Speaker calibration...done right??
mknutt
mknutt Posts: 61
edited November 2003 in Speakers
Just got done calibrating my speakers with the Avia disc and the RS SPL meter. Here is what I did...
Set all speaker levels and bass/treble to 0. Played the test tone for the left main and turned master volume until it read 85dB. Leaving the master volume alone, I then switched to each speaker and changed their settings until they each read 85 dB. My final settings were...
Left Main 0
Center -3
Right Main 0
R Surr +4
L Surr +4
Is this normal or did I do something wrong? I noticed everyone else's settings were pretty much even +/- 1-2 dB. Just want to be sure I am getting this right.
Post edited by mknutt on
  • i4gotmyid
    i4gotmyid Posts: 173
    thats not bad at all, i have +10 for center and +7 for left surround and +8 for right surround because my mains have all the juice its hard for the rest to catch up
  • thehalo8
    thehalo8 Posts: 127
    It also depends on how far away you are from your speakers. At my old place my center and mains were 0-2 db but my surrounds were around 8 db. Every setup is going to be different, so don’t feel like you have done something wrong. If you did it properly, which is not to hard, and it sounds good what is there to worry about :)
    Mains: Polk RTi70's
    Center: Polk CSi40
    Surrounds: Polk TC60i's
    Sub: Polk PSW505
    Receiver: Onkyo TX-DS696
    TV: Samsung HLS 5687W 56"
    DVD: Sony DVP S5300
    Protection: Monster HTS 3600
    Backup Battery: Belkin AP3080010
  • dorokusai
    dorokusai Posts: 25,628
    Looks about normal. I have odd values for a couple speakers, just like you.
  • Dr. Spec
    Dr. Spec Posts: 3,780
    Was the meter at the seat at ear level, on C-weighted Slow, facing the center channel and angled 45 degrees upward?
    What about the subwoofer? Set the channel level to -5 and adjust volume at the sub. What did you end up with there?
    SVS
