Mixing with Polk Speakers
Saddle
Saddle Posts: 6
edited April 2010 in 2 Channel Audio
Hope this is the correct forum...
Any one using Polks for serious mixing either at work or in a home studio? Older monitor series or what??
Saddle
Post edited by Saddle on
  • skrol
    skrol Posts: 3,449
    edited April 2010
    Do you mean for studio monitor or live sound reinforcement? I think they would do well as studio monitors. I don't think they would hold up too well for sound reinforcement.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • Saddle
    Saddle Posts: 6
    edited April 2010
    skrol wrote: »
    Yes, studio only. Mixing and/or mastering.
  • vc69
    vc69 Posts: 2,500
    edited April 2010
    I have always used the "industry standard" near-fields. Either NS10's or 4412's. I find Polk speakers, though a pleasure to listen to, are too colored for any real monitoring work.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • skrol
    skrol Posts: 3,449
    edited April 2010
    At our church we us a pair of powered Tannoys that work well. I believe they are the Reveal 6D Active.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • vc69
    vc69 Posts: 2,500
    edited April 2010
    Tannoy and Genelec are my favorites. But they were out of reach for my little demo studio way back when. If I were to buy a set of monitors today, they would probably be Genelec.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • Saddle
    Saddle Posts: 6
    edited April 2010
    vc69 wrote: »
    Genlec +1 :D
  • audiobilly
    audiobilly Posts: 351
    edited April 2010
    I agree, Polks' are a pleasure to listen to but they add to much to use as studio monitors. Tannoy, very nice-neutral. Genelec, very nice-warm. Consider KRK, nice-neutral. Very susceptible to ones' opinion, and what the purpose is. If you can make it sound good on NS10s' then it will sound good on anything!
  • vc69
    vc69 Posts: 2,500
    edited April 2010
    audiobilly wrote: »
    Exactly. I still own a pair. Wouldn't want to listen to them, but I can't seem to part with them.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • Saddle
    Saddle Posts: 6
    edited April 2010
    audiobilly wrote: »
    I currently have the KRK Rokit G2 6" near-fields. My mixes translate ok, but I need more bottom end when I mix. Otherwise I take out and listen to it on my 5's and Polk 10s to check it out. Sure would be nice to just mix on a set of speakers and be done...
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited April 2010
    Saddle wrote: »
    Ahhhh, to have our cake and eat it too, lol. Good luck man.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
