bass shaker hook-up! Again
dholmes
dholmes Posts: 1,136
edited November 2003 in Speakers
Okay Ive got 4 bass shakers & a plate amp for a sub, what is the best way to hook them up? I was thinking that the plate amp has a 2 spk hook-up, run the 2 positive on the amp to 2 bass shakers jump from there to the other 2 & do the same to negs. Is there a site where I can go to to figure this out thanks
My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Post edited by dholmes on
  • scornful
    scornful Posts: 272
    What impedience is the amp rated at? What nom. impedence are the bass shakers? A little more info if you want a good answer...
    Rtotal = (1/R1 + 1/R2)^-1 parallel
    Rtotal = R1 + R2 series
    These apply for nominal loads. If your shakers are anything like speakers, the load varies with frequency. But that wont matter for what you're doing....
    Denon 3802
    B&K 7270
    Outlaw ICBM
    Behringer DSP1124P
    Samson S1000
    SVS 20-39CS+ (x2)
    RTi150's
    CSi40
    FXi30's
    RTi38's
    Win Vista HTPC
    InFocus 4805 ~100" Screen
  • dholmes
    the shakers are 4ohms & so is the amp.
  • RuSsMaN
    RuSsMaN Posts: 17,985
    To stay at a 4ohm load, you'll need to wire 2 separate pairs in series, the wire the separate pairs together in parallel.
    Cheers,
    Russ
  • scornful
    scornful Posts: 272
    Yup.... here's a rough pic
    here
    Denon 3802
    B&K 7270
    Outlaw ICBM
    Behringer DSP1124P
    Samson S1000
    SVS 20-39CS+ (x2)
    RTi150's
    CSi40
    FXi30's
    RTi38's
    Win Vista HTPC
  • RuSsMaN
    Same result, but the pic shows 2 separate pairs in parallel, then the 2 pairs wired in series.
    6 of one - half a dozen... you end up at 4ohm.
    Cheers,
    Russ
  • scornful
    scornful Posts: 272
    Yeah I guess I should have explained that... I was working on the pic when you posted
    Denon 3802
    B&K 7270
    Outlaw ICBM
    Behringer DSP1124P
    Samson S1000
    SVS 20-39CS+ (x2)
    RTi150's
    CSi40
    FXi30's
    RTi38's
    Win Vista HTPC
