"Dedicated" sub cable vs. "Standard" RCA IC
Hey guys,
I think I just scored a nice deal on a Velo SPL-1200R, for $426 shipped! Got it yesterday and it looks pretty much new. Just a couple of very minor scuffs on the bottom. The rest is shiny-new!
Man, this things rocks my house at a volume level of 45, more than my MiniVee did at a level of 80. (I'm in serious need of calibration :-P )
Anyway, I bought some MIT AVT3's for my mains and center. Since the surrounds don't get too much action, I was going to go with something a little less costly, so I went to Audiogon and put in a bid for the Metallurgy GA-2 and won a set for $32. ADITIONALLY, I entered the Morrow Audio weekly drawing over there at Audiogon AND I won that also!
So now I have some "auditioning" to do. But I have ONE extra MIT AVT3 left over. I hooked it up to the sub for now, but my question is: will a "dedicated" sub cable be significantly better? I was thinking of going with the Audioquest Sub-X or Sub-1 (Sub-3 is out of my price range).
Any suggestions would be highly appreciated.
A/V Proc: UMC-1
AMP......: XPA-5
Speakers: Polk LCi-RTS100 x 5
Sub.......: Velodyne SPL-1200R
Bluray....: Pioneer BDP320
HD DVD..: Toshiba HD-A30
Post edited by AudioMancer on
  • PSOVLSK
    PSOVLSK Posts: 5,376
    edited March 2010
    I wouldn't think you'd notice much (if any) improvement over the MIT, but if you want to add a sub cable, here's another option: http://www.audioadvisor.com/prodinfo.asp?number=AQBTIISUB%203 I use this cable and I've been happy with it.
  • AudioMancer
    AudioMancer Posts: 21
    edited March 2010
    Nice, thanx!!
    I will seriously consider this. Would you happen to know what the Audioquest equivalent is? Based on the "original" price, looks like a Sub-1 (?)
    I guess what my question is: is a "dedicated" sub made in some special way to carry low frequencies? (more so than the "standard" cable?)
    A/V Proc: UMC-1
    AMP......: XPA-5
  • PSOVLSK
    edited March 2010
    I'm not sure what's "special" about a dedicated sub cable.
  • AudioMancer
    edited March 2010
    Can anyone else add a little "technical" info pro/con a subwoofer cable?
    A/V Proc: UMC-1
    AMP......: XPA-5
  • ikolbyi
    ikolbyi Posts: 77
    edited April 2010
    PSOVLSK wrote: »
    How does the marketing Juggernaut Monster compare to this cable?
    http://www.monstercable.com/productdisplay.asp?pin=3795
    I did purchase Monster's "Subwoofer 600sw Ultra High Performance Cable" for my installation because I got it discounted, I'm just curious how it stacks up.
    Opinions anyone?
    Zone 1
    (5.1 Setup)
    -- VM 20 (L/R)
    -- RM 8 Center (center)
    -- VM 10 (S.L/R)
    -- DSW microPRO 1000 (LFE)
    Zone 2
    -- Atrium 45
    Denon AVR-2809
    (7.1 Setup)
    -- RM 6600 (L/R + center + S.L/R)
    -- RM 7 (SB.L/R)
    -- PSW 350 (LFE)
    Denon AVR-1909
  • AudioMancer
    edited April 2010
    kolbtod wrote: »
    Opinions anyone?
    Over at this thread: http://www.polkaudio.com/forums/showthread.php?t=97992
    leroyjr1 says he's using monster cable for his sub, and he "loves it". Sounds like it's a quality cable. Not sure if it's the same one you're using.
    He has almost 5,000 posts so I would assume he's knowledgeable.
    A/V Proc: UMC-1
    AMP......: XPA-5
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited April 2010
    Cable threads are a dime a dozen these days with opinions both ways. IMHO, if it sounds good to you, who cares who makes it. I have a 25' Rocketfish Sub cable, and it does the job very well.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • ugapug
    ugapug Posts: 6
    edited April 2010
    The only caveat I have is - if it's a long cable and it's poorly shielded, you might get some hum.
    My Rig:
    Onkyo TX-SR806
    Front: Polk RTi8
    Center: Polk CSi5
    Surrounds: Polk RTi4
    Sub: SVS PB12-Plus/2
  • AudioMancer
    edited April 2010
    Thanx for the help and advice guys.
    I'll hang on to the AVT3 for now, 'til I have $300 burning a hole in my pocket. LOL!
    A/V Proc: UMC-1
    AMP......: XPA-5
  • amulford
    amulford Posts: 5,020
    edited April 2010
    Your Avt will do all you ask of it. No need to upgrade from there.
    The quality most important to me in a sub cable is low frequency noise rejection. Like the emf you would get from power (think 60 Hz hum). Low freq signal propagation too, but alot of times that quality will be in the wire lay.
