Looking for speakers to go along with PSW10
Hello,
I am a relative newbie when it comes to audio equipment. My situation is that a friend gave me his PSW10 (new) which I now want to use as part of a new stereo/AV setup. My first requirement would be a couple of floorstanding speakers and I was looking at the various Monitor editions 50, 60 etc. on Newegg.
I don't want to spend more than around $150 for each but was just wondering which of these would be a good match for the PSW10 in a relatively small room with hardwood floors. I'm not an audiophile by any means but also appreciate good sound. I envision hooking up a lossless music player to this system or possibly streaming audio via wireless and a squeezebox.
Any suggestions would be much appreciated.
Thank you
-Paul
Thank you
-Paul
HK 3490, Pair Monitor 70's (series II), PSW505
Post edited by paulgj on
Hello,
Thank you
-Paul
Sound-wise, all of the floorstanding monitors will sound similar - the bigger ones just go lower. In a small room, the 50s might be just fine, considering you'll have a sub to cover the low end. I say, save your $$, get the best deal you can find on the 50s, and take it from there.
That said, the 70s are probably a better full-range option on their own (i.e. - no sub) for music.
When you say small room, it often helps to state your dimensions. We all have different ideas about what that means. Good luck!
+1 on the monitors. I'd go with the 60s since they're only 30 more dollars on Newegg.
What kind of AVR are you using? Are you setting aside a budget for speaker wire and interconnect cables?Living Room: Receiver: Pioneer Elite SC-25 | Turntable: Technics SL-B200 | CD Player: Rotel RCD-955AX | Fronts: Polk RTiA3 | Center: Polk CSi A4 | Rears: Polk FXi3 | Sub: Velodyne DPS-10 | Cables: AudioQuest Type4 & TypeA
Office: Carver HR-742 | Speakers: RTi6 | Turntable: Numark 1600 -
mdaudioguy wrote: »When you say small room, it often helps to state your dimensions. We all have different ideas about what that means. Good luck!
My main room is about 20' x 20' if that helps.+1 on the monitors. I'd go with the 60s since they're only 30 more dollars on Newegg.
Right now I'm probably going with the monitor 60's when they have a good deal going. As far as AVR, I have an old Pioneer SX-6 from the 80's but want to buy a new receiver so any suggestions would be appreciated. Something relatively affordable (up to $500) with iPod input and compatible with squeezebox
As far as cabling is concerned, I have a new 50ft spool of Belkin "Pure AV" 16 gauge speaker cable but nothing else right now. Is this cable good for Monitor 60's and PSW10?
Thanks!
-PaulHK 3490, Pair Monitor 70's (series II), PSW505 -
The 60s are a good choice for your room. 70s would be even better. I do NOT agree that all the Monitors sound the same...the high end on the 70s when powered correctly has better imaging and soundstaging. It is the only Monitor with a cascade crossover.
You want to get an AVR with pre-outs. So Onkyo 707, Pioneer Elite VSX-21, Marantz 5004, Harman Kardon 254 or 354.
Listen to some of those and see what you like. They are all High current AVRs. You may have to spend a little more than 500 or look for a sale or buy used.
Belkin cable is OK for now--everything is relative.
Thanks! Just picked up a pair of 60's on sale at Newegg for $119.99 each. I'll check out those AVRs.HK 3490, Pair Monitor 70's (series II), PSW505
Less than 240 a pair! That's a STEAL!
Good Luck!
Definitely bigger than what I call small!!Thanks! Just picked up a pair of 60's on sale at Newegg for $119.99 each. I'll check out those AVRs.
Good choice. They should fill that room nicely, and at quite a reasonable amount of $$... Enjoy!
Those 60's are a steal at $120 ea. you will not be dissapointed. IMHO, the Monitors are hard to beat for the prices they can be had for these days. I know I love mine.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
