Recalibrating Speakers after break-in
I purchased my speakers and calibrated them, thanks to the help I received on this board, about 4 months ago. Since by now they should be broken in, is it normal to recalibrate the speakers? Just wondering. This is still one my best purchases and the WAF is all good.
Hank
Hank
My 7.1 System:
Fronts: Polk RTi70's
Center: Polk CSi40
Surround Sides: Polk FXi50's
Surround Backs: Polk RTi38's
Sub: SVS PB1-ISD
Receiver: Sony STR-DA7ES
SAT Receiver: Sony SAT 200B
HDTV: Panasonic CT-36HX42
Center: Polk CSi40
Sub: SVS PB1-ISD
Post edited by hank1105 on
I usually re-calibrate my speakers every 4-6 months. My system is located in my living room and between moving furniture to vacuum and other variables, the system needs to be adjusted slightly.Oh, you hate your job? Why didn't you say so? There's a support
group for that. It's called EVERYBODY, and they meet at the bar.
-Drew Carey
There is a very fine line between "hobby" and "mental illness."
-Unknown
My DVD Collection -
Good to know, thank you for your time.My 7.1 System:
Center: Polk CSi40
Sub: SVS PB1-ISD
HDTV: Panasonic CT-36HX42 -
Also, consider not only recalibration when you move speakers around, but furniture as well. Just moving furniture around and re-arranging the room in other ways than messing with your speaker placement can change reflections significantly.Mains: polkaudio RTi70's (bi-wired)
Center: polkaudio CSi40 (bi-wired)
Surrounds: polkaudio FXi30's
Rear Center: polkaudio CSi30
Sub: SVS 20-39 PC+
Receiver: ONKYO TX-SR600
Display: JVC HD-56G786
DVD Player: SONY DVP-CX985V
DVD Player: OPPO DV-981HD 1080p High Definition Up-Converting Universal DVD Player with HDMI
Remote: Logitech Harmony H688
