Bass Trap Plant?
jaxwired
I've got a tight corner and don't have room for a traditional bass trap AND I don't want something ugly AND I don't want to spend 700 large on one tube (what a rip off).
So I'm was thinking about trying this ($75 on ebay):
NAD C545 -> Benchmark DAC1 -> Bryston BP6 -> Bryston 4B SST2 -> Dynaudio Contour S1.4
Post edited by jaxwired on
Looks like it may rustle at a certain frequencies.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
This might be even better, but it's more money. I mean, look how fluffy this thing is. How could it not suck bass right up?
NAD C545 -> Benchmark DAC1 -> Bryston BP6 -> Bryston 4B SST2 -> Dynaudio Contour S1.4 -
That probably wouldn't be very effective at low frequencies.
These are pretty affordable: http://www.gikacoustics.com/products.html"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Face, those are good prices, but that bolster foam is only $25. It might be worth trying...2 Channel
I wouldn't bother. It wouldn't be effective at low frequencies, but may help with room echo."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Jaxwired,
None of the objects you added to the thread would act as broad band absorbers. The plants would act as diffusers at higher frequencies and do nothing at lower frequencies. The bolster foam would be a diffuser as well.
You need to purchase a 'traditional' product or build a broad band absorber for your desired location.
Arthur SchopenhauerAll truth passes through three stages. First, it is ridiculed, second it is violently opposed and third, it is accepted as self evident. -
integrated w/DAC module Gryphon Diablo 300
server Wolf Alpha 3SX
phono pre Dynamic Sounds Associates Phono II
turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
speakers Rockport Mira II
cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
rack Adona Eris 6dw
ultrasonic cleaner Degritter -
I'd like to second what jm1 mentioned. The big tubes for big dollars provide big results. However, if you're handy at all, there are many recipes on the net for a home-brewed trap.
Gordon2 Channel -
Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8) -
A high quality firm to deal with. I have 10 different traps from bass to high frequency absorbers from RT. Looking into a bit of diffusion for my back wall now.
Gordon2 Channel -
