Speaker cable size
13»
    edited March 2010
    DELETED... not worth the effort
    edited March 2010
    kolbtod wrote: »
    All wiring is a factor in 4 elements:
    -gauge size
    - shielding (single or multi-layered)
    - wire type (copper/gold/silver)
    - solid or stranded
    Distance and placement of speakers to unit producing the sound (AVR, power amp, etc..) is a key contributor to the sound quality. The further your speakers are away from the sound source and the more noise that can be introduced into the wire (such as a power source near the wire), the faster the quality of the signal degrades. If your speakers are close to the sound source, then lower quality wire vs higher quality wire is all relative.
    In my situation, my speakers are only 4 feet away from the sound source so I have no signal leakage and no power source is near it neither so I don't have to worry about that distorting the signal neither. This is why I only have a slight improvement.
    Now at the former club, the speaker runs are far away (100+ feet) and the wiring was ran on top of the dance floor lights. In this application you have to contend with the heat of the lamps and the electrical field from the 220v electrical wiring. Solid 12 guage, 3 layer insulated cable with banana plugs was required to prevent signal loss to the speakers in that setup, not to mention the speaker sound quality could produce sounds most lower-end models can not.
    Concerning brands and brand names - That's a personal choice and in these forums more like a religion. Check the specs of the wire, that is the most important attribute of a wire, not the marketing name slapped on the packaging.
    For the average user, using 14 gauge "in-wall" is good enough to get the full spectrum of sound to your speakers.
    You have A LOT to learn.
    "Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | BlueSound Node3 - Tubes add soul!
    edited March 2010
    heiney9 wrote: »
    Sarcasm does not help anyone, describing in detail what is missing from my posting does.
    Zone 1
    (5.1 Setup)
    -- VM 20 (L/R)
    -- RM 8 Center (center)
    -- VM 10 (S.L/R)
    -- DSW microPRO 1000 (LFE)
    Zone 2
    -- Atrium 45
    Denon AVR-2809
    (7.1 Setup)
    -- RM 6600 (L/R + center + S.L/R)
    -- RM 7 (SB.L/R)
    -- PSW 350 (LFE)
    Denon AVR-1909
    edited March 2010
    kolbtod wrote: »
    I'm not going to rehash a subject that has been beaten to death. There are atleast 20-30 cable threads. Get your learn on or continue in the darkness. Makes no difference to me. :)
    edited March 2010
    kolbtod wrote: »
    That wasn't sarcasm, though... :)
    edited March 2010
    kolbtod wrote: »
    Experience.
    edited March 2010
    Face wrote: »
    Experience.
    According to MIT white papers, I'm on the money: http://www.mitcables.com/mit-cables-technical-/-whitepapers/reference-library/articles/mit-cables-technical-whitepapers/menu-id-252.html
    Specifically: MIT White Paper: Energy, Efficiency, & Noise in Audio Cables
    Better cables do produce better sound (have always said that), but for the average ear, that largely depends on the type of hardware and set-up you own if it truly makes a real difference. A point some of you seem to miss.
    Zone 1
    (5.1 Setup)
    -- VM 20 (L/R)
    -- VM 10 (S.L/R)
    Zone 2
    -- Atrium 45
    Denon AVR-2809
    (7.1 Setup)
    -- RM 7 (SB.L/R)
    -- PSW 350 (LFE)
    Denon AVR-1909
    edited March 2010
    Keiko wrote:
    ~yawn~
    I agree Mike. :rolleyes:
    edited March 2010
    shack wrote: »
    Point, set, match: http://www.roger-russell.com/wire/wire.htm
    Another website that concurs with my analysis. For those of you who write "yawn" or some other sarcastic comment, I recommend you detail why you feel all of this is inaccurate.
    Zone 1
    (5.1 Setup)
    -- VM 20 (L/R)
    -- VM 10 (S.L/R)
    Zone 2
    -- Atrium 45
    Denon AVR-2809
    (7.1 Setup)
    -- RM 7 (SB.L/R)
    -- PSW 350 (LFE)
    Denon AVR-1909
    edited March 2010
    kolbtod wrote: »
    That site must have one helluva Google hit count! :p
    A/V Proc: UMC-1
    AMP......: XPA-5
    Speakers: Polk LCi-RTS100 x 5
    Sub.......: Velodyne SPL-1200R
    Bluray....: Pioneer BDP320
    HD DVD..: Toshiba HD-A30
    edited March 2010
    Personal experience.
    Point, Set, Match!
    edited March 2010
    Roger Russell?????? You have got to be kidding me. He's the worst charlatan of them all. All the people, including myself, whom are bored with cable debates will direct you to the 20 or 30 other cables discussions done right here on this board in which we have all participated. If you want to take the time and are really interested in what we (as a collective) have to say then spend some time reading; if not then fine............but I'm done here as it's all been said.
    edited March 2010
    heiney9 wrote: »
    Your feelings for R.Russell are humours when MIT (Music Interface Technologies) White Papers indicate the same principles as noted earlier. The MIT cables are fine products and are designed for higher-end equipment that can take advantage of the better quality. But for the average consumer with average speakers purchased from BestBuy or similar retailer, those type of cables will not add additional value over traditional 14 gauge wire with short distances to the consumer's listening experience.
    Zone 1
    (5.1 Setup)
    -- VM 20 (L/R)
    -- VM 10 (S.L/R)
    Zone 2
    -- Atrium 45
    Denon AVR-2809
    (7.1 Setup)
    -- RM 7 (SB.L/R)
    -- PSW 350 (LFE)
    Denon AVR-1909
    edited March 2010
    BlueFox wrote: »
    Roger Russell says there is no difference between low-end/high-end cables regardless of the equipment being used. That is why he, and his followers, are charlatans.
    Don't forget he's a hypocrite as well. Spouting off about how cables make no difference whatsoever, but then wires the highend speakers he sell's with Cardas wiring. Charlatan-hypocrite with no credibility in my eyes, not to mention I hear differences in just about every cable or system I run.
    edited March 2010
    There must not be a mod logged in right now. :rolleyes:
    I just don't understand why people wanna argue about cables so much. If you wanna run lamp cord and are happy with it, run lamp cord. If you wanna run $3000 cable and can afford it, do it. Some folks act like they are getting paid to promote/change minds about speaker cables.
    --Gary--
Welcome!
