ADCOM GFP-750 Blue Boards
Toolfan66
Toolfan66 Posts: 17,986
edited August 2010 in 2 Channel Audio
Really does anybody know what the difference is other then the color?
My board is the Blue Board. This is a pic of mine
Here is another board looks blue to me the Adcom logo is there and bigger,
But I am guessing this is a red board.. this is a pic of one on ebay right now.
Anybody???
Post edited by Toolfan66 on
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited April 2010
    Blue board 750's were made in America, and the other 750's were made overseas(not sure where exactly).
    I've looked into this myself, and that's the only difference that I'm aware of.
    From what I understand, there isn't any real sonic difference between the two. Some people have claimed that the build quality of the blue board units is slightly better.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • steveinaz
    steveinaz Posts: 19,545
    edited April 2010
    Maybe the blue boards are mil-spec, lacquer coated??
  • Ricardo
    Ricardo Posts: 10,636
    edited April 2010
    Blue ones have the same effect as Viagra.
    SOPA
  • steveinaz
    edited April 2010
    My CEC CDP has all blue boards.
    edited April 2010
    Well I got Blue Balls..
  • steveinaz
    edited April 2010
    ...those are definitely not mil-spec...LOL
  • sda2mike
    sda2mike Posts: 3,131
    edited April 2010
    those are strikingly handsome, in blue
  • ALL212
    ALL212 Posts: 1,645
    edited April 2010
    The balls...or the boards?
    Aaron
    Enabler Extraordinaire
  • sda2mike
    edited April 2010
    the boards, man!
  • cstmar01
    cstmar01 Posts: 4,424
    edited April 2010
    from what I read and heard this was it. There was a guy selling one on audiogon and I inquired about it because he said the blue boards are worth more, but never really gave a reason why, just that it was made in the USA compared to china is the only reason why he said.
  • jimangie1973
    jimangie1973 Posts: 1
    edited August 2010
    Raised from the dead....
    Both those pictures up top are of the blue board. They were American made with nice ALPS pots for the volume and balance controls. The red board models were just that, completely red and made overseas. The problem with the red board models is they use crappy pots with a large amount of 'play' or wiggle, definately not ALPS. I know this first hand because I ordered one of the red board units new and returned it soon after only to buy a blue board version on Audiogon.
    edited August 2010
    Thanks!!! Now we are in the know..
  • FTGV
    FTGV Posts: 3,650
    edited August 2010
    If I was the fortunate owner of one of these I would want to upgrade those cheap looking film caps they use for input and output coupling.
    heiney9 Posts: 25,405
    edited August 2010
    FTGV wrote: »
    Tell me more? There is a thread on DIY Audio, but it's hard to follow. The guy replaced all the caps. I'm going to be ordering some coupling caps shortly for my Norh tube integrated. If you could point in the right direction on the Adcom with a few suggestions.
  • FTGV
    FTGV Posts: 3,650
    edited August 2010
    The baby blue ones in the gain stages( center right in first pic)
    edited August 2010
    FTGV wrote: »
    You mean like this
    Seems some are missing?
    edited August 2010
  • FTGV
    FTGV Posts: 3,650
    edited August 2010
    heiney9 wrote: »
    You mean like this
    Brock I only see an X.
    edited August 2010
    FTGV wrote: »
    I guess when you link a photo from a site one has to sign into, no one can see it unless they are signed in. Try this.
  • FTGV
    FTGV Posts: 3,650
    edited August 2010
    Ok I see that.I found a schematic on your first link and it appears coupling is actually done with a cheap electrolytic bypassed with a cheap film.:eek:
  • FTGV
    FTGV Posts: 3,650
    edited August 2010
    heiney9 wrote: »
    Yes he removed the stock film bypasses and replaced the 'lytics' with Black Gates which are now unobtainium.
    edited August 2010
    FTGV wrote: »
    I think some ELNA Cerafine's might work nicely there. What do you think?
    edited August 2010
    Or maybe some nice Obbligato's or Mundorf's.......I guess we don't want 'lytics in there.
  • FTGV
    FTGV Posts: 3,650
    edited August 2010
    Well since the output caps (4 needed) are 100uf a film cap would be prohibitively large and expensive,so a premium lytic might be the realistic choice.The Cerafines would certainly be good but having recently tried a pair in a DAC project I would try to source some Sanyo OScons.As for the 10uf input caps I would look at maybe trying the Panny ECQ's film's if they will fit in the alotted board space .While inexpensive they are quite good for coupling purposes and I believe Pass used them in the Aleph P(atleast it appeared so in the pic I saw of the inards.)
