofers you just can't get that low end bass, but i love the highs so mabey a speaker upgrade to use the last three.[/QUOTE]
I think you will be very surprised at the Bass you will get..
i have a m1.5t and that is no slouch in the power deparment. That beging said a 7 can't make bass like a 15 or 12 for that matter. I don't really understand why polk dosn't make a large bass woofer with no ampflication. My run-in with a amp woofer section didn't go to well but hey that is the way it goes.
I have a 400x7 modle and love the amp. One thing to watch out for is if your using banana's in a rack that you need to move is the speaker wires might come out. But you sound like you are using big enough wires that it should fill up the hole in the naners and the screws in the them should lock down hard.If life had more tubes it would be a lot smoother.
Sweet Amp-Congrats!Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
I would look into replacing the wire, while the guage is good with that amp you will notice a SQ shift IMO. -
Have I missed something or is it Bob Carver's BIRTHDAY today...or Carver-fest??
Lots of threads here?
cnh
Not sure when his birthday is.
Nice score on the amp. I love my Sunfire amps.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t -
http://www.carveraudio.com/main.html
September 10th - 20th, 2010 Needmore Rd,
Bryson City, North Carolina
Countdown to CarverFest
142 days, 22 hours, 58 minutes, 19 seconds -
what type of wire would you suggest, becuase i don't belive in 900 dollar wire. Also when i get my amp i will be selling a m 1.5t if anyone is looking, it has a hum but works great, I would recommoed getting it serviced. 350 plus shipping
Look at Monoprice, Blue Jeans Cable, & Signal Cable for your wiring needs.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Polk doesn't make a big woofer cabinet ( 12"-15" ) because they're belief is if you ad up the area of 3 -7" like on a RTiA9 it equals out in area as a single large 1. A 7" can react faster due to not having as much resistance fighting or cupping air like a 12 or 15. That is they're reasoning
That is a solid line of reasoning but, the sound waves proagate throught the air. When a seven hits it starts out smaller and will always be smaller than a 12 or 15 fireing at the same time in the same postion. That is why the 7's hit faster, but they also don't hold a note as long either. I guess there are pro's and con's but you can just put a 12 10 7 6 5 and one inch tweeter in a tower and we will be all set.
That's why the SDA's still play with the best of them. A bunch of 6.5's and a 10 to 15 inch passive sub move a lot of air.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Mr. hc_416. Sounds like a build project through parts express. You may have the new " Super Speaker " right in your hands!!! If you pursue your idea , photos and specs would be cool as hell! Regards.
