Recalibrating Speakers after break-in
hank1105
hank1105 Posts: 63
edited November 2003 in Speakers
I purchased my speakers and calibrated them, thanks to the help I received on this board, about 4 months ago. Since by now they should be broken in, is it normal to recalibrate the speakers? Just wondering. This is still one my best purchases and the WAF is all good.
Hank
My 7.1 System:
Fronts: Polk RTi70's
Center: Polk CSi40
Surround Sides: Polk FXi50's
Surround Backs: Polk RTi38's
Sub: SVS PB1-ISD
Receiver: Sony STR-DA7ES
SAT Receiver: Sony SAT 200B
HDTV: Panasonic CT-36HX42
Post edited by hank1105 on
  • jgido759
    jgido759 Posts: 572
    I usually re-calibrate my speakers every 4-6 months. My system is located in my living room and between moving furniture to vacuum and other variables, the system needs to be adjusted slightly.
    Oh, you hate your job? Why didn't you say so? There's a support
    group for that. It's called EVERYBODY, and they meet at the bar.
    -Drew Carey
    There is a very fine line between "hobby" and "mental illness."
    -Unknown
    My DVD Collection
  • hank1105
    hank1105 Posts: 63
    Good to know, thank you for your time.
    My 7.1 System:
    Center: Polk CSi40
    Sub: SVS PB1-ISD
  • kberg
    kberg Posts: 974
    Also, consider not only recalibration when you move speakers around, but furniture as well. Just moving furniture around and re-arranging the room in other ways than messing with your speaker placement can change reflections significantly.
    Mains: polkaudio RTi70's (bi-wired)
    Center: polkaudio CSi40 (bi-wired)
    Surrounds: polkaudio FXi30's
    Rear Center: polkaudio CSi30
    Sub: SVS 20-39 PC+
    Receiver: ONKYO TX-SR600
    Display: JVC HD-56G786
    DVD Player: SONY DVP-CX985V
    DVD Player: OPPO DV-981HD 1080p High Definition Up-Converting Universal DVD Player with HDMI
    Remote: Logitech Harmony H688
