Quad NOS RCA 6922/E88CC Gold Pin
thsmith
I bought this quad about 3 months ago and they have about 200 hours on them at most.
I have tested them on my Sencore and they are pass short and gas test, emissions read on all and both grids the same at 103.
I believe they were made by Siemens even though they say made in USA. All come with nice RCA box's.
The etched codes on all read
942
7L9
*9I
USA
$125 shipped and PP. Sold my Athem Pre 2L and no longer can use 6922 tubes.
942
7L9
*9I
USA
Post edited by thsmith on
I should add that these RCAs bested Amperex 6DJ8s I had in the Anthem. Very sweet sounding tubes.
Hopefully some of the seasoned tube guys can verify these were made by Seimens. I do not believe RCA ever made their own 6922s. Amperex and Seimens made RCA 6922 tubes for them.Speakers: SDA-1C (most all the goodies)
IIRC,, the RCA "goldpins were made by Seimens and HalskeJC approves....he told me so. (F-1 nut)
I am not sure about this but.....IF you can swap these out with 12au7's in the Anthem1 tube amp? I'm game and consider these sold.
If not, carry on and I apologize about the disruption of the thread.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
Tom, do not believe 6922 can replace 12au7sSpeakers: SDA-1C (most all the goodies)
usually 12au7's and 12ax7's interchange.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
tracy i have a quad of rca 6dj8 that the seller said were amperex and they sound very good, i'm thinking about yours. if they don't go pretty soon i may pull the trigger.
marvinAmplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Monday morning bumpSpeakers: SDA-1C (most all the goodies)
A very nice quad of 6922, you will not be dissapointed.Speakers: SDA-1C (most all the goodies)
Your tempting me Tracy! Funds are tight right now. If these are still available at the end of the week, I'll see what I can do.
Ok, to hopefully push a couple of you over how about $115 shiipped and PP.Speakers: SDA-1C (most all the goodies)
PM sent.Main System 2.2:
Proton AA-1150 ~ Yamaha C-4 ~ Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
(2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2 ~ Sansui D-X111R
Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
Home Theater 5.2:
Yamaha RX-V800 ~ Furman Elite-15 DMi ~ Polk Audio RT55i ~ RT35i ~ CS400i ~ (2x) PSW450
Winter Residence 2.1 (laptop system):
Yamaha RX-485 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200 -
Thanks Carl, PM respondedSpeakers: SDA-1C (most all the goodies)
Are these actually made in West Germany then even though they say "made in USA" on them? As far as I know Siemens didn't make any tubes in the USA, but I could be wrong. Any help is appreciated.
Greg
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
Siemans made 6922 tubes for RCA.Speakers: SDA-1C (most all the goodies)
Tracy, Why'd you sell the 2L? I might be interested in these. My 2L still has the factory originals.____________________________________________________________
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, McIntosh C2300, Marantz AV7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Sim Audio Moon 380D DAC, EPSON Pro Cinema 6050 -
I understand that, but I am wondering if these tubes are actually made in the US or Germany? I know that Siemens made tubes in Germany for RCA, but was not aware that they were labeled made in USA. Also, do these tubes have gray divider plates or the shiny silver ones? Couldn't tell from the pictures. Thanks again.
Greg
Greg, not sure what to tell you. Hopefully the etched codes will help you.
What and where are the divider plates ?Speakers: SDA-1C (most all the goodies)
The codes are what's throwing me actually. The codes on the Siemens labeled E88CCs have the codes on the getter support and is usually something like :A2 over 9L (or something similar). These codes don't seem like Siemens normal codes and are certainly not found in the normal Siemens spot. These codes are more like Amperex codes.
The divider plate also refered to as a "shield" is the thing that is just below where the code is etched into in the picture below. I believe these RCAs are made by Amperex, the more I think about it.
Greg
I need to charge the battery in the camera but until then, if you are referring to the plate in the picture with arrow it is grey not silver IMO.Speakers: SDA-1C (most all the goodies)
I bought a Wright WLA12A. The Pre 2L was great.
No doubt you will enjoy the RCAs over the stock Anthem tubes.Speakers: SDA-1C (most all the goodies)
This is where the "shield" is located. But, as I said I believe these are made by Amperex, and may not have this shield. The * is the code as well as the length of the code are the givaways.
Greg
I guess the shield on my tubes are grey.
Are you interested in buying my tubes or just ?Speakers: SDA-1C (most all the goodies)
I would like to buy a quad of Siemens 1965 or earlier 6922s, hence the questions about the build of them. I already own some Amperex's and I believe that's what these are (although these are the US made ones and mine are Holland). These are still very good tubes and are considered some of the best out of the 6922 bunch. If anyone else knows I'd appreciate it.
Greg
SoldSpeakers: SDA-1C (most all the goodies)
