questions for speakers
bproe
bproe Posts: 3
edited April 2010 in Speakers
First post.need advise on new towers to replace bose in new house.theater room size is 16 by 24.considering monitor 60 or 70.currently using yamaha rx-v650 reciever. already have hsu stf2 sub. any recommendations for center and surrounds would be appreciated. thanks
Post edited by bproe on
  • Conradicles
    Conradicles Posts: 6,338
    edited April 2010
    Welcome to the forum bproe. I have a few in mind, but was wondering how much you are willing to spend?
    PS: I would go with the Monitor 70 for sure. Your amp with it's pre-outs will allow you to upgrade to an additional power amp in the future to help feed the Monitor 70's more power.
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited April 2010
    +1 on the 70's, they are the best bang for the buck in the Monitor series, IMHO. Center channel I would get a CS2 and for surrounds I woudlook into Monitor 30's or Monitor 40's. Very similar setup to what I had not too long ago and it was awesome. Good luck and welcome to Club Polk.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • hearingimpared
    hearingimpared Posts: 21,136
    edited April 2010
    Welcome to the best audio club on the net bproe!
    edited April 2010
    -Jeff
    WELCOME TO CLUB POLK!!
    I'd pretty much go with Jeff's system above....M70s, CS2 and M40s are surrounds, your AVR and sub look good for now..but they won't for long if you hang around 'here'!
    cnh
  • packetjones
    packetjones Posts: 1,059
    edited April 2010
    Welcome to the CP.
    I also agree with the statements above. The monitor series is very budget friendly. It is definetly a great place to start. Depending onthe budget that you have I would also recommend the RTiA series. The RTi's are more for HT and are a step up from monitor series.
    Wjhat is your room size and budget?
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • bproe
    bproe Posts: 3
    edited April 2010
    thanks for all the help guys.wasnt sure if 70's would need seperate amp to play well enough for ht.would tsi's be appreciable difference for mostly ht.would like to keep towers around 500$
  • cnoat
    cnoat Posts: 315
    edited April 2010
    Welcome.If you want to spend your money,This is the place to be.
    Onkyo 898 center rears
    Parasound 1000a fronts
    Rti 12's fronts
    Csi5 Center
    Rti's8 Rear
    505 sub
    Parasound Avc-1800
    Mains-Rti 12 -Parasound 1500a
    Center-Csi5-Parasound 1000a
    Rears-Rti 8-Parasound 750a
    Sub SVS Ultra Tv 12
    Diamondback and King Cobra IC's
    AQ T4 SC
  • hagmanm2
    hagmanm2 Posts: 205
    edited April 2010
    bproe wrote: »
    Nah, stick with the 70s, they'll outmatch the 500s bang for the buck. There are several threads out and about that compare the two.
    http://www.polkaudio.com/forums/showthread.php?t=90419&highlight=500s+70s
    The general consensus is regardless of which you end up preferring (500s or the 70s), for the money the 70s are the better deal. ;)
    I will say I heard a discernible difference in my 500s when I amp'd them separately via my M-40 (then tried bi-amping and liked it most). However, I don't know how much of a difference that would translate to over in HT (most of my listening is music)... though it would free up the AVR to send more power to your center. I'm very happy with my M-40, 120Wx2 channels and can be found on ebay for cheap cheap!
    Living Room: Receiver: Pioneer Elite SC-25 | Turntable: Technics SL-B200 | CD Player: Rotel RCD-955AX | Fronts: Polk RTiA3 | Center: Polk CSi A4 | Rears: Polk FXi3 | Sub: Velodyne DPS-10 | Cables: AudioQuest Type4 & TypeA
    Office: Carver HR-742 | Speakers: RTi6 | Turntable: Numark 1600
  • wutadumsn23
    edited April 2010
    +1 on the 70's, I own both the TSi 500's and the Monitor 70's and IMJHO the 70's are the better speaker regardless of the price.
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
