Speaker cable size
DELETED... not worth the effortThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
All wiring is a factor in 4 elements:
-gauge size
- shielding (single or multi-layered)
- wire type (copper/gold/silver)
- solid or stranded
Distance and placement of speakers to unit producing the sound (AVR, power amp, etc..) is a key contributor to the sound quality. The further your speakers are away from the sound source and the more noise that can be introduced into the wire (such as a power source near the wire), the faster the quality of the signal degrades. If your speakers are close to the sound source, then lower quality wire vs higher quality wire is all relative.
In my situation, my speakers are only 4 feet away from the sound source so I have no signal leakage and no power source is near it neither so I don't have to worry about that distorting the signal neither. This is why I only have a slight improvement.
Now at the former club, the speaker runs are far away (100+ feet) and the wiring was ran on top of the dance floor lights. In this application you have to contend with the heat of the lamps and the electrical field from the 220v electrical wiring. Solid 12 guage, 3 layer insulated cable with banana plugs was required to prevent signal loss to the speakers in that setup, not to mention the speaker sound quality could produce sounds most lower-end models can not.
Concerning brands and brand names - That's a personal choice and in these forums more like a religion. Check the specs of the wire, that is the most important attribute of a wire, not the marketing name slapped on the packaging.
For the average user, using 14 gauge "in-wall" is good enough to get the full spectrum of sound to your speakers.
You have A LOT to learn."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Sarcasm does not help anyone, describing in detail what is missing from my posting does.Zone 1
(5.1 Setup)
-- VM 20 (L/R)
-- RM 8 Center (center)
-- VM 10 (S.L/R)
-- DSW microPRO 1000 (LFE)
Zone 2
-- Atrium 45
Denon AVR-2809
(7.1 Setup)
-- RM 6600 (L/R + center + S.L/R)
-- RM 7 (SB.L/R)
-- PSW 350 (LFE)
Denon AVR-1909 -
I'm not going to rehash a subject that has been beaten to death. There are atleast 20-30 cable threads. Get your learn on or continue in the darkness. Makes no difference to me.
That wasn't sarcasm, though...
Experience.Sarcasm does not help anyone, describing in detail what is missing from my posting does."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Experience.
According to MIT white papers, I'm on the money: http://www.mitcables.com/mit-cables-technical-/-whitepapers/reference-library/articles/mit-cables-technical-whitepapers/menu-id-252.html
Specifically: MIT White Paper: Energy, Efficiency, & Noise in Audio Cables
Better cables do produce better sound (have always said that), but for the average ear, that largely depends on the type of hardware and set-up you own if it truly makes a real difference. A point some of you seem to miss.Zone 1
(5.1 Setup)
-- VM 20 (L/R)
-- VM 10 (S.L/R)
Zone 2
-- Atrium 45
Denon AVR-2809
(7.1 Setup)
-- RM 7 (SB.L/R)
-- PSW 350 (LFE)
Denon AVR-1909 -
Keiko wrote:~yawn~
I agree Mike. :rolleyes:"Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
Point, set, match: http://www.roger-russell.com/wire/wire.htm
Another website that concurs with my analysis. For those of you who write "yawn" or some other sarcastic comment, I recommend you detail why you feel all of this is inaccurate.Zone 1
(5.1 Setup)
-- VM 20 (L/R)
-- VM 10 (S.L/R)
Zone 2
-- Atrium 45
Denon AVR-2809
(7.1 Setup)
-- RM 7 (SB.L/R)
-- PSW 350 (LFE)
Denon AVR-1909 -
That site must have one helluva Google hit count!
A/V Proc: UMC-1
AMP......: XPA-5
Speakers: Polk LCi-RTS100 x 5
Sub.......: Velodyne SPL-1200R
Bluray....: Pioneer BDP320
HD DVD..: Toshiba HD-A30 -
Personal experience.
Point, Set, Match!Political Correctness'.........defined
President of Club Polk -
Roger Russell?????? You have got to be kidding me. He's the worst charlatan of them all. All the people, including myself, whom are bored with cable debates will direct you to the 20 or 30 other cables discussions done right here on this board in which we have all participated. If you want to take the time and are really interested in what we (as a collective) have to say then spend some time reading; if not then fine............but I'm done here as it's all been said.
Your feelings for R.Russell are humours when MIT (Music Interface Technologies) White Papers indicate the same principles as noted earlier. The MIT cables are fine products and are designed for higher-end equipment that can take advantage of the better quality. But for the average consumer with average speakers purchased from BestBuy or similar retailer, those type of cables will not add additional value over traditional 14 gauge wire with short distances to the consumer's listening experience.Zone 1
(5.1 Setup)
-- VM 20 (L/R)
-- VM 10 (S.L/R)
Zone 2
-- Atrium 45
Denon AVR-2809
(7.1 Setup)
-- RM 7 (SB.L/R)
-- PSW 350 (LFE)
Denon AVR-1909 -
Roger Russell says there is no difference between low-end/high-end cables regardless of the equipment being used. That is why he, and his followers, are charlatans.
Don't forget he's a hypocrite as well. Spouting off about how cables make no difference whatsoever, but then wires the highend speakers he sell's with Cardas wiring. Charlatan-hypocrite with no credibility in my eyes, not to mention I hear differences in just about every cable or system I run.
There must not be a mod logged in right now. :rolleyes:
I just don't understand why people wanna argue about cables so much. If you wanna run lamp cord and are happy with it, run lamp cord. If you wanna run $3000 cable and can afford it, do it. Some folks act like they are getting paid to promote/change minds about speaker cables.--Gary--
