BiWire - Stupid Question?
hank1105
hank1105 Posts: 63
edited October 2003 in Speakers
I always see references to biwiring speakers. I have noticed 4 posts on the back of my speakers, but only used the usual speaker cables to connect them to the receiver. If someone could be so kind and tell what biwiring is and what are the pros and cons. Thanks.
Hank
My 7.1 System:
Fronts: Polk RTi70's
Center: Polk CSi40
Surround Sides: Polk FXi50's
Surround Backs: Polk RTi38's
Sub: SVS PB1-ISD
Receiver: Sony STR-DA7ES
SAT Receiver: Sony SAT 200B
HDTV: Panasonic CT-36HX42
Post edited by hank1105 on
  • Grimster74
    Grimster74 Posts: 2,577
    edited October 2003
    Hank
    See also...
    http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=13554
  • hank1105
    hank1105 Posts: 63
    edited October 2003
    Thanks Grim. Just a technical question how does bi-wiring work? How would I hookup bi-wires to a speaker?
    My 7.1 System:
    Center: Polk CSi40
    Sub: SVS PB1-ISD
  • Grimster74
    edited October 2003
    It requires 2 sets of wires per speaker. At one end you take both positives and twist them together, then do the same for the negatives. Hook that end to the speaker terminal on the RECEIVER. Then, remove the metal jumpers on the RTi70's. Take one end of the 2 set of wires and connect them accordingly to the top binding post which runs the tweeters. Then do the same to the bottom binding post which run the mids. Just make sure you have the polarity correct +/+, -/-. Same for at the receiver. Hope this helps.
  • Grimster74
    edited October 2003
    Here is a link from my system showcase that shows what it should look like at the speaker. I can never get a picture uploaded on this forum. Its always to damn big.
    http://clubpolk.polkaudio.com/showcase/closeup.php?userid=40818&pic=76_12_big.jpg
  • hank1105
    hank1105 Posts: 63
    edited October 2003
    Excellent, makes complete sense now. Thank you very much.
    Hank
    My 7.1 System:
    Center: Polk CSi40
    Sub: SVS PB1-ISD
